Dell 3100cn Laser Printer Logo
Posted on Feb 23, 2009
Printer not responding
Error message: Print spooler service is not running.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 05, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
59
Points
0
Start the spooler form control pannel, administraive tooles-service.
shloud work after.
2answers
My canon printer will not respond when trying to print. I also tried connecting it via USB cord and not responding. What can I do? What is wrong?
Canon Printer Not Responding is a common error that you might get. This error can be displayed because of several reasons like Outdated drivers, weaken network connections, USB problems, and much more. For resolving this error, you have to follow the troubleshooting steps mentioned below. These are the basic procedures that will help you to resolve the error successfully.
Methods to Troubleshoot Canon Printer Not Responding:
Run the Printer Troubleshooter to Fix Canon Printer No Response Error:
The windows have a built-in printer troubleshooter that can fix your error. This tool will help you out to fix the issue of the printer not responding:
Press the "window logo key" and type "troubleshoot". Then select Troubleshoot or Troubleshooting.
In troubleshooter, click Printer and then "Run the troubleshooter" (using windows 10)
Click "Use a Printer" (using windows 7)
Follow the following instructions to complete the troubleshooting. If this works for you then you don't have to go on further methods.
Restart the Printer Spooler Service:
The printer spooler service on your computer manages your communication between your printer and computer and print jobs. If this service is not working properly on the computer then your canon printer will stop responding. You have to reset this service to fix your printer issue.
Press the "window logo key" and R simultaneously on your keyboard to request the Run.
In the Run type "service. MSC" and press Enter.
Click "Print Spooler and then click Restart.
Check that your printer is printing the document.
For More Follow this:- Canon Printer Not Responding
2answers
Where i could see the printer spooler?
I open the run command you can type: net start spooler
(You will get a message that says the print spooler service has started)
If you still have issues open the run command and type: services.msc
it will display a list, where you can find print spooler.
From there you can right-click on it and set it so it is started and runs automatically.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
I got an installed printer, and it can't print. It seems that my PC cannot read the printer, like there is no printer installed. When I try to uninstall the printer and to install again the error
When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select Automatic Service status click Start Then click OK MICROSOFT PRINT SPOOLER FIXES
http://support.microsoft.com/kb/934885
Got a message of printer not responding
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Print spooler error
reinstal the driver with print spooler running, good luck
2answers
What does it mean when i get the error message print spooler services not running
you need to turn it on, Go, . START>>RUN>>services.msc enter. When the services screen comes up, scroll down until you find the "Print Spooler" Enable it, Start it, and set to Automatic, reboot, ya good to go.
2helpful
2answers
"fatal print spooler error" error message
Completely uninstall the printer driver and install again. If this does not work, there is a corruption in the windows registry or in the print spooler cache files.
For a temporary workaround, disable print spooling. But, if you do, you will need to remember to never close an application you print from until printing is actually finished.
The print spooler service is not running.
Reinstall the printer drivers will shore it up quickly the spooler has to do with the printer so do that and you should be fine.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Problem installing lexmark 2650 on toshiba a 30 satellite
did you add a printer onto the computer control panel
did you down load the printer driver from the manufacturers web page downloads
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
