Question about Goodman GMS90703BXA Heater
I have a Goodman GMS9/GCS9 Gas-Fired Warm Air furnace and it's no
The Induced Draft Blower starts to run but there is no furnace operation. The Integrated control module diagnostic LED is flashing 3 flashes. The possible causes listed in the manual say:
1. Pressure switch hose blocked, pinched or connected improperly.
(I took of the front cover of the furnace and looked at this rubber Pressure switch hose and it looks fine to me)
2. Blocked flue and/or inlet air pipe, blocked drain system, or weak induced draft blower.
(I went outside and checked the flue and inlet and they both look fine, with no visible blockage. I inspected the drain system that comes out of the side of the furnace and that also looks fine, with no visible problems. The Induced Draft Blower sounds fine when it kicks on too, sounds strong with no audible odd or weird noises eminating from it.
3. Incorrect pressure switch setpoint or malfunctioning switch contacts.
(I don't have any idea how the pressure switch setpoint could be off since I have never adjusted it and I have no idea how to adjust it or what would even be a proper adjustment of it. As far as malfunctioning switch contacts, I don't know why they'd be malfunctioning, the furnace is in a clean dry furnace room with little or no dust and very little moisture. Visibly, all of the contacts look great.
4. Loose or improperly connected wiring.
(I don't know how any of the wiring could be loose or improperly connected because the furnace has run for 3 years with no problems)
This problem all started about 4 weeks ago when the furnace would run, but never for long enough to get the house warmed up to the adjusted thermostat tempurature of 69 degrees. It was keeping the house heated at around 65 degrees at that time. Now it has entirely stopped heating whatsoever, with the blower turning on and then the Integrated control module LED goes from steady on to THREE quick flashes, meaning that there is a problem. The flames never ignite and then the blower eventually turns off. I pulled the drain tubing from the trap to see if any water is being held back. I blew into it and it seemed clear, although the trap is filled with water, but it looks like it's supposed to be because the trap drains at the top.
I also disconnected the pressure switch tubing at the pressure switch and by blew through it slightly to see if any debris was blocking the port. It seemed clear too.
The gas flow is definintely on to the furnace and I have just recently installed a new filter.
Any help would be greatly appreciated, I'm layed off and I really don't want to pay for a service call here.
For anyone who finds this question in the future - It's the condensate drain hose for the heat exchanger.
Get a bucket and some towels handy and unplug the lowermost flexible rubber hose - if you do this right after the furnace has stopped, water will come gushing out. Mine was continually plugging up causing my furnace to stop, like yours - the L shaped plastic tube that dips into the drain trap on the outside of the unit (the thing filled with water) was too close to the bottom of the trap. I took it out, shortened it by 1/2 an inch (keep the same bevel that's on there!) and I haven't had a problem since. Blowing out the line would only hold things off for a few weeks before it started acting up again.
Cost me $90 for a service call the first time since visually it looks fine and I checked the upper hoses that go to the pressure switch :)
Learn from my service call!
Posted on Aug 09, 2009
  • 96 Answers
Take the hose connected to the pressure off the heat exchanger end and turn unit on and **** on the hose and make a vacuum to the pressure to make it connect if the unit starts the vacuum switch could be getting weak and needs changed
Posted on Feb 23, 2009
Remove the rubber vacuum hose and make sure the hose is clear. Then stick a thin wire down the fitting of the heat exchanger and dislodge anything that may be blocking it. After i did this, I reconnected the hose, and the furnace fired up like it should. I talked to my service guy shortly after. He says that Goodman painted the inside of the motor and after a couples of years the paint flakes off and clogs the opening. Just saved myself probably $150. To everyone who posted solutions, thanks for the help.
Posted on Oct 02, 2009
  • 51 Answers
Also check to see if hose from bellow switch to draft inducer has water inside. if hose is to long can trap condensate
3 Suggested Answers
  • 230 Answers
SOURCE: How to manually relight a
You should NEVER attempt to relight manually this furnace. Serious burns could be the result. This furnace has an electronic ignition and should light by itself. If it does not light you may have a bad ignitor. These are usually around 30-50 US dollars.
Posted on Jan 28, 2009
  • 232 Answers
SOURCE: need help with a goodman gmt070 furnace
it may be clogged at the barbed fitting on the induced draft motor where the pressuer switch tubing connects. take a paper clip and **** it out make sure you can stick it thru freely till you can feel the Inducer wheel then reconnect and try again.
Posted on Nov 05, 2009
Combustion blower motor runs all the time
I'm assuming what you call a combustion motor is actually the idm(induced draft motor) which is the 1st action in a gas fired furnace, clearing any residual fuel from heat exchanger then forcing the flue gas to the outdoors. This IDM is controlled, normally, by the furnace control board(circuit board). May need a new board.
Nov 16, 2015 | Heating & Cooling
I have a Goodman GMS9 furnace. When the furnace starts the induction fan runs for about 15 seconds, the ignitor turns on but thats as far as it goes. The burners do not light and I don't think the gas...
The igniter heats a thermocouple to turn on the gas valve. From your description, the thermocouple may have failed. The noisy stack blower probably needs to be replaced but its controller may be in need of replacement as well.
Nov 01, 2013 | Goodman GMS90703BXA Heater
My Goodman GMS9/GCS9 Gas-Fired Furnace is not working.?
Check all safety switches on door. Make sure the main breaker in fuse box is on and well as main switch on furnace. Please ad more details. New install, just quit working? How old....
Oct 27, 2013 | Goodman GMS90703BXA Heater
Goodman Furnace GMS9/GCS9 Blower seems to not be made very well. The repairman put two different ones on before finding one that's somewhat balanced. I still feel it rumbling a little. Are there
It is possible it is a problem with the motor mounting bracket or the fan housing itself. Tough to believe you have gotten three bad blower wheels. Also could be the motor .
Dec 17, 2017 | Goodman Heating & Cooling
My furnace heats the house well, but during the cool down it actually blows cold air dropping the temperature causing the furnace to re-ignite. How do I adjust? Goodman - GMS9/GCS9
Depending on the age of the furnace you may be able to adjust the cool down. On some furnaces there is a silver box usually made by honeywell. This is your fan limit control. If you take the cover off you will see a dial with different temperature settings with 3 pins in a grove. The first one is fan on with temperature rise this turns the blower on when the furnace starts and warms up. The second is the fan off after furnace shuts down, this would be the one you want to adjust to a higher temperature to keep the blower from blowing cold air. The last pin is the high limit if the furnace gets to this temperature it will shut the furnace off but keep the blower running. Make sure that the thermostat fan option is set to auto and not on.
Jan 02, 2010 | Goodman GMS90703BXA Heater
Induced Draft Blower Not Blowing- 3 Blinks on LED
Your doing well just right. When the call for heat is on the draft motor gets a call from the board to come on. When this happens if no voltage is present at the motor then you ahve abad baord. Replace it.
Nov 28, 2009 | Heating & Cooling
How to manually relight a Goodman® GMS9/GCS9 Single-Stage, Multi-Speed Gas Furnaces
Jan 28, 2009 | Goodman GMS90703BXA Heater
Furnace won't stay running
1 FLASH
Furnace fails to operate.
• Integrated control module
diagnostic LED is
flashing ONE (1) flash.
• Furnace lockout due
to an excessive
number of ignition
“retries” (3 total)1.
• Failure to establish flame.
Cause may be no gas to
burners, front cover
pressure switch stuck open,
bad igniter or igniter
alignment, improper orifices,
or coated/oxidized or
improperly connected flame
sensor.
• Loss of flame after establishment.
Cause may be
interrupted gas supply, lazy
burner flames (improper gas
pressure or restriction in flue
and/or combustion air
piping), front cover pressure
switch opening, or improper
performance.
• Locate and correct gas
interruption.
• Check front cover
pressure switch
operation (hose, wiring,
contact operation).
Correct if necessary.
• Replace or realign
igniter.
• Check flame sense
signal. Sand sensor if
coated and/or oxidized.
• Check flue piping for
blockage, proper
length, elbows, and
termination.
• Verify proper induced
draft blower performance.
Nov 23, 2008 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
3,619 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
