Question about Bissell 3105-4 Featherweight Vacuum
I don't know how to put on my belt to my Bissell easy vac
  • 328 Answers
There are five screws underneath where the beater bar is. These need to be undone before you can open the sole plate up and get to the brush. If you still need help consider downloading this free pdf:
http://www.BISSELL.com/images/UserGuides/3130_1107.pdf
Dont forget to rate, thanks.
Posted on Mar 07, 2009
Bissel easy vac roller won't work
remove brush roll and clean any string, hair, or whatever from it. especially around the ends. you can also unscrew the ends and check for debris there also. when you put ends back on use a little wd40 to lube up the bearings. if that doesn't work replace brush and won't hurt to change belt
Feb 13, 2013 | Bissell Roller Brush 2037029 for Easy Vac...
My Bissell 3130 Easy Vac Bagless vacuum makes a "rev sound when pulling back on the vacuum, never did this before i have taken apart and cleaned vacuum thoroughly, not sure what else i can do
The drive belt may be wornout/stretched and the act of pulling the vacuum backwards could be causing the belt to slip and the motor to rev up as a result.
Do you have a replacement belt you can try?
Jan 05, 2011 | Bissell 3130 Bagless Upright Vacuum
Have a bissell easy vac 3130-B and the brush on the bottom stopped turning i never looked before so i don really know if it turned in the first place
Behind the brush will be a metal thing that spins when the vacuum runs. That's what the belt loops over with the other end around the brush. You can sometimes find the belts a places like wal mart.
Aug 31, 2010 | Vacuums
Can't find replacement drive belt for bissell easy vac power brush model 3108
go to bissell.com and look it up there.or call all-type vacuum and janitorial supply and ask for lisa or bonnie.tell them pete reccomended them.314-275-8006
Apr 27, 2009 | Vacuums
Replacing belt on bissell model 1694
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=707372 Generic problem for all Vacuums
Replacing belt on Bissell model
Posted by chi_agee on Jun 25, 2008
Replacing belt on Bissell model 1694
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Most of the Bissell’s the belt is changed from the bottom or the top is removed and you service it from the top. There are usually screws, clips or levers to remove the bottom plate or top cover and once that is removed then the belt change. If the belt is a flat belt the recommended belt change is every 4 to 6 months and id it is a geared belt then you would change it once a year for the best cleaning. If you have questions, refer to the owner’s manual in the trouble shooting section, if you don’t have an owner’s manual then you can contact the Bissell Factory cust serv listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 25, 2008 | Vacuums
Bissell 3510 Vac with loud noise but not belt
Did you check the brush roll, may have a problem with it. But you could have a problem with a motor bearing going bad, they getting loud, also if there is a problem with the motor fan, that may be the cause of it being loud. Bissell 3510 either is obsolete or is thw rong number, it doesn't come up at the Bissell site.
Mar 16, 2008 | Vacuums
Bissell 3105-4 Featherweight Vacuum Logo
89 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
