Question about Miele M613GSS 800 Watts Convection / Microwave Oven
Sparking roof of my miele M613G microwave
The panel on the roof of my miele M613G microwave has started to spark and burn - is this fixable or will I need a new oven
  • 2 more comments
  • martynlock Feb 24, 2009
    Thank you Philiplys, thats very helpful, I just need to find spare parts for this machine now.
    I spoke with Miele and they didn't really have any clue - especially about the plate that seems to be on the roof of the inside of the microwave.
    They suggested the replacement model M8151 at nearly £500.
    Lets hope the spares are a little cheaper.
    Once again - thanks
    Martyn
  • martynlock Mar 04, 2009
    Hi Philip
    I've tried again and again but Miele will not give out a parts list, however they have sent me an exploded diagram of the machine itself.
    I believe the guy I was speaking with has highlighted what 'may' be needed after repeating your thoughts of what could be wrong with the machine.
    I may just bite the bullet and buy some parts.....
    Thanks for your help, if you would like a copy I can email it to you.
    Kind regards
    Martyn
  • Anonymous Mar 12, 2014
    dirt on glass panel inside miele microwave
    Problem Solver:
  • 11 Answers
I've got a Miele microwave and I had that very same problem. On the top of the cooking chamber there's a round mica insulator. That insulator covers a wave spreader, that is basically a aluminium fan mounted on a teflon spindle. What happens is that the spreader is either bent or loose. As the microwave runs, the spreader gets electrically charged (charged by the microwaves cooking your food) and when in gets too close to the metal chassis, a spark jumps from the spreader to the chassis.
The way to fix it is quite simple: you have to remove the mica insulator by unscrewing some philips-headed screws from the inside of your oven (if they happen to be stuck, just remove the cover of the microwave and WD-40 the nuts where they're screwed on). Then, you'll see the cheap aluminum spreder. Either screw it tight or bend it a bit so that it doesn't touch the chassis at any time or the mica insulator. Put the mica back in, screw it down gently and smile.
Posted on Mar 11, 2009
  • 52 Answers
These ovens are favourite for this, it is something to do with the stirrer blades. the top casing can be removed and replaced
Posted on Feb 23, 2009
  • phillipe lys Feb 25, 2009
    Miele and other microwave manufacturers are very unhelpful, they only want their engineers to carry out the repairs. however they are required to make spares available for 10 years after the last .
    production date.
    you need to keep on to them and request a spare parts list and then request the part from them
    best of luck keep me informed
    Philip
I used lastnite and sparks coming from roof help
sounds like either a new unit or the repair cost and still have an old microwave .
May 09, 2015 | Microwave Ovens
Miele H 4080 Microwave mica diffuser plate
http://www.amazon.com/Amico-Microwave-Repairing-Plates-Sheets/dp/B00880DAB0
Oct 19, 2013 | Miele M613GSS 800 Watts Convection /...
My microwave is about 7 years old and has recently started sparking when I heat things in it. Can it be saved or is it best to buy a new one?
sparking usually relates to i) using metal in the cavity or ii) some burnt food on the roof iii) the waveguide cover 'mica' panel is burning iv) door area enamel has been damaged. After 7 years you may want to bin it and get a new one as they are now so cheap, fixing them is usually more expensive.
Apr 22, 2011 | Dacor DMO24SS Microwave Oven
Sparks when micro turned on. it appears the pannel
Yes if you can find someone to supply it as a spare part. Clean any grease or debris from behind it too. Often there are little plastic rivets that hold it on. You might as well order them too. If it burnt too bad there will be a carbonisation on the panel too which must be cleaned off as it will attract the microwave energy.
Before ordering anything, remove the burnt panel and run the microwave with just a cup of water in it to make sure it still works fine.
Whatever you do, do not open up a microwave oven cabinet, they are very dangerous inside. If you cant remove the panel from within the cooking cavity then leave well alone and get an engineer to look at it.
Aug 04, 2010 | Dacor DMO24SS Microwave Oven
Microwave sparks inside oven in the area of the sealed compartment when it is started
If unit was run for long time with food on walls and not cleaned off, it is possible that the unit was burned in a spot where the food was and if there is metal frame under that part for the finish it will spark. Check closely for burns, if it is sparking due to that problem, junk it. It is a dangerous condition.
Jul 28, 2010 | Daewoo KOG-867T Microwave Oven
I'm getting a flash inside the oven and the plastic on the inside roof has a burn mark. I removed the plastic cover over the micro wave generator and it did not spark. is the oven dying? It is a 1983 0ver...
It looks like the metal part inside the oven is exposed to the high frequency rf waves. this may sound strange but try coating the metal part with fresh paint. remember no metal inside the oven will stand the waves created inside the oven the spark u see is the waves hitting the exposed metal part inside the oven
Oct 13, 2009 | Magic Chef MCD1311ST Microwave Oven
Microwave not turning
Do you still have the owner's manual? They usually have contact information. You can download it here: http://www.miele.co.uk/Resources/OperatingInstructions/M613G.pdf Otherwise, for parts sources try http://www.miele.co.uk/Customer/
Dec 29, 2006 | Miele M613GSS 800 Watts Convection /...
Miele M613GSS 800 Watts Convection / Microwave Oven Logo
1,599 people viewed this question
Top Miele Microwave Ovens Experts
William Miller
William Miller
Ruth summersides
Are you a Miele Microwave Oven Expert? Answer questions, earn points and help others
