Question about HP Photosmart D7160 InkJet Printer
Yellow ink cartridge will not print
New yellow ink cartridges will not work
    Problem Solver:
The print heads must be bad. I had the same problem. Still under warranty and HP replaced printer with rebuilt unit
Posted on Mar 12, 2009
Hi, I have a Canon Pixma iP4300 printer and the Yellow ink is not printing. I have changed the cartridge and all other colours are working except Yellow. I would appreciate any solutions you may be able...
I have a Canon Pixma iP4300 printer and the Yellow ink is not printing. I have changed the particular cartridge and all other colours are working except Yellow. I have cleansed the printer several times and tried with new Yellow ink cartridges with new chips, but nothing helps.
What should I do?
Jan 25, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Yellow ink will not print
On the Brother MFC series printers it uses remote ink trays as you will know, instead of having print heads directly on the ink cartridge. Whilst this approach makes it cheaper to produce the ink, and easier to change the cartridge, it can make it difficult to clear clogs.
There are several things you can do which may help, but B. and C. are at your own risk. All steps assume you have a new yellow ink cartridge.
A. In paint or another program, create a full page yellow image and keep printing it out. See if it gets any better after each print. If it does, continue until it seems to be working fine.
B. If you can manage to get to the print head, you can get a cue tip, dip it in rubbing alcohol and gently clean the print head. Leave 20 minutes to dry, and then do step A. again.
C. (AS A VERY LAST RESORT AT YOUR OWN RISK. THIS IS GOING TO RUIN YOUR YELLOW INK CARTRIDGE SO USE AN OLD YELLOW ONE IF YOU CAN) If steps A. and B. fail, you can put a "little" rubbing alcohol in the Yellow Ink Cartridge, and keep trying step A. If Yellow starts printing again, swap to a yellow cartridge that does not have rubbing alcohol in it. You are now going to have to cycle through many pages to clear the rubbing alcohol from the ink lines.
Note that if you keep cleaning the cartridges, it is going to use a lot of ink, and may actually hinder solving your yellow ink problem.
Good uck
Apr 24, 2010 | Brother MFC 240C All-In-One InkJet Printer
Print Head Problems??
The ink cartridges on your Canon Pixma MP500
print head not problem your yellow cartridge &black
problem
Oct 07, 2009 | Canon Pixma MP500 All-In-One InkJet...
Stopped printing yellow, worked fine yesterday, new cartridge installed, suspect airlock as no yellow at all.
Try taking your yellow cartridge out and giving it a shake. Also make sure you've removed all the plastic tabs from the cartridge, and test to see if there is any colour coming from it by pressing a damp paper towel against where the ink shoots out. If it still doesn't work I would simply return the yellow ink cartridge to where you purchased it for a new one.
May 06, 2009 | Brother MFC-5840CN All-In-One InkJet...
Alarm flashes ink emptyhas ink! color was printing only yellow/green now prints only red/pink!
any chance it has dried out? run the test / head cleaning / did you reset the cartridge when you replaced it? generally if one or two colors work - the problem is the ink cartridge or the head for the colors not working. Did you remove the "tape" on the new cartridge?
Apr 16, 2009 | Office Equipment & Supplies
Yellow won't print with old or new cartridge
Some ink jets are differant. Some have an Ink jet cartridge system that has the print head on the cartridge itself. Others use a seperate print head. When you pull out the ink cartridge is there another small unit below the cartridge that you can pull out? If so that is the print head and you will need to replace it. Also make sure that you have taken off the tape off of the air pilot hole on the ink cartridge so it can work properly. www.tonerovernight.com
Mar 16, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
Cannot get yellow to print
I had the same problem with the yellow cartridge. Yellow quit printing, put in a new yellow and still would not print yellow. I had a help file, don't know where I got it, but it suggested replacing the black ink cartridge also, even though the black wasn't low yet. Replaced the black, ran a few nozzle cleans and everything worked fine. Don't know why. Try it
Mar 03, 2007 | Epson Stylus CX6600 All-In-One InkJet...
HP Photosmart D7160 InkJet Printer Logo
214 people viewed this question
Ben Johnson
