Question about LG DLE2532W Electric Dryer
Heater element-how do you change?
How do you change the heater element in a LG DLE2532W dryer? Where is the heating element located?
  • Anonymous Mar 27, 2014
    where do I find information on how to replace the heating element for my LG dryer model number dle2301r
  • 40 Answers
Take puttyknife put between top and front panels about two to three inches from sides one at a time push in to release tab top will flip up two screws at top front corners pull front panel toward you unplug door switch and remove front panel then take four screws from roller and duct panel and remove from latches and unplug conector underneath set roller panel aside remove belt from will walk you thrugh the rest
Posted on Feb 23, 2009
Change heating element in LG dryer
remove top then remove front and the element is in the lower right corner
Apr 20, 2014 | LG DLE2532W Electric Dryer
How do i get to the heating element in a lg dle2532w dryer
Check your manual. You can download it here if you can't find your.LG DLE2532W Dryer Owner's Manual
FileName: l0310453.pdf
Jan 29, 2011 | Dryers
I have an LG DLE2532W dryer. It suddenly stopped putting out heat. I've heard that there's a heat regulator switch that can trip if the unit overheats located underneath the barrel. What's the easiest...
You r correct. Take top off. Take control unit off. Take front off. Search how to videos online, YouTube,,
Jun 05, 2017 | LG DLE2532W Electric Dryer
Where do i locate the heating element on my lg dryer
no fuse unless an electronic fuse on control board, check your element continuity, then the hi-limit switch then any cycling switches for proper continuity and operation
Aug 24, 2009 | LG DLE2532W Electric Dryer
Gibson electric dryer doesnt heat up
you may have shorted you thermal fuse. or the overload that is attached to the element housing. Good luck.
Apr 13, 2009 | LG DLE2532W Electric Dryer
Sounds like the heater element is bad that is the main cause for them not to heat up . Their should be a cover on the back that comes off and you can get to the heater element after removing it .
Feb 23, 2009 | LG DLE2532W Electric Dryer
Dryer not heating
skjessie the first thing I always advise is to turn the breakers off then back on. Electric dryers use 240 volts for the heating element only. The motor is 120 volts. If the dryer still isn't heating, then you may have a bad heater, tripped thermal limiter, or bad control unit.
Feb 01, 2008 | LG DLE2532W Electric Dryer
It could be a defective heating element or thermostat. Open the service panel and check for 115/220V on the heating element tags. If you can read the 115/220V, you should replae the element. In case you can't read it - the thermostat should be replaced. Good luck!
Sep 10, 2007 | LG DLE2532W Electric Dryer
LG DLE2532W Electric Dryer Logo
461 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Dryer Expert? Answer questions, earn points and help others
