Question about NorStar M7324 Telephone
Problem with speed dial buttons
We lost all of our speed dial buttons, they all go to the same number now. When we try to reprogram one, they all start going to that number. Unplugged phone completely to reset it but that didn't help any.
  • ynotphone
    ynotphone May 11, 2010
    That doesn't make sense...
    Are you programming the system speed dials? or speed dials on the set buttons?
I have this problem when one of the spped dial buttons gets stuck. Make sure none of the speed dial buttons are still pushed down and try reprogramming.
Posted on Mar 27, 2009
To program a speed dial button - <feature> *1 - select button / enter speed dial number / quit....you may have to reprogram each button.
Posted on Mar 23, 2009
How do I reprogram a speed dial number on a DKT2010-H that has no display?
With a DKT 2xx0, you're probably on a DK-XX system
Try these steps
Leave phone on hook
Press REDIAL
Press SPEED DIAL
Enter Speed Dial Bin Number:
(Small system is 10-49 personal, 60-99 system-wide)
(Medium system is 10-49 personal, 600 - 699 system-wide)
(Large system is 100-139 personal, 200-999 system-wide)
Enter phone number
Press REDIAL to lock in number
If you're on a CiX system:
Press #9876
Press SPEED DIAL
Press Bin Number 100-199
Enter phone number
Press Speed Dial
Lift handset to lock in
Oct 06, 2014 | Toshiba DKT-2010 Corded Phone
"No such station" message appears when I try to
It means there's "No Such Station" :-)
VM extensions are part of the system, usually the pilot number is the lowest of the sequence. If your button got reprogrammed and you're dialing a number that doesn't exist, you'll get that error.
Start by dialing like 22, 23, 24, 25 (4 highest ports in a 0816 DSU). Reprogram the button by Intercom **1 press the button and dial 6xx where xx is the VM pilot number.
Carl
Jun 23, 2011 | Comdial 8012S-GT Corded Phone
Hello. I have a M7310 Nortel office phone. All of a sudden, the Speed Dial button will not work. In checking the phone, all the speed dial numbers are still programed in the phone, but again the speed dial...
What? They are either programmed or not programmed. If the button is blank, I'm voting for NOT programmed.
If your system is old enough, it's probably lost the backup battery. Ugly things, like pulse dial and only 2 lines are what usually happens, along with losing all of the button mapping but your 2 lines and the default programs of LNR, CONF, etc.
If it's just one phone, there's no magic recall. You'll just have to reprogram it. Same with the system if you've lost everything, but I"d call a repair tech first to fix the battery on the software cartridge.
Carl
Apr 14, 2011 | NorStar Meridian M7310 Phone
I have the KX-T7020. How do I reprogram the auto dial numbers?
Here's a guess. Is the 7020 the one with 16 buttons? If so, they are marked CO 1-12 and F1-4. You program them by putting the phone in PROG from the switch on the back of the phone, then press the button and 1. If it's a F button, dial 9 + number and STORE. If it's a CO button dial 29 + number and STORE.
If you're talking SYSTEM speed dial numbers, those are done from the display phone at jack 01 and putting the system in programming.
Carl
Mar 24, 2011 | Panasonic KX-T7020 Corded Phone
How do i reprogram my speeddial numbers on jazz 4400?
Hello.
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
How do I program a speed dial out side number on the buttons to the right?
What happens when you dial "9" on the intercom? If that gets you an outside line, then press PROGRAM, one of the buttons, and dial 9 plus your number and STORE.
Hmmm...Speed dial :-)
If you get a vacant line at "9", then you need to reprogram your 400 line access on your phone sytem to disable the vacant lines.
Carl
Aug 31, 2010 | Panasonic KX-T7731 Corded Phone
How do I reprogram the buttons? Office personnel has changed and I would like to put some different numbers in speed dial.
On the set you wish to reprogram, press feature 00
press the button you want to program, enter in the phone number you want. if you want to program someones extension, after pressing the button you want to program press the right intercom and the persons extension number.
Dec 19, 2009 | AT&T Partner 18 Phone (315805B)
I have an older at&amp;t 620 speaker phone
goto call settings and fix in the numbers you want for speed dial
Jul 15, 2009 | Lands Phones
How do i reprogram model ge 2-9267a
pull out the plastic tab that holds the piece of paper with the names of the people you speed dial. the instructions are under there.  pick up handset - ignore dial tone or dial tone going away - press "memory store" button - dial the number - press one of the eight buttons for location - hang up phone. that's it - your new number overwrites any old number that was in there. (then write the name of person on the piece of paper.)
Apr 18, 2009 | GE Lands Phones
Speed dial instructions
make sure phone is off not in talk mode- then press the memory buton-press desired number 1-9-press memory button again,the display shows enter name -press memory button to save the name.then the display shows enter number-enter the number then press memory again and you will hear a tone that confirms
Oct 05, 2007 | Uniden Cordless Phone
NorStar M7324 Telephone Logo
230 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
