Question about Garden
I've cleaned and replaced to gas in my mower it
I've cleaned carburator and replaced the gas in my mower it starts easily and runs but it throttles up and down,continuisly, when it gets near empty it seems to run like it should, help!
  • 4 Answers
SOURCE: I have a murray 22 inch lawn mower with a 4.0 hp briggs and
Change your air filter, spark plug, fuel filter, and oil. Then make sure the gas is fresh. Gas starts going bad after a month. Spray carb cleaner in hole underneith the fuel filter. Oh yea dont put more than 20oz of oil in it.
Posted on Mar 27, 2009
  • 82 Answers
SOURCE: Mower not running at set speed, choking
you should have an air/fuel mixture screw on the carb somewhere. Start the engine and turn it one way then the other a small amount at a time. One way it will get worse and one way it will get better. Keep turning till it smooths out
Posted on May 09, 2009
  • 246 Answers
SOURCE: yard man gas push mower starts but wont stay running
Hello jusapup68:
>>Did you Soak the Carburetor when you Cleaned it?
>>If No, then the Carburetor can Still be the Problem.
>>Does the Engine Start and Quit if you Pour a Small Amount (1/4 oz of Gas into the Carburetor and Try to Start the Engine?
>>If Yes, then Soak the Carburetor Overnight.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve.
Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace is the Needle Valve.
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>2- .
You can View a Breakdown/IPL of the Mower at this Site Addy, and Select Shop Online Parts and Accessories. Now Select the Model Tab. Select the OEM (MTD) and Enter the Model Numbers. Now Double Click on the Model in the Results Area.
>>Have you Checked the Spark at the Plug?
>>Here is a Basic Instruction File I am in the Process of Making. It will Might Say Mower, but a Snow Thrower/Blower is Powered by the Same Type of Engine, so the Diagnostics are Basically the Same. >>***Here are some Diagnostic Instructions to Do on the Engine to Locate the Cause/Cure for a Hard/Not Starting Engine. This Does Not Include a Problem with the Valves. If I Suspected the Valves are Involved, then a Separate File for the Valves will be in this E-mail. This is a File in the Making, so Any Input is Appreciated.
>>1- Check the Spark. If Not Firing, then Replace the Plug.
>>2- If the Plug is Firing, then First, Pour a Small Amount of Gas (1oz) Into the Carburetor Throat with the Throttle at Full. With the Throttle Still at Full, Try to Start the Engine. If the Engine Starts and Quits, then Make Sure the Gas is Free Flowing to the Carburetor. If the Gas is Free Flowing, then Remove, Disassemble and Soak the Carburetor Overnight in Carburetor Cleaner (I Use Gunk). I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning. You Only have to Remove the Bowl, Float Pin, Float and Needle Valve and Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed. Then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts. Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air. Install New Parts if Required.
>>3- If No Fire at the Plug, then Remove the Coil Shut Off Wire from the Kill Switch at the Engine Stop/Brake Bracket (where the End of the Stop/Brake Cable Attaches at the Engine). Check for Fire. If No Fire, then Remove the Blower Housing and Remove the Ground Wire from the Coil. Check for Fire. If Still No Fire, then the Coil is Bad. *On Some JD Model Mower the Engines Use an Igniter. Remove the Igniter and Coil and have your Local JD Dealer Test them for you.
>>* **On Models with Point Set, the Condenser is Bad and the Point Set and Condenser should be Replaced as a Unit. Make Sure the Point Set Plunger is Fully Extended when Setting the Point Set Gap to .020in.
>>** If there was No Response from the Engine When the Gas was Poured Into the Carburetor Throat and the Plug was Firing, then Check the Compression. If the Compression is Good, the Carburetor has Been Soaked and Cleaned and the Plug is Firing, then Check the Flywheel Key. If the Key is Damaged, then the Plug Firing is Incorrect to the Position of the Piston During the Compression (Power Stroke).
>>*** On the OHV and Some L-Head (Flat Head) Engines there is a Compression Release. The Exhaust Valve Clearance has to be Opened to .020in for the Compression Release Not to Operate; in Order to get a Correct Compression Reading.***
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
jbridger (John)
Posted on May 14, 2009
SOURCE: Troy Bilt model 542(11a-542-q711)has Honda 160cc
I need Gaskets for caboretor
Posted on Sep 08, 2009
  • 7482 Answers
SOURCE: I can crank my murray gas lawn mower 6.5 quantum
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
How do I make my lawn mower run better?
Yes, clean the air filter if it's a foam , washable fliter. If it's not the washable kind , replace it. Also replace the gas filter if there's one on the engine. Buy a can or bottle of carburetor and fuel system cleaner and put it in the gas tank to clean the carburetor.
Jun 10, 2014 | Mtd 22" Yard Machine Push Mower
My 99 buick regal cranks over and starts but has trouble running. If you give it gas to help it through the start up it levels out and runs fine. Fuel pump is good, I've changed spark plugs and wires,
sounds like a stuck open EGR valve to me , take it off of a cool engine and spray some carb cleaner around the seat see if any leaks through to the other side. If it does The valve is bad. Also check out your throttle body for carbon and gumming. W/ engine off spray an appropriate carburator
cleaner into the opening and clean throttle plate and bore with a rag until shiney. put all the air cleaner hoses back together and hold throttle to floor momentarily until engine starts, then rev up half way and release throttle twice quickly, now allow engine to idle idle should be stable and smooth. If not then check for other sources of vaccume leaks.
Apr 18, 2013 | Cars & Trucks
Zero Turn Lawn Mower shakes on full throttle
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 14, 2017 | John Deere EZtrak Z225 Zero-Turn Riding...
2003 CRF150f that I can't get started.
As long as you have spark and compression i would go back to the carb and pull the low speed jet out make sure it is clear and also the passage way its in this is the most common problem if a bike sits for some time the gas tends to gel and the tiny jet will easily clog up make sure its clear or the bike just wot run correctly at all.
Aug 28, 2012 | Honda Motorcycles
6.25 190 cc mower wont stay started
your running out the gas in the carb out you need to rebiuld the carburator probably dirt in the carb from bad gas
Jul 22, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
My mower won't start
try running it with the gas cap loose the vent might be plugged
Apr 13, 2012 | Garden
Will not stay running
You have a fuel delivery problem. Main reasons for this is a dirty or plugged up carburator. If you know what you are doing, clean the carburator. If you let gas set in it for more than a month or so without starting it up, the good ole ethonal in the fuel has gummed up inside the carb. Once you get the carb clean (jets, ports, etc) and it still doesn't run replace the fuel pump. Cheap as heck and easy to install. Both items can be done in less than an hour and cost you about 25 bucks.
May 14, 2010 | Poulan Pro " Pro" Self Propelled Mower
Cub cadet lawn tractor, ran out of gas. After
I would bet that the throttle shaft is worn and has a lot of play in it on the carburator. This is very common. The best bet is to have the carburator worked on by a small engine repair shop, or get a replacement one.
Apr 16, 2010 | Garden
Can't start brisggs & Stratton 21in mower. I
Get some GUMOUT carburator cleaner GAS ADDITIVE. Put about 1/2 TEASPOON in the gas tank and about 1 tablespoon per gallon into your spare gas. The float pin is probably sticking from winter non-use. This will free it ip.
You can also remove the bowl from the carburator and spray everything to immediately dissolve the varnish. Be careful not to lose the pin spring.
Jun 13, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
