Question about Whirlpool Calypso GVW9959K Top Load Washer
I have a whirlpool top loader with calypsoTM wash motion. The machine showed Off Balance I had to start over them the machine showed ''FL'' over Fill. I turned the water off and have tryed to get the machine to dran but after a minutes the ''FL'' comes on. I need to know have to get the lower tank empty.
  • 15,935 Answers
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%^
Posted on Sep 18, 2010
What will cause my Whirlpool washing machine to set on low speed spin cycle?
The machine uses automatic load sensors to balance the load and when you put something in the machine that is big, like a comforter, it knows that it cannot balance that item. So with a front loader it wont spin at high speed because it would be off balance and either damage the machine or the machine would "walk" because of the off balance motion.
Apr 28, 2014 | Whirlpool Washing Machines
My whirlpool top loader extra large washing macine
Many late model washing machines use a direct-drive system to agitate and spin. They don't use belts or pressure wheels to transfer power and motion from the motor to the transmission. The motor is coupled directly to the transmission. If the motor is running and there is no agitation or spinning of the tub, the culprit is usually a plastic coupling between the motor and transmission or the transmission itself.
Aug 07, 2008 | Washing Machines
What dose a FL code mean on whirlpool cabrio platinum
I will try and help for some reason Whirlpool likes to flip letters around which differ from the service manual FL would be an LF long fill or is it a F1 the model doesn't show in the Whirlpool data base nor parts suppliers I suspect wtw6600sb1 does the machine from initial start fill correctly then wash if so we can eliminate the pressure switch and hose after wash cycle unit should drain then fill with rinse water if the inlet valve does not let water into the machine to satisfy the pressure switch the control times out and flashes a long fill code this unit has a log valve system possible you have a bad inlet valve on the bank of valve or a bad control not outputing voltage to the valve, hope this points you in the right direction
Jan 14, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
I bought the Whirlpool Duet to replace my old standard washer & dryer and I find that the wash time is longer than the old washer. Even the quick wash takes about 1 hour. Am I doing something wrong...
I assume from your comment that your old washer was a top loader. Yes, front loading machines typically have longer cycle times than top loaders. There are several contibuting factors... first of all, the wash action of a front load is to oscillate the drum back and forth as well as provide a slow tumbling motion whereas a top loader w/ agitator or impeller has a more aggressive action. The more aggressive action rolls and tumbles your clothes more often and therefore cleans faster. Also, because front loaders spin very fast (up to twice as fast as top loaders) to reduce the amount of moisture left in the clothes, they need to have balanced loads. They accomplish this by testing and rebalancing your load several times during each cycle before beginning to spin.
That was a long answer to your question- no, you are not doing anything wrong.
Good luck.
Jan 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool cabrio washing machine
FL error code generally means 'flood condition' which is telling you the machine is overfilling with water with water.
Try pressing STOP/CANCEL to clear the display.
If the condition persists the water fill valve or sensor may be faulty and may need replacement.
May 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a maytag top loader washer and when it is on the spin cycle the whole drum shakes hitting the walls of the washer
Without having the model number, it is difficult to diagnose.
Most Maytag / Whirlpool top loaders use a set of balance springs and friction pads to buffer the shaking.
Here is a Whirlpool site with a number of PDF files on their products including troubleshooting sections.
Find your washer under laundry products and open the PDF, it will probably take a few minutes to load.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6?OpenView&Start=1
Sep 27, 2009 | Washing Machines
Washer vibrates during spin cycle
Front loaders have to be situated on solid flooring such as a basement or they will vibrate.
http://tclaundryrepair.com/
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool top loader unbalanced spin cycle
First change the springs - both the leveling and suspension. You may also need to change a few other parts on the brake and drive tube including the thrust ring. But replace the springs and let see what happens.
Post your results . Remember to rate this solution
Regards
Jul 27, 2008 | Whirlpool LSB6200KQ Top Load Washer
Front loader washing machine
Plug off the wall; open up behind. Possible some spring hs come off or a shock absorber is faulty. Can be easily fixed by you. You might have to take the top off.
Jan 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer displays FL code Hi Where do I find the model number for my machine. It's a Kenmore Elite Calypso Motion Top Loader? I am getting an error code of FL and need to trouble shoot problem but, I have...
I GOT THIS OFF THE MANUAL, HOPE THIS HELPS.
"FL' (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the over fill switch is reset or power is discontinued to the
unit. Press STOP/CANCEL to clear the display. Shut off the
water faucets to the inlet hoses if water continues to flow.
Nov 08, 2007 | Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
111 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
