Question about 3Com Computers & Internet
I want to use 4color code to terminate to the rj45
    Novelist:
  • 121 Answers
Hello Patrick,
My name is ArmyMason, are you looking for a wireing diagram for RJ45. if so its Red/White, Red, Green/White, Blue, Blue/White, Green, Brown/White, Brown. Make sure the wiring is pushed all the way down into the connector before crimping.
http://www.megalink.net/~turnertech/RJ_45.jpg
Thanks,
ArmyMason
Posted on Feb 23, 2009
How do you connect to a terminal with avocent dsr8035
You should have a DB9 to RJ45 converter in the box. This converter is used to change from DB9 serial to RJ45, which is the port on the DSR that is used to connect to the serial console.
Should you do not have such connector, call Avocent Tech Support, they will help you to get that converter.
The NullModem Cable might also be requiered
Also remember:
9600
8
none
none
Apr 23, 2014 | Avocent DSR8035 KVM over IP Switch KVM...
Need driver for cisco rj45 to d9
You don´t need a driver. You need a serial port on your PC/laptop and a terminal-software, such as Hyperterminal. Do not forget to set the terminal-speed to 9600 (this is standard on Cisco-routers).
hth, Karl
Feb 14, 2013 | Cisco Compatible DB9 to RJ45 Console...
Not connect from console port
Verify that the correct settings and cable/connectors (rollover cable, correct COM port specified) are being used when establishing the console connection.
From the manual-
3.9.2 Connecting to an IBM or Compatible Device
To connect an IBM PC or compatible device, running the VT terminal emulation, to an
Enterasys Networks module Console port (Figure 3-20), proceed as follows:
1. Connect the RJ45 connector at one end of the cable (not supplied) to the Console port on the
Enterasys Networks module.
Connecting to Console Port for Local Management
Hardware Installation 3-31
2. Plug the RJ45 connector at the other end of the cable into the RJ45-to-DB9 adapter (supplied
with the device).
3. Connect the RJ45-to-DB9 adapter to the communications port on the PC.
4. Turn on the PC and configure your VT emulation package with the following parameters:
Parameter Setting
Mode: 7 Bit Control
Transmit: Transmit=9600
Bits Parity: 8 Bits, No Parity
Stop Bit: 1 Stop Bit
source: Install Guide for Enterasys 1H582-25 / 1H582-51 (http://www.retrevo.com/support/Enterasys-1H582-51-Switches-manual/id/2785dj098/t/2/)
Jun 22, 2011 | Enterasys MATRIX E1 (1h582-51-g)...
Need driver for CISCO DB9 TO RJ45 6FT CABLE 72-3383-0 for my notebook
If I am understanding correctly, you are using a serial to ethernet cable. The serial cable plugs into your laptop and the ethernet end plugs into the CONSOLE port on the Cisco.
From here you use a terminal emulation program like "Hyperterminal" to connect via the serial port. As long as your serial port is installed, no other drivers are necessary.
May 02, 2011 | Cisco Compatible DB9 to RJ45 Console...
Need to know how to wire a RJ45 Cate 5E wall socket. Trying to understand the wiring diagrams which are numbered 1 to 8 where as socket is configured as A and B in two rows of 4. Fittings I have are Krone...
If you place the socket in front of you, the terminals from on the left side from bottom to top will use the white/blue, blue, white/brown, brown wires and the terminals on the right side would use the green, white/green, orange, white/orange wires from bottom to top.
A and B are used just to differentiate from the T568A and T568B schemes. So if you don't need cross-over configurations, you can just use the same on both ends. The method above is for the B scheme.
Apr 30, 2011 | Philips RJ45 Female to Female Ethernet...
How to attach cat 6 cable to rj-45 jack
Good day..You should have knowledge about the color coding for cat-6 cable termination. Its called "termination" computer term.if it is a straight-throw use this color code:RJ45 must face at you when you arrange the wire colors..WOrange,Orange,WGreen,Blue,WBlue,Green, WBrown,Brown..(W=White). Then use a Crimping Tool to crimp it.Flat that twisted wires before you insert to rj45. Hope you are okey with this. Ask me if problems occured. Mastergani
Mar 17, 2010 | Computers & Internet
No connect to rs232 serial, ports PC
df1c50d.png This is for a newbridge or alcatel 3624 mainstreet channelbank - do not use the modem side, only use the terminal side - all is needed is Rx, Tx, and ground - if looking from the "window" side of rj45 connector, or pins-side up on rj45 socket.
Aug 18, 2009 | Alcatel Newbridge MainStreet 3600...
I need the pinout for the serial cable? RJ45 to DB9
f211598.png This is for a newbridge or alcatel 3624 mainstreet channelbank - do not use the modem side, only use the terminal side - all is needed is Rx, Tx, and ground - if looking from the "window" side of rj45 connector, or pins-side up on rj45 socket.
Aug 03, 2009 | Alcatel Newbridge MainStreet 3612...
Pinout rs232 I want to print directly form handheld falcon 310 using rj45 jack
The pinout for that type of device is most likely in the yost format. It is a standard used with most pos equipment. You can get a diagram here : http://www.lammertbies.nl/comm/cable/yost-serial-rj45.html
Hope this helps
Jay
Jun 29, 2009 | PSC Falcon 310 Portable Terminal
How to make RJ11 to RJ45 cable
pls send me your email adddress we are send the doc file of cable crimping proses with color code ......... E-Mail:jilpeshpatel@compudesk.in
Mar 30, 2009 | Computers & Internet
Computers & Internet Logo
120 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
