Question about Hitachi 28LD5200 28 in. HDTV-Ready LCD Television
I cannot approach the tv mode and it is not in the menu either
They brought me the tv and it was working perfectly when they took it home only the av input was available ,pc and video are working
can you tell me what to do ,or how to reset
  • gpmvleeuwen Feb 24, 2009
    i am able to approach the adjust mode with the 745 nrs ,and put them back too the default settings,but some i cant change,it says something about pwb ,but after that it wont go into factory setting,still no tv mode,I think I have to upgrade the software,the self test screen says ok behind all the tested nrs,please help me solve this
    Problem Solver:
  • 15 Answers
Let stalk connections. How is the TV hooked up?
Posted on Feb 23, 2009
HDMI input says "mode not compatible"
If your Playstation is putting out the signal in 1080p then try changing it to 1080i and see if that works. Not all TVs are compatible with 1080p.
Aug 02, 2012 | Samsung Lnt4042hx/xaa
Plasma tv/home theater
Is your Panasonic set to monitor the HDMI input? Just like selecting a mode input on the Tv you must also select the mode input on the surround system.
Bill
Dec 07, 2007 | Televison & Video
I've got a Sony STR-K880 Cinema surround system and the remote control won't work it anymore! The only thing it will do is turn the system off when I push the'AV I-O' button and the &#
I had the same problem. Found the fix in this document
STR-K880 service manual
On the amp, while powered off:
"While depressing the INPUT MODE button, press the POWER button to turn on the main power."
You may need to do this more than once.
This switches command mode between AV1 and AV2.
Jul 08, 2012 | Sony Audio Players & Recorders
How to tune thomson tv 14MG135
first is to get it from AV mode which suggests it is on one of the rear audio/video inputs.
If no source or Tv video button on remote look in the menu--once off the AV input it should be able to tune.
Direct hookup with cable or what?
May 02, 2012 | Thomson 14MG135 14" TV
My tv is stuck on the video imput for my Wii and none of the front panel buttons work
Try to see if any of these four methods will work.
Sanyo TVs
1. Press VIDEO MODE or TV/VIDEO button in front panel or on remote
2. Press MENU , choose FEATURE SETUP, then choose either VIDEO MODE or TV/AV, select VIDEO or AV
3. Press TV/AV or INPUT SELECT on remote
4. Press SETUP, choose TV/AV, switch to AV
Sep 25, 2011 | Panasonic TH-42PX60U Television
I can't get my freeview box (Philips DTR 2010 to work. Had it working in my flat earlier today & have brought it home for wkend where it's wrkd before. All plugged in but the TV stays 'snowy' when I...
Select the AV input manually via the TV remote. The scart lead may not be switching the TV automatically (if you have two scarts on the Freeview box, then try the other scart socket).
Feb 18, 2011 | Televison & Video
Ive got a urc-3920 One for all remote . All functions works perfect , but the AV button mutes the TV. Cant change to AV with remote.I've pressed all buttons on the remote to see if it has not been switched...
i have a goodmans tv GTV69RFDT and i have brought a one for all remote urc-3920-urc 3940. All the codes dont work, i have tried the seach method and still nothing is working properly, i get the number buttons and volume but no up channel and down or menu button. Need help
Dan
Nov 03, 2010 | One For All URC-3021 Remote Control
T.V. won't allow me to adjust color and sound...
Chepe_77,
You are absolutely correct. The reason why you cannot change your audio and video settings are due to the fact that you are in "Dynamic Fixed". Which is one of your many av modes. Av modes are different preset color settings and dynamic fixed is the only one that will lock your settings. Best Buy set it that way so that people could not just come by and alter the settings on the unit. AV modes are on all sharp lcd products and even though you have the wrong remote you should have an av mode button on the remote that came with it. Try pressing the av mode button and see what happens. When you press the av mode button, you will see your av modes change at the bottom of the screen. However, the issue still remains that you have the wrong remote. So there is a chance that you may press the av mode button on the remote that you have, but it still will may not work ONLY because you have the wrong remote. If the remote you have does not work, I GUARANTEE that pressing the av mode button on the proper remote will take care of that. If you dont want to purchase the remote from sharp, www.partstore.com is a good place. Good luck to you
Apr 12, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Finding AV channel without a remote control
Hi, I brought a EmersonTV model EWF2004 without a remote control and I can't find the AV channel to watch DVD's I hope you can help me
Sep 01, 2008 | Emerson EWF2004 20" TV
Hitachi 28LD5200 28 in. HDTV-Ready LCD Television Logo
55 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
