Question about IBM ThinkPad R50e Notebook
I cant access internet exp. from my laptop even with good signal
I have a sony laptop with windows xp, I have a wireless router but cant access internet explorer. I have very good signal strength but when I try to open ie it says it cant display the page. Checking the connection it says something about a certificate.
  • 447 Answers
Access the preferred network settings (if you are using the Windows wireless setup - right click on the wireless icon + view available wireless networks + preferred networks) for your machine and edit the listing for your wireless network, you'll need to uncheck the box that says something to the effect of "an authentication key is provided for me" and enter your security key in the boxes provided.
If it still fails - you may want to remove your network from the preferred listing and add it manually, making sure that the authentication is turned off as described and with your security key entered twice.
Posted on Feb 23, 2009
How to connect to internet. what are the instructions... because my router have a signal but it cant connect to internet
1.Log into router. Using either to in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using or to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop/Desktop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
9. cell phones, cordless phones, digital TV's, can affect the data signal from a router. Also distance from the router can be a factor. If your router is in a basement place the router to a upper floor and center it in the room.
You will also need to configure your browser for the internet
1. for Windows XP here is the setup :
2. For Windows 7
here is the setup instructions: getting online and networking
Apr 07, 2011 | Computers & Internet
I recently restored my Compaq Presario V2000 back to windows xp (it was vista before). Now, I cannot connect to the internet. The laptop picks up the signal and the icon on the bottom right says that...
A Belkin router doesn't usually force the utilities page on you. I would advise checking your start page - you might have set it to your router's homepage by accident.
Aug 19, 2010 | Belkin N1 Wireless-N Wireless Router
Icouldn't access the internet. Your help tam, via
Please go in to your router and change the wireless setting from WPA2-PSK to WEP. Ansd then try to connect your laptop.
To windows after you change setting to WEP
(XP bottom right hand side you have system tray in that you have a wireless sign click on it. It ask for the password which you will change put that password click connect)
For laptop also same in case it not work then
(window icon>control panel>network and sharing center>wireless connection>properties>put the password click connect (then it will check out the wireless signal after sometime you will'be able to connect).
Hope this will resolve your issue.
Oct 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Hi i am using internet on my laptop with windows xp os internet connection i was using with the help of phillips wireless router yesterday one of my friend with his laptop used my wireless connectionafer...
I have a different router with similar problem but to fix this problem I just shut down the CPU and the router, then I waited a minute or 2 so it would reset and when I turned it back on everything woked fine. could be as easy as clicking on the repair internet connection icon so it will rest IP, but you may have already tried that. Good luck
Jul 13, 2009 | Computers & Internet
Laptop driver needed
You dont need a driver for the wireless router. If your laptop can recieve wireless signal(from a wireless router) all you need is an active internet connection, configure the laptop and router to distribute the internet, you're good to go.
If your laptop cant recieve a wireless signal from a wireless router then you might need a USB Wifi Dongle.
Apr 06, 2009 | Linksys Wireless-G VPN router with...
Hp Pavilion dv6929nr not connected with D-link DI-624
There are a number of factors that can cause the signal of your access point to deteriorate and the performance of your network to fall under par. Practically any appliance that operates on the same frequency level (2.4 GHz) as 802.11b or 802.11g can cause interference with your wireless network. Be sure to keep cordless phones, microwaves and other electrical equipment at least 1m away from the access point. Try changing channels on the access point and test it out on one of the clients. To change the radio channel on the access point login to the configuration (usually a web based interface) and go to the Wireless Settings (will vary depending on vendor) section, select a different channel and save settings. On the client, go to Device Manager, right click your wireless network adapter and go to Properties. In the advanced tab select the Channel Property and change the Value to the same number as the one you chose on the Access Point. Disable and then re-enable the wireless connection. Also you can try by select the speed manually 802.11b or 11Mbps on your laptop wireless properties.
Mar 21, 2009 | HP Computers & Internet
Configuring WRT54G
there are many ways to setup/configure a wireless router. the easiest way for me is to plug your modem to the router, (even though unplugged, there should be a wireless network signal on your device that has a wifi but no internet connection) once connected, plug the modem to the wireless router then reset it, wait a few seconds then you'll get an unsecured network with internet access on it. usually, the only use for the cd is to make you configure it easier like putting a password on it etc.
Feb 05, 2009 | Linksys Wireless-G WRT54G Router
No wireless signal
Most home router has an IP address of or If you dad's laptop can connect to the router just fine, then it's a problem with your linux laptop. Can you see other wireless networks on your laptop?
Jul 23, 2008 | Belkin (F5D7231-4) Wireless Router
Wireless internet access
set up wireless security on the router and laptops, they most likely are not allowed, by the router, access
Jul 12, 2008 | D-Link AirPlus DI-524 Wireless Router
Wireless connection
Hi, I am going crazy! Just moved house and took my Netgear Wireless router with me. However, even though the hard wired base unit works, my wireless laptop can't access the internet - even though a full stregnth signal is there when i browse for wireless connections. Using Vista Home Premium. Help appreciated!
Dec 29, 2007 | NetGear WGR614 Wireless Router
IBM ThinkPad R50e Notebook Logo
231 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
