Question about GE Refrigerators
Ice forming in freezer
I have large masses of ice forming in the freezer. It is right below the ice maker. It is just making huge pieces of ice in the main part of the freezer. Everything is still frozen, so I am not sure what is going on.
    Problem Solver:
  • 8 Answers
Un-plug refrigerator,remove the back panel from freezer section and see if ice is covering coils. If so, probably the defrost heaters are blown.
Posted on Feb 23, 2009
Ice maker leaking into ice storage tray
start with hose replcement buy parts at sears water hose to main ice maker might have crack in it or the stopper is bad get in ther look close with brite light
Oct 14, 2008 | Refrigerators
Large mass of ice cubes frozen together in tray, most likely from leaky ice maker. Can this be fixed without purchasing a new ice maker.
have you checked it when it's filling to see if it's overflowing or the heater on the ice maker might not be shutting off and melting some of the cubes but you have to check,also it could be the water valve,see if there's an adjustment on the ice maker,look in your book,some of them have an adjustment,try to adjust it so less water is coming into the ice maker but to answer your question you might need a new ice maker or a water valve,the only way to tell is to watch it when it fills to see what's happening,you can pop off the cover to the ice maker and jump it out with a piece of wire,in the bottom right hand corner you'll see two holes close together,t and h stick the jumper wire in those two holes and the ice maker will start up,watch it until it fills,if it overflows try the screw to let less water into it,if that doesn't work then it's gonna be the water valve letting to much water come into the valve
Feb 11, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
My ice maker quit making ice on my amana bottom freezer
Hi, If your ice maker has stopped making ice then you need to check these things.
The lever that controls the ice maker has been pushed up which turns it off. If you have a red lever, pull it down to the wire and if you just have a wire then just pull down the wire to start your ice maker up.
Make sure the freezer temperature is below 10 degrees F If the freezer is too warm ice production will be poor because the ice maker will not cycle properly.
The ice maker fill tube may have ice formed in it, blocking it. Use a hair dryer to melt the ice. Watch out for the plastic parts, so that you do not melt the plastic. Also check the water inlet valve and the shut off valve, to make sure it is not plugged with debris. The openings in those valves are very small.
Check the gears in the ice makers to see if they are broken or stripped. Also look to see if the ice rake is broken. All parts in the ice maker are replaceable individually, If you find broken parts replace them.
Take care
Jul 23, 2010 | Amana ABB1927DE Bottom Freezer...
My icemaker is making huge chunks of ice in bin
You will need to replace the termination thermostat. What sounds like is happening is. Every 8 to 10 hr. your freezer goes into defrost for a set period of time. There is a termination thermostat that senses the temp at you evaporator coil in you freezer. When you heaters come on they defrost the ice from your coil. once the termination thermostat senses the temp has gotten to a preset degree, it cuts the power to the heaters. This keeps the heaters from staying on the whole period and making your freezer warm. After the pre set time period the timer turns the compressor back on. What it sounds like is happening is the termination thermostat is not opening, cutting the heaters off. By not doing so, it's letting your freezer get above freezing, melting your ice some. When the timer advances into cooling again it freezes your ice together. I would say it's your water valve leaking but that would make large pieces of ice that the ice maker has trouble dumping and also sometimes a large chunk that does not look like cubs. That would also eventually freeze the inlet tube closed..
Please rate solution
Aug 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Stopped making ice, motor is running, compressor is working, large blks of ice are forming in the rack above were they should be dropping into the bin
Disconnect the water line from the water control valve to the ice maker to see if it is letting water thru all the time. It should only let water pass when the ice maker is empty.
May 03, 2009 | GE Freezers
GE Monogram refrigerator/freezer problem/ice dam in ice maker
I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
Mar 26, 2009 | Refrigerators
Ice maker leaking
what is the model number of this fridge?
HTML clipboard_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
May 19, 2008 | Sub-Zero 632 / S
Refrigerators Logo
144 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
