Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
GE Side by Side refrigerator and frezzer not cooling
The ice cream is melting and the water is not cold? Can I fix this or do I need to call a repair person?
    Sergeant:
  • 359 Answers
FIRST MAKE SURE YOU HAVE IT SET TO DIVERT MORE AIR TO FREEZER SIDE THAN RE FRIG SIDE , MAKE SURE THERMOSTAT IS SET TO COOL ENOUGH , NEXT MAKE SURE SMALL FAN IN REAR OF FREEZER IS RUNNING , SOME MODELS YOU MUST DEPRESS DOOR SWITCH AS YOU WATCH IT , IF FAN IS BAD YOU CAN REPLACE IT YOURSELF REMOVE FAN AND COVER AND MOST UNPLUG , SOME IDEAS
Posted on Feb 24, 2009
I have a ten year old, side by side, Kenmore refridgerator, model 596.5069 that will not get cool. Started noticing the ice in the frezzer was melting and now it will cool only a bit. Have another fridge...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 04, 2011 | Kenmore Side by Side Refrigerator
I have a GE side by side refrigerator bought in 2003. The freezer is not cooling enough and the ice creams have melted. The fridge is not cooling much but it is cooling enough to maintain the stuff in it....
heatman101
Jun 03, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Our GE Profile has stopped Freezing. It does not make ice and many items have "thawed out" - including melted ice cream. Please help! We can't afford a new fridge. Thanks.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Nov 28, 2010 | GE Profile PSW26P Stainless Steel Side by...
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Sep 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My G.E Adora refrigerator freezer is not cold enough. Ice cream is melting and refrigerator is at too cold and is freezing food, It is only 5 years old. It is a side by side. Help!
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 18, 2010 | GE Adora (DSF25KGTBG) Side by Side...
Stays in defrost too long. ice in the ice maker melt together. drips water inside the frezzer, changed the defrost thermostat & the mother board witch has the defrost timer in it. what is the ohms...
how is the food?is the ice cream getting soft? are you just having problems with the ice melting?you could have a bad water valve,water could be leaking past the valve,overflowing into the bin and will drip down,with the heater it's gonna work or not work when it should,there's a heater in the ice maker also
Mar 20, 2010 | Hotpoint HSS25GFP Side by Side...
Symptoms: Ice cubes melt, drip then refreeze causing
are you having any cooling problems? take a look at your ice cream, if you have any. does it look like it has melted and refrozen? if so, you have a cooling problem, and that is causing ice to melt, then refreeze. if you have no cooling problems, then you may have a faulty water valve solenoid, or even a faulty icemaker.
Feb 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The ice melts from the ice maker forming icicles down below.
Just had this same issue repaired yesterday, the defrost element was out allowing the freezer to freeze up stopping the fan which moves the air and in turn causing the upper part of the frezzer to become warm and melt the ice. This is a common problem for the GE profile and I recommend finding a service company cheaper than GE and quit letting GE make more money off their CRAPPY appliances.
Oct 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
91 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
