Question about Microsoft Windows Server Standard 2003 for PC
I DONT KNOW HW TO CONFIGURE THE IP ADDRESS IN DOS MODE SO PLZ .HELP ME...AND GRAND ME THE CODE OF CONFIGURING SYSTEMS .. THANKING U IN ADVANCE SINCERELY FASMIN
    President:
  • 623 Answers
You can use the netsh command to configure Ip adresses.
1. IP via DHCP:
netsh set address name="MyLocalAreaConnection" source=dhcp
2. static IP:
netsh set address name="MyLocal AreaConnection" source=static addr=192.168.1.61 mask=255.255.255.0 gateway=192.168.1.1
- no line breaks in the commands
- change names and numbers to your needs
- check on mistyping and spaces between the commands
Posted on Feb 23, 2009
Can the management IP address of an ONT be configured?
ONT management IP addresses are classified as LAN-side management IP addresses and WAN-side IP addresses.
· The LAN-side management IP address can be configured. To do so, choose LAN > LAN Host Configuration from the main menu on the web page.
· The WAN-side management IP address is based on WAN port configurations.
§ If the WAN port statically obtains an IP address, the WAN-side management IP address can be configured. Ensure that the configured management IP address can communicate with the upper-layer device.
§ If the WAN port obtains an IP address in DHCP or PPPoE mode, the WAN-side management IP address can only be obtained from the DHCP server.
May 16, 2016 | Computers & Internet
Tip
How to configure a Router?
How to determine the WAN configuration or Interntet configuration of a SOHO Router?
1. Connect the computer to the Modem via Ethernet cable. Make sure you are able to going online 2. After confirming you are online. Go to Start->Run. Type "cmd" on the Run window. 3. Type "ipconfig" on the command prompt or Black window or DOS window 4. You will be getting IP address,Subnet Mask and Default Gateway
There are 4 possibilities of IP address you can get
i)Public IP address under PPP adapter. -Router has to be configured in PPPoE mode to get a WAN IP. This will require a Username and Password from ISP ii) Public IP address under PPP adapter and Private IP address under Ethernet adapter -Router has to be configured in PPPoE mode to get a WAN IP. This will require a Username and Password from ISP iii)Public IP address under Ethernet adapter -Router has to be configured in Dynamic IP or DHCP mode to get a WAN IP -If it is still not getting a WAN IP address. * Click Mac clone on the router's WAN configuration * Power-cycle modem and Router. iv)Just a Private IP address under Ethernet adapter -Router has to be configured in Dynamic IP or DHCP mode to get a WAN IP -If it is still not getting a WAN IP address. * Power-cycle Modem and router.
After determining the WAN mode, it is time to configure the Router
1. Connect the Modem to the WAN port of the router. Connect the computer to the LAN port 2. Go to Start->Run. Type "cmd" on the Run window. 3. Type "ipconfig" on the command prompt or Black window or DOS window 4. You will be getting IP address,Subnet Mask and Default Gateway. The Default Gateway will the IP address of your router 5. Open a Web browser and type http://192.168.1.1(where this is the default IP of the router. This will be different from each manufacturer) on the address bar. 6. Go to WAN settings or Internet settings and select the options based on the above mentioned possibilities
on Aug 26, 2010 | Computers & Internet
How to change the server aol to my google chrome on start up
Dynamic host configuration protocol (DHCP) is a way to configure IP addresses and TCP/IP settings throughout your network.
The DHCP service is run on a machine with a static IP address so that the computers on the network can find it for automated configurations.
Setting the IP address on a Windows 2003 server is accomplished through the network configuration settings in Control Panel.
Click the Windows "Start" button and select "Control Panel." Double-click "Network Connections." In this section, double-click "LAN Connection."
This opens the configuration tool to set the IP address of the server.
Select "TCP/IP" from the list of configured network applications and click the "Properties" button. This opens a new configuration window.
Select "Use the following IP address" to set a static IP for the server.
Enter the IP address chosen for the server in the first textbox that is activated.
Enter the subnet mask and default gateway for the server.
The default gateway is usually the router on the local network or the DSL or cable modem on a small, home network.
Enter the DNS server address.
The DNS servers are separate servers on the network.
For small, home networks, the DNS server is provided by your service provider.
Click the "Ok" button to save the settings. Click "Ok" again at the general LAN properties window.
Renew settings on local computers. Computers that use the DHCP server for configuration need to be rebooted.
You can also use the DOS command prompt to renew settings.
The "ipconfig -renew" command refreshes the settings on client computers on the network.
or for home page browser
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Click on the tools at the bottom of the drop down list will be internet options or
Click start control panel internet options you will see a home page box To Create Page Tabs type
each adress on its own line (type in google.com) or your preferred home page and browser
below that will be change search defaults click on settings you will see all search Providers
Toolbar extensions and Accelerators you have
have if dont need any of them you can disable or remove them
Click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details
Hope this helps
Dec 29, 2012 | Google Chrome
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
Forget IP Address and configuration ...
to verify the ip address click start run and type in cmd then click ok then it will go into the dos mode in that page type ipconfig /all you will see all the ip adress
May 01, 2011 | 3Com 4500 24-Port Ethernet Switch
My Black Armor NAS keep changing its IP address and can't be accessed most of the time on the network. Hw can i fix this
Configure your network's DHCP-server to *ALWAYS* give the *SAME* IP-address to the NAS -- use the (unique) MAC-address of the NAS's network-adapter to assign a "static" or "fixed" IP-address to the NAS.
Jul 27, 2010 | Computers & Internet
I dont know crouter configuration
Hai,
Look at your computer's IP configuration. Go to Network and Dial-up Connections, RIGHT CLICK on your network and pick PROPERTIES. Click on the Internet TCP/IP protocol, then click on the PROPERTIES button. Make sure that your settings are OBTAIN IP ADDRESS AUTOMATICALLY.
Then get into your status screen and look at the GATEWAY address. Is that 192.168.0.1 ?
(If you are using Windows 95/98/ME, then go to RUN and go to WINIPCFG)
You can also use the COMMAND PROMPT and type IPCONFIG and it will show the Gateway address. If the Gateway address is slightly different, then try to get into it at that address.
Also from the COMMAND PROMPT, (or MS-DOS window) you can use the PING command. Just type PING 192.168.0.1. If your router responds, you might be OK.
Look at the lights on your ethernet card. Is it GREEN, or does it show YELLOW.
Try rebooting your computer and using PING again.
Then the problem presist it's possible that this Router is NO GOOD.
Hope this Helped!
Aug 27, 2009 | Computers & Internet
I have Kyocera FS1010 printer and previosly it was configured with one IP, so I accessed with that through IE and resetted all to change IP add. Now it is showing that 0.0.0.0 only and I am unable...
you can configure it but its too confused the way to do it, you u have to play with the arrows to configure the ip address. let me know where you located or if u have any email address so i can walk you through.
Best Regards
Mar 19, 2009 | Kyocera Mita FS 1010 Laser Printer
Configuring nbg334w router
To configure the wireless router it is recommended the it is connected directly to router.
Please follow these steps to fix your issue
1. Reset the router using reset button on the back of the NBG334W router
2. Configure or change the laptop ehternet adaptor setting to "Obtain IP address automatically.
3 connect laptop and router using ethernet cable. check the ip address using ipconfig command in DOS prompt. If IP address is 0.0.0.0 or 169.X..X..X run command
ipconfig /release
ipconfig/ renew
best way restart the computer
4. if you still have issue in getting ip address double check ethernet cable and try reseting the router again.
5. Still problem persist install new firmware on the router. you can download router firmware from
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906164737&ModelIndexflags=0,420070320142921
Please vote if this information is helpful in resolving your issue
Dec 27, 2008 | Zyxel Prestige 334 Router
How can i configure the Ip address and dns in dos mode
netsh [-a AliasFile] [-c Context] [-r RemoteMachine] [Command | -f ScriptFile]
? Displays a list of commands. add Adds a configuration entry to a list of entries.
add helper Installs a helper DLL. delete Deletes a configuration entry from a list of entries.
delete helper Deletes a helper DLL. dump Displays a configuration script. exec Runs a script file. help Displays a list of commands. interface Changes to the `interface' context.
ip Changes the 'interface ip' context. ras Changes to the `ras' context.
aaaa Changes to the `ras aaaa' context. appletalk Changes to the `ras appletalk' context. ip Changes the 'ras ip' context. ipx Changes to the `ras ipx' context. netbeui Changes to the `ras netbeui' context. routing Changes to the `routing' context.
ip Change to the 'routing ip' context. ipx Changes to the `routing ipx' context. set Updates configuration settings.
machine Sets the current machine on which to operate. show Displays information.
show alias Lists all defined aliases. show helper Lists all the top-level helpers.
Available commands after you have entered the netsh command (typing netsh at the prompt and pressing enter).
.. Goes up one context level. ? Displays a list of commands. abort Discards changes made while in offline mode. add Adds a configuration entry to a list of entries. alias Adds an alias. bye Exits the program. commit Commits changes made while in offline mode. delete Deletes a configuration entry from a list of entries. dump Displays a configuration script. exec Runs a script file. exit Exits the program. help Displays a list of commands. interface Changes to the `interface' context. offline Sets the current mode to offline. online Sets the current mode to online. popd Pops a context from the stack. pushd Pushes current context on stack. quit Exits the program. ras Changes to the `ras' context. routing Changes to the `routing' context. set Updates configuration settings. show Displays information. unalias Deletes an alias. Examples
netsh Enter the netsh command. netsh dump Dump all the network information as a script to the screen. Can also be sent to a file by doing netsh dump > file.txt . This script can then be executed using the exec command. set address name="Local Area Connection" source=dhcp Set the "Local Area Connection" to DHCP. set address local static 10.0.0.9 255.0.0.0 10.0.0.1 1 Set the local address to Static. netsh interface ip show config View network ip configuration. Below is an example of what may be seen. Configuration for interface "Local Area Connection"
DHCP enabled: Yes
InterfaceMetric: 1
DNS servers configured through DHCP
WINS servers configured through DHCP
May 15, 2008 | Microsoft Windows Server Standard 2003 for...
Microsoft Windows Server Standard 2003 for PC Logo
154 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
