I have a american standard freedom 95 vertical upflow furnance. just installed 9/08. I am gettinf water dripping down inside of furnace to bottom. No hoses leaking anywhere. No water from vent pipe or inlet. Looks like coming from inside on right side from behind vent blower? please advise.
  • 478 Answers
Yep, thats where the lweak is. try to loosen the three screws and adjusting it to getgood seal from o-ring behind inducer motor.
Posted on Mar 12, 2009
Our thermastat won't let us reset the temp. it says its locked, we have no idea what that means or how to fix it, or even it that's the problem. our furnace thermostat.
What type of thermostat do you have?
You can call the company that installed it to get the over ride password or how to reset the thermostat so you can control the temperature
Jan 08, 2017 | Heating & Cooling
How do i deal with the dripping of water from my Mitsubiishi split system from inside unit? Will putting the unit on 19 and then turning it full bore clear over condensing?
NO
the water is condensation from the humidity in the air turning to water on the cold evaporator core
normally it drips into a tray and drains away outside
if it is inside ( running down the walls it indicates
the drain hole and tube is blocked or the evaporator core is covered in gunk and holding the water up and not dripping where it is designed to
Call an accredited ac specialist shop to clean the fins and drain tube
Jan 06, 2017 | Heating & Cooling
We have royal red furnace to heat our home.The fan dose not stop.
Details.......does the furnace function normally otherwise? Might just be a stuck fan switch. Make sure the thermostat hasn't been set on Fan ON setting or summer air circ. on older furnaces.
Find the fan switch and tap it and see if fan quits. If it does,fan switch is bad.probably. Always make sure your air circ. filter(return air to furnace) is replaced every 3 mo. or so,too. don-ohio (:^)
Jan 03, 2017 | Royal Heating & Cooling
My thermostat is set on 68 degrees and it shows room temperature is 68, but the furnace still kickson, Honeywell said it has a 1 degree difference. so what's the problem then?
Yes there is a one degree tolerance, in fact my heater just kicked on and it is set to 67 and the inside temperature reads 67. It is also a Honeywell.
Dec 28, 2016 | Heating & Cooling
My oil furnance is running but when it reches temperature it shuts off and will not come back on until we bleed the lines
You have a small leak on the suction side of the pump between the tank and the pump. when this happens the pump looses prime each time the furnace shuts down and when the furnace tries to fire up again the saftey device trips before the oil gets to the burner.
Jan 25, 2015 | Heating & Cooling
Is it cost effective to replace draft inducer blower on 22 year old furnace?
Depends on the cost to repair. Probably a 22 year old furnace is not very efficient also. Take every thing into consideration.
If it still works it may work for a while but you don't want a break down in the middle of winter.
Nov 07, 2014 | Heating & Cooling
How do I tell the age of my Comfort Maker furnace?
Check for a serial number. Inside the door or near where the wires go in.
Sep 13, 2014 | Heating & Cooling
I have a Coleman Evcon electric furnace, the blower fan runs constantly and I have to shut the breaker off inside the front cover to turn it off. The switch is on auto and it runs even when the thermostat...
It could be a thermostat problem. Also it will seem to run constantly as it tries to heat and one of the elements are working which could be a sequencer problem.
Nov 28, 2013 | Heating & Cooling
Water dropping on air conditioner
Water is dripping on your ac from a duct? Or is the unit it self leaking Are you sure you don't need a Professional Air Duct Inspection?
If you are in the market for an Air Duct cleaning check out Air Duct Cleaning Dallas Tx.
Jun 10, 2012 | Heating & Cooling
Heating & Cooling Logo
373 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
