Question about Kenmore 47732 / 47734 / 47739 Electric Double Oven
Kenmore gas oven continuously beeps F-5 when on. I have to cancel and not use. Please help.
  • 15,935 Answers
All F5-E Codes - Door Switch Defect - This occurs when the door switches do not match.
If door is latched, disconnect power from unit and check wires and connections. If damage is found, replace appropriate part.
If connections are not damaged, reconnect power and hold down any key until the F5 error clears.
Once the F2 code appears, select 'cancel' and observe for one minute for errors.
If door is NOT latched, disconnect power from unit and check wires and connections. If damage is found, replace appropriate part.
If connections are not damaged, measure door switch (door open = latch open) and latch switch (unlatch = switch open) and replace either if defective.
If corrections are made during any step, power should be reconnected and the unit should be tested.
Press and hold any key to clear the error code and F2 code should appear. Select 'cancel' and observe for one minute for errors.
If error continues, disconnect power and replace control.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
I put my kenmore oven on to clean.I PRESS CLEAN AND THAN START.THE DOOR LOCKED AND THE CLEAN LIGHT CAME ON.AFEW SECOND LATER I HEARD BEEP BEEP AND ERR-F9.GOT MY BOOK OUT AND FOUND NO ANSWER.SO I CALL...
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Aug 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
40494 / 40495 / 40499 Electric Single Oven: have a kenmore self cleaning electric range it was...
May 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Error message on Kenmore oven
F-1 is not good. It basically means the EOC (electronic oven control is bad). There is a little test here for a little info:
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Sep 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Stove door locked and continues to beep and flash code F9
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$%^^%$
Mar 27, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
My oven wont quit beeping!
It depends on the actual model number (that you didn't supply), but most Kenmore F7 errors indicate a bad keypad or bad control panel. If you unplug the ribbon cable from the keypad to the panel then plug the oven back in and it starts beeping again, it's a bad control panel, if it doesn't beep anymore, it's a bad keypad.
Please unplug the oven power with working on it.
Geno
Aug 02, 2008 | Ovens
Cleaning the over
Try pressing and holding the cancel button for at least 5 secs. Wait a few mins. Something different should display on the display panel. The door should unlock after a couple of minutes.
Dec 25, 2007 | Kenmore 30172 / 30174 / 30179 Gas Single...
Kenmore electric oven 337098
While I can't promise results, it sounds similar to a problem I have helped over 1100 other solve. Please go to the following link: http://fp1.centurytel.net/Powerman/Dreaded F7 Problem.pdf Let me know if it works for you. You can email me at hutchipop@yahoo.com
Aug 20, 2007 | Kenmore 30172 / 30174 / 30179 Gas Single...
Kenmore 47732 / 47734 / 47739 Electric Double Oven Logo
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
