Question about Jenn-Air JLG7130A
Grill will not light / jenn-air
I have a model 730-0337 (converted to natural gas) worked great into fall. in colder weather grill works one week and no gas present the next week. igniter is firing, no gas present or so little that flame is barely visible. grill is clean, igniters work, gas valve in house is on. Is this a manifold problem? I have a weber at another home hooked up the same way and works great even in below zero weather.
    Sergeant:
    New Friend:
  • 199 Answers
Blow out all the gas tubes, sounds like you have spider webs in them.
Posted on Jul 27, 2017
jsrock516
  • 5911 Answers
SOURCE: jenn air jgr8850adw won't bake
This usually is an indication of a bad igniter. If this is the standard glow type igniter, it could appear as if it is working, but may not be providing enough current to open the gas valve. This is a safety feature on gas ovens. The gas valve requires a current potential of .32 to .37 amps through the igniter before it will open and allow gas to flow. This prevents gas leakage if the igniter fails to light. The reason your broiler works is probably due to the fact that the broiler gets used less and the igniter is probably in better condition. You can test this theory, if you like, by swapping the igniter for the bake and broil burners to see if the symptoms change. Or, you can simply just replace the bake igniter with a new one. Make sure you secure the power before attempting, though. You shouldn't have to turn off the gas for this. Chances are that's all it is. I hope this helps you.
Posted on Jul 14, 2007
fridgetech
  • 473 Answers
SOURCE: Jenn Air Cooktop Burners Won't Ignite
The orifices may be dirty. They can usually be cleaned out with a safety pin.
Posted on Oct 05, 2007
SOURCE: Jenn-Air JGD8130 Gas Cooktop will not ignite
I just ordered one of these---sounds like people are not happy with this model---please get me more info
Posted on Mar 29, 2008
SOURCE: Jen-Air Gas range Igniter keeps clicking but not starting fire
01/26/09 My wife decided to give our Jenn-Air a good cleaning. With lot's of soapy warm water she pulled the knobs off and washed under each of them not realizing excess water was now running down the inside of each control knob shaft. The igniter immediately began clicking away as it was being shorted by the conductance of the water now inside of the switch. I had to remove the cover (2-screws) to access the control switches but that is all I needed to do do in order to have clear access. Using her hair dryer it took about 5 minutes of warm air blowing down each of the shafts until the water evaporated and the clicking stopped. Wahla. The old Jenn-Air is back to working order again.
Posted on Jan 27, 2009
jyackle5
  • 8197 Answers
SOURCE: grill model 720-0163 need to convert from propane to natural gas
Go to jenn airs web site an order a new natural gas regulator and or-faces.
Good luck and please rate fixya!
Posted on Feb 24, 2009
I Have A Jenn-Aie Model 720-0164 Natural Gas Grill. When I Grill, The Control Knobs Get So Hot Theyh Will Burn You. What Could Csuse This?
Can this grill be also used on propane? If so you might be running it too hot on natural gas, check to see if the control knobs have two different set of markings.
Sep 16, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
Jenn air model 720 0061 manuel
Jenn Air model 720 0061 LP outdoor grill manufactured 12/ 2004 serial DG-002
I have bought this second hand. Would like operating , maintenance, and parts info.
Mar 31, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
Is there a conversion kit for Jenn-Air Model No: 720-0061-LP to convert from LP to Natural Gas?
Matt, I am not aware of one. Nor, whether it's approved or not, by the manufacturer, Nexgril.
My best advice is to contact their Customer Support Dept @ 800-913-8999
Keep in mind, it you are able to convert it, the gill will no longer get as hot as it does with propane.
Propane burns hotter than Natural Gas in an outdoor environment.
I hope this helps you and Happy Grilling!! Thanks for choosing FixYa.
Jul 28, 2011 | Grilling
I have a Jenn air model 730-0163 natural gas grille I need to convert to propane. can this be done and what parts and where do you purchase the?
As I told a questioner, yesterday. Yes, I believe a kit is available. If you purchased this Jenn Air grill from Lowe's, it was manufactured by Nexgrill Industries. Not Jenn Air. In any event, Lowe's no longer sells the Jenn-Air line of grills. My very best advice is to contact Nexgrill Customer Service @ 800-913-8999. In addition to the burner orifice parts you'll have to have, you will also need a grill tank Hose/Regulator Assembly.
Hope this helps and Happy Grilling!
Mar 18, 2011 | Grilling
I have a jinnair model JA460N Gas Grill that currently runs on natural gas, I need to convert to propane. Is this possible and if so is there a conversion kit available?
Mar 16, 2011 | Jenn-Air Grilling
Jenn Air 730-0163 need to convert from natural gas to propane
If you purchased your Jenn Air grill at Lowe's, you'll need to contact Nexgrill Manufacturing, the manufacturer of that grill. 800-913-8999 Don't forget, in addition to the burner conversion parts, you will need a grill hose/regulator assembly. This is not part of the conversion kit.
Happy Grilling!
Mar 12, 2011 | Grilling
NAtural gas vs propane
I'll trade my propane regulator for your natural gas hook up.
Mar 27, 2009 | Jenn-Air JLG7130A
Jenn Air 740-0141 LP to NG Conversion
If the grill can be converted, it's usually a matter of providing a source for the natural gas and then changing the gas jets for the burner(s) and possibly a regulator, depending on your model. Some grills may require changing the gas burner valves themselves. Kits are usually available from a dealer unless the unit is old.
The natural gas jet will be slightly larger than the propane jet because natural gas doesn't have as high a heating value as propane.
If you do this, check your new conversion for any leaks using a soap solution in a spray bottle.
Just be aware that the grill may not get as hot with natural gas and cooking could take a little longer, but should still work just fine.
Your natural gas line should typically be about 1/2" unless it's huge or is over 50-60 feet away from the grill location. If so, use a 3/4" line. Piping material and methods are usually governed by your local building codes.
Mar 17, 2009 | Thermos Stainless Steel Gas Grill
Grill model 720-0163 need to convert from propane to natural gas
Feb 22, 2009 | Jenn-Air JLG7130A
Jenn air propane grill conversion
It is inconceivable to me that large manufacturers like Jenn-Air and Nexgrill can jointly make and sell an expensive grill and then completely abandon the consumer. I purchased an Jenn-Air 740-0142 LPG and like so many wanted to convert to nautural gas which requires a larger gas orifice. I spent a month on the internet and phone calling Jenn-Air and finally Nexgrill who actually manufactured the unit in China. The Jenn-Air and Nexgrill serial numbers are the same. the 740 prefix is LPG and the 750 prefix is natural gas. After three calls to Nexgrill I found a manager who actually acknowledged making Jenn-Air but declined selling me parts for it as I believe they have product liability concerns. I call back as a Nexgrill owner and finally ordered natural gas orifices at $10.00 each. The shipment never showed up. Calling back again I was told that they really didnt really have any orifices in stock but could sell me the entire replacement gas valve for $28.00 which I purchased. The valves actually arrived on the shipping receipt was from The Grill Services in City of Industry 909-718-6128 www.grillservices.com . Part number 750-0141/142/593/594.
Forget about pirates in Somalia... we have them right here. Shame on you Jenn-Air and Nextgrill.
Mar 12, 2008 | Grilling
Grilling Logo
496 people viewed this question
Top Jenn-Air Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Jenn-Air Grilling Expert? Answer questions, earn points and help others
