Cars & Trucks Logo
A
Anonymous Posted on Mar 10, 2013
Can you use 5w20 instead of 5w30 engine oil when they reccomend 5w30
Dan Alpert
Level 1:
New Friend:
  • Contributor 50 Answers
  • Posted on Feb 18, 2014
Dan Alpert
Contributor
Level 1:
New Friend:
Answers
50
Questions
0
Helped
13497
Points
75
Use only the oil weight on the oil cap or owners manual if the cap does not list the oil weight. Most older vehicles called for eather 10w30 or 5w30 depending on the ambient temp. In the past 10 or so years, manufacturers updated engines for better fuel efficiency by tightening tolerances in the engines, thereby needing a lighter oil weight to provide sufficient lubrication for the parts So manufacturers started requiring 5w20 oil in their engines. I work as an Auto Care Technician at Walmart, and we will NOT do an oil change for any weight other than the recommended weight by the manufacturer. If it calls for 5w20, we use 5w20, regardless of what the owner wants. This is to avoid any possible engine oil related problems. People will blame someone else if they have a warranty issue the dealer refuses to honor for whatever reason, and it would go back to the last place the vehicle had the oil changed at. So therefore at Walmart, we follow the manufacturers recommended oil weight for all oil changes.
1 Related Answer
Anonymous
  • 819 Answers
  • Posted on Nov 13, 2009
SOURCE: can i use 5w30 instead of 5w20 oil on a 2006
you can but not recommended. the reason for the thinner oil is the tolerances in the bearing races on these engines are very tight, requiring thinner oil. 5w30 is ok for sure if you are going synthetic.
Testimonial: "thank you very much. ran across some synthetic oil .. cant complain it was free.."
1helpful
What is the best oil for a 95 F250 5.8L. 5w20 or 5w30
5w20 is too light for and engine that old 10w 20 or 30 would be minimum viscosity in really cold weather ( 0 c) or normal ambient temp 15w 30 grade
1helpful
2answers
Can I use a synthetic 5w20 in my 2008 Suzuki Forenzs? I have always used 5w30.
If it calls for 5W30, use 5W30 only. The weight of the motor oil is very important for proper lubrication. It does not matter if synthetic or not, as long as you use the exact motor oil that is specified in your owners manual. I do not recommend using 5W20 motor oil. Never !!!
5w20 or 5w30
Unless your in 0'F or colder weather, you'll be fine.
Nissan quest
More thanlikely it uses 5w30. Use of 5w20 was not intruduced until newer cars of today came out because of the decreased tollerrencles between engine components whic calls for a lower visocoty oil. Most engines in the 90'2 used either 10w30 or 5w30. To know for sure you can always check the owners manual from the car or it should also be licten on the tag under the hood or tag on radiarior cross brace. I would bet on 5w30 as correct oil
2helpful
Silly question really..... where do you pour the oil into on 1989 ford fiesta? Also which oil do you use?
the cap ditectly on top of the engine that says engine oil. 5w20 or 5w30 will work fine
What is the recommended engine oil
You need to replace the oil with 5w30 engine oil.The book may want 5w20 but that is during the heat of the summer only,you will be fine with the 5w30,year round it is a good viscosity oil to use.
What is proper oil for 2002 Vue 6 cyl? 5W30 or
5w 30,,,,,only the honda 3.5 in the newer vue took 5w20
2helpful
2answers
Can i use 5w30 instead of 5w20 oil on a 2006
Engin oil
The proper oil for any car, depend of the mileage, temperature conditions , altitude condition.
temperature below 40 Farenheit. recomeded oil is 0w20.
Some manufactures recomended use 5w20 in all conditions. and miles.
More than 40 f. 5w30 to 20w50,
If you car is in 0 miles to 30,000 miles 5w30
30k to 50k 10w30
50k to 90k 10w40
90k and up 20w50
This is just a recomended reference or table.
always consult with your owners manual.
Or manufacters spec.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
