Question about Sony PlayStation Portable (PSP) Console
Screen problems but working properly
My sons PSP has vertical and horizontal lines through out the screen when it is turned on. However the games still operates properly.
  • Anonymous Feb 23, 2009
    Sony PSP has vertical lines when turned on but games still play normally.
  • 112 Answers
It is nothing to worry the screen is just partially damaged.He must have put it down.Your lucky it is only partially damaged.Tell your son not to put it down again or do something that would damage the console.
Posted on Jan 27, 2010
My son has dropped his PSP from his bed to the laminate floor, now it starts but the screen shows veritcal lines and a in the top right hand cormer the game can be seen. It this PSP dead or can it be...
There are two possible problems with the PSP.
The first is that the connection between the wire connecting the screen and the mother board has become loose. Vertical lines are often signs that the screen is not receiving all the data required to fill every line.
More likely, the lines on the screen were severely damaged from the drop, rendering them inactive. This means that you will require a new screen.
Because of the purchase date, your product is still under Sony's initial warranty. This means you can request a repair or a new device. I have included a link to the "Service Request Page" to speed things along for you. Note that there is a $50 fee for replacing and diagnosing a problem with a device. While it may seem costly, due to the early age of the device, it may be best to go through Sony as not to void the warranty.
Sony Support Page https://service1.us.playstation.com/rma.htm?_flowExecutionKey=_c82CAAC8E-A2F1-D305-5FA5-9DB224B922D9_k54341030-70C9-01DA-D990-B296489121F3
Mar 13, 2011 | Sony PlayStation Portable (PSP) Console
Hi, i recently replaced my sons cracked lcd psp screen with a brand new sony screen. when i turned it on it was fine, but then when he put it on snooze mode and then turned it back on, the screen came up...
I'm not sure exactly what your deal is, but i have a similar problem. my screen was cracked, i replaced it, and when i turn it on or off, the screen goes all white. I'm guessing this is somewhat along the lines of normal. but if you still think something is wrong, call sony, and they should tell you what the deal is.
Jan 10, 2011 | Sony PlayStation Portable (PSP) Console
There is a line down the center of the screen
whether the line-shaped vertical or horizontal? if it appears a horizontal line on your side, it signifies the vertical rays do not exit the screen or your TV vertical part is not working. damage can be caused by IC Vertical, or in the vertical deflection coil yoke.dan if a line that appears is from top to bottom that indicates the horizontal section is not working, usually there is a problem of the deflection yoke is not connected or defective.
Jul 11, 2010 | Televison & Video
Screen is red with white horizontal lines when game is inserted, took battery out and in also game still does not work , sony psp
your psp is damaged !! try to hack it..! NOTE hack will only work this versions
psp1000
psp1001
psp2000
psp2001
BUT IT WILL not WORK FOR 3000 or 3001 look on the bottom of the psp it should say psp and then your current version heres a link on how to hack it.!! http://www.youtube.com/watch?v=nL7ToOp_nTY&videos=G1BagnnETiI
Jul 23, 2010 | Sony PlayStation Portable (PSP) Console
My sons psp comes on but there is only green wavy lines on screen.
try rebooting it and if your sons psp had been fallen anywhere when he was playing then there maybe a chance hardware or battery small chip was bolted if this doesnt work go anfd look inn sony showroom and show them this problem
Dec 25, 2009 | Sony PlayStation Portable (PSP) Console
Lines on screen
the wires inside the psp might be shorting or frayed. You will more than likely have to contact sony to get a new psp.
Jun 30, 2009 | Sony PSP-3000 Silver Console
Psp horizontal line bottom screen
Sounds to me more like an LCD display issue
May 04, 2009 | Sony PlayStation Portable (PSP) Console
Top screen has horizontal and vertical lines
The only solution is to replace this top screen.
Buy.com has the top screen for $20 Bucks!
Search Top Screen Replacement Display on there.. Hopes this helps.
Apr 14, 2009 | Nintendo DS Lite Console
Coloured lines all over screen
The colored line you saw was the actual screen pressing against the back of the psp......Example would be if you put your thumb and pressed on a laptop's screen. It doesnt work now because the screen is now cracked and you can either order a replacment screen on amazon for about 50 bucks or buy a new system
Dec 31, 2008 | Sony PlayStation Portable (PSP) Console
PSP suddenly has vertical lines no image
For your first PSP: there is a loose conection of LCD Screen with the motherboard and the solution is as follow: You can open the PSP and just lift the LCD Screen up be sure before lifting LCD Screen one thin Switch panel of micro buttons Home,VOL,select etc, you have to remove this first then only it is possible to lift the LCD Screen and after that you check that broad connection strip which is fixed with the motherboard socket you remove it this strip and refixed it again,your problem should get solved if suppose your LCD Screen is not broken.
Sep 02, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
119 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
