Question about Brother HL-5240 Laser Printer
HL-5240 wrinkled first page on my HL-5240 when printing, any suggestions on how to fix?
  • andy_lock200 Mar 13, 2009
    Keeps Wrinkling the paper or jams altogether, have had it all apart and cleaned it all but still keeps happening
  • 138 Answers
Unfortunately your problem is with the fusing assembly. This is not a cheap part at all. It's available at www.precisionroller.com for around $170.00. The problem is the lower silicon roller in the fuser. If you open the back door and then the back inner door, you can view the fuser. The part your looking at is the orange roller. It will either be wrinkled, ballooned, or separating the outer clear sleeve from the inner core. The last one is a little harder to see without a flashlight or similar. If you look close, you'll see the clear silicon oil inside between the outter sleeve and orange core. If the printer is still under warranty, call Brother for a replacement fuser. I know the news is not good but, hope that helps you.
Posted on Mar 30, 2009
Brother hl-5420 leaving imprints
Replace the wiper blade which has been fixed under the drum
Dec 08, 2011 | Brother HL-5240 Laser Printer
Brother HL 5240 Laser Printer Hi I hope you can
Hello
You need to re-install drivers of the printer. also check the USB cable.
Good Luck
Jan 07, 2011 | Brother HL-5240 Laser Printer
When we try to print envelopes. It grabs the
Open the door on the back above the power cord. Rotate both blue levers all the way up so they change from "1" to "2". Wrinkle problem will be solved. This was in the troubleshooting section of the online user manual, page 95. You would think they would tell you about this in the envelope section of the manual.
Jul 01, 2009 | Brother HL-5240 Laser Printer
FIRST printed page is quite wrinkled, the rest are fine
Hello sir;Try to print one page, when the paper process half way then stop the machine, remove the cartridge, check the paper is wrinkling, if yes ,that's meanspaper feed roller dirty or registration roller slipply, ortherwise, check the fusing unit, need to replace presure roller. The 2nd issue, you need to replace paper stop roller or rubber pad.
May 12, 2009 | Brother HL 5250DN Laser Printer
Black pages
Take a look here at the possible causes
http://www.printertechs.com/tech/print-defects/blackpages.php
Hope this helps
Remember to vote
good luck
Dec 03, 2008 | Brother HL 1440 Laser Printer
Envelopes all come out of the printer wrinkled
Open the back of the printer. You will see 2 little blue levers on either side. Put them in the opposite direction, that is, if they are up, snap them down. I dont know the mechanics of this, but it worked for me.
Nov 01, 2008 | Brother HL-5240 Laser Printer
Printing envelopes on HL4040CN
I just bought a HL-4040CN and all my envelopes wrinkled, regardless of the size, paper thickness or software settings (thin envelope, thick envelope, etc.). Here's how I solved the problem....Open the rear panel and you'll notice a small gray lever on each side, which is probably pointing to "A" on the scale (A, B, Envelope). Move both levers to "Envelope" and close the back panel. The troubleshooting manual says the levers should be moved back to "A" after printing the envelopes, but I left them in the Envelope position and can't see any difference when printing regular or test pages or envelopes, except the envelopes are no longer wrinkled. I called Brother and asked them if there was any reason why the levers can't stay in the Envelope position, and they told me they could be left there if it wasn't negatively affecting other documents. Now, I have a great printer that prints everything without any problems. Hope this helps.
Sep 08, 2008 | Brother HL-2040 Laser Printer
My Brother HL 5240 has Status toner, drum and paper lights on, I bought it on 4/30/08, new toner, plenty of paper, it showed on computer: printer is off line, but it was connected with computer. Really...
The drum light will flash on my brother HL-5240 Laser Printer when printing but it continues to print just fine. Does this mean the drum needs to be replaced?
Aug 07, 2008 | Office Equipment & Supplies
Hl5240 laser
Fuser unit will need to be replaced, very common workshop job on these machines.
Oct 25, 2007 | Brother HL-5240 Laser Printer
Brother HL-5240 Laser Printer Logo
370 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
