Question about Frigidaire FEQ1442ES Electric Dryer
Squealing dryer I have a Frigidaire dryer model FEQ1442CES0, and it squeals.
  • 883 Answers
SOURCE: squealing!!
the noise is coming from the drum axle bushing that allows the drum to spin on it's axle. Gain access to the rear of machine and apply some high temperature grease that is found in automotive parts stores to the bushing. run it while observing spinning drum at rear for any possible other problem where squeal can be found such as drum slides.
Posted on Dec 26, 2007
SOURCE: LOUD SQUEALING NOISE
Most likely the rear drum bearing is worn. There's a "ball and socket" arrangement that supports the drum at the rear and a repair kit for it. Part #5303281153. Should run around $25.fe7bd93.jpg
Posted on Dec 28, 2007
SOURCE: Squeaky Dryer
Master_Tech:
I have the same model number and the same squeaky problem. I could use the same fix that you gave bebowser.
thanks
skuterbum@yahoo.com
Posted on Apr 16, 2008
SOURCE: GE Dryer model#DWSR483EA1WW
you need to replace the inner plastic "shell" and the teflon pieces that the drum rides on. The dryer drum has eaten thru the teflon slides, and has probably started eating the shell away also.
About $40 in parts available on line will fix the problem.
Posted on Jun 21, 2008
  • 1028 Answers
SOURCE: Frigidaire LEQ332DSO Squealing Noise
sounds like rear bearing is dry you will need to remove drum to get to it pop clips in top and raise 2 phillips scews 1 in each side remove front remove belt from drum lift drum up in rear and remove ck to make sure plastic bearing is not worn down to metal bracket if it is it will need to be replaced
Posted on Jul 08, 2008
Why does my frigidaire leq332ds0 sound like it's overloaded when it's not?
Good Morning Nikki,
I understand your Frigidaire dryer, model# LEQ332DS0, is squealing like it's overloaded, even after replacing the belt. There could be a number of possibilities that could be causing your appliance to squeal. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your dryer and determine what is causing your appliance to squeal. Hope this is helpful.
-Best Regards-
WP
May 28, 2014 | Frigidaire Dryers
Loud squeal from Frigidaire electric dryer, tumbler slipping, then smoke and blown breaker
Sounds like the bearing on the motor, had this problem with my two at the same time replaced the bearing and they are both ok now.
also check the back bearing on the machine usually hidden by a plastic cover thats where the squealing comes from they are easy to replace and don't cost much all it is ,is a bit of brass which doesn't last long.
hope this helps.
puggy
Jan 13, 2014 | Frigidaire Dryers
My frigidaire combo unit the dryer is squealing?
the felt that rounds the drum that touches the front panel could also be worn and you can have a situation where metal is rubbing
Jun 27, 2012 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire model FDE336RES2 makes a squealing noise and won't turn with a full load in dryer.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 03, 2011 | Frigidaire Dryers
My dryer is squealing very loud when it is on.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Apr 07, 2010 | Frigidaire Dryers
Dryer squealing
probably some was in a pocket and is now jammed in the seal you will need to take the whole cas(sheet metal ) off of the unit to access the tumbler seal
Jan 06, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
Squealing dryer
The dryer drum support on the rear of the drum is worn and must be replaced.
It is a ball and cup design. It is worn out.
Feb 21, 2009 | Frigidaire GLER341A Electric Dryer
Dec 27, 2007 | Frigidaire GLER341A Electric Dryer
Squealing!!
Dec 26, 2007 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire FEQ1442ES Electric Dryer Logo
185 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
