Question about Frigidaire ATF6000ES Front Load Washer
How do you change the control motor board on a frigidare front loading washing machine
  • 50 Answers
Access is from the back of the machine. Motor control is on the left side tucked in beside the motor.
Posted on Feb 26, 2009
E45 error on frigidare affinity washer
Hello efrendepaz - That is correct, typically error code E45 indicates that the washer has detected a Main Control Board issue. The control board will need replacing and regrettably this is not simple DIY job. I would strongly recommend connecting with a professional to move forward accurately.
Mar 13, 2013 | Frigidaire Affinity ATF7000E Front Load...
My frigidare (ATF6700FS1) reads error 23 it will not spin
Failure of the drain pump relay or associated circuit. IF the board is examined for any loose joints to the drain pump and confirmed then the solution is a replacement of the control board.
Jan 17, 2013 | Frigidaire ATF6000ES Front Load Washer
I have a problem with a motor control board for a wascomat washer, made by frigidare. the motor control board is part # 134149200. the thermister on the board tdr1 gets so hot it melts the solder and falls...
The NTC thermistor is a current limit device. If there is too greater load, (motor getting tight/bearing tight) too much current will pass and it will get hot.
Some have a relay that sit a contact across the NTC to stop this from happening and if the relay is faulty, it will get too hot.
Jun 13, 2017 | Washing Machines
Washer won't start, lights all work except top one, door lock. I changed the locking device but still the same. On the trouble list the next step should be to change the control board??? The model is...
The board would be the likely problem if the switch is good. To double check the switch check it for ohms, it should be around 1500 ohms no lower than 1400 if it is the switch is bad if it checks good replace the main control. Here is a link that should help
Sep 08, 2010 | Frigidaire ATF6000ES Front Load Washer
ATF6000FS1 Frigidare front load washer The washer doesn't seem to wash the clothes well. Often, i find some clothes not wet and even the wet clothes don't come out well washed.
Suggests that motor not not tuning heavy loads due to worn belt or motor.. you could check if Carbon Brushes are worn if they are fitted some motors dont use them..good luck
Nov 16, 2009 | Frigidaire ATF6000ES Front Load Washer
clean the pump and also make sure that the pump motor is powered during draining
May 30, 2009 | Frigidaire GSTF1670A Front Load Washer
Frigidare front loader won't spin during wash cycle
Does the washer go throught he whole cycle and just not spin? Or does it just shut down? If it goes the the whole cycle, You either have a bad door switch or a bad control board. Replace the door switch first. Then the control board 2nd. Door switch is a very common problem with these washer.
Feb 10, 2009 | Frigidaire GLTF2940ES Front Load Washer
Will not extract on spin cycle
After oheming motor control board as stated in the service manual. Tracing the 6 pin lead wires from the control board to the motor plug. I found that one of the pin on motor plug was not making proper connection. I used a screw driver to pry the pin open so it made a better connection. Tried the washer and so far it has been working 7 washes.
Mar 27, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidare affinity front load washer
is thse the digital panel if so the control board needs replaced
Nov 10, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
461 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
