Question about HP ProLiant DL160 G5 (445198-001) Server
I have HP proliant DL160 server. How i will make RAID two HD?
I have bought HP proliant DL160 server. But i am able to Make RAID of two SATA hard drive. please help me...
  • 339 Answers
Try going into the RBSU(Rom based setup utility) and configuring SATA RAID in the advanced section.
This doesn't work for all versions - if it doesn't help, please be more specific about your configuration, i.e. what "G" level is the server? Hot plug or non hot plug drive? etc.
Posted on Jul 12, 2009
How to installed xp2 in server hp proliant ml 350 my hard drive ok
You may need raid controller driver for HP proliant ml 350. Copy raid controller driver in flopy disc, insert it in flopy drive, insert cd in cd driver, boot server from cd and start installation process, as soon as you see Press F6 if you need to install third party scsi drivers or raid controller, press F6 and follow the instruction. It will then ask you to select RAID driver file and then will continue to windows xp installation.
Regards,
Kaushik Patel
Aug 24, 2013 | Computers & Internet
I forget bios password for HP DL160 G6 server, how do i reset the password ?
  1. Shutdown your server.
  2. Go inside the server, and remove the CMOS battery. It should look like this.
3. Be sure to power down your server before taking it out. Be aware that once you take this out the system will forget a lot of it's time settings. This is the battery that keeps the computer's memory of time, date, and BIOS password when it's shutdown.
Apr 14, 2013 | HEWLETT-PACKARD HP ProLiant DL160 G6...
ML3670 does not boot as it does not found an boot disk
Replace HDD (Red Flashing ).It seems you have unknowingly disturbed your Raid . If Possible take backup of your server.Reconfigure RAID and Freshly Install OS .
Apr 04, 2012 | HP ProLiant ML370 G4 Server
We recently had a HD failure on our HP Proliant ML370 G3 server. The failed drive is in a RAID 5 configuration, so we simply purchased a replacement drive, and installed it. The problem, is that it...
why not ask HP this, and not in chat rooms. (here)
raid recovery is fully documented at Hp.com
for sure, and even forum help...
you'll have to switch to the commercial, side,
https://h30434.www3.hp.com/
type this in there box.
May 13, 2017 | HP ProLiant ML370 G3 Server
HP DL180 G5 2 x sata segate 1 T 32 buffers mirrored for Win 2003 Server and 6 sata segate 1 T 32 buffers for data (raid 5) Problem is about 2 hard mirrored that somtimes one of those hards shows yellow...
you just posted a Proliant system to FIxyah, why?
why not post to the HP forum for business computers.>?>?
what HDD? are the SMART DRIVES. as all are now?
yes, the run SMART program to see why they are failing.
see if any ran out of spare clusters and doom soon for sure.
why not ask here, (at real HP)?
Jul 13, 2017 | HP ProLiant DL180 G5 Server
Enable RAID system
use this guide, this is fo the embedded sata raid controller that comes standar with the ml150 g5.
Enabling SATA RAID functionality in the BIOS Setup Utility: 1.Boot the server, and then press F10 to enter the ROM-Based Setup Utility (RBSU).
2.Go to the advanced tab.
3.Enter the IDE configuration or hard disk configuration.
4.Change the ATA/IDE configuration to enhanced or SATA controller 2 enhanced (if not available then use enabled mode).
5.Configure SATA as RAID or configure controller 1 as RAID.
6.F10 to save and exit.
7.Reboot the server.
8.During post f8 will now show up for the embedded SATA set up.
•Creating the RAID volume.
1.Enter the embedded SATA setup by pressing f8 during post.
2.Enter the array configuration utility.
3.Enter create array.
4.Create the raid volume as desired.
5.Save and exit.
i hope it helps you!!!
Aug 11, 2010 | HP ProLiant ML150 G5 Server
ProLiant DL160 G6 Server, Part Number 593352-B21, Serial Number USE029N5Z2. The system fails to power on. The power supply has the LED light green. The start button does not turn amber. Do not...
ProLiant ML150 G6 and DL160 G6 (HP Smart Array B110i SATA RAID) does not support more than 4GB memory, (2GBX2 modules) or more added, it works fine with single 2GB module. Boot OS with single module and upgrade system Rompack to the latest version then upgrade B110i controller driver to 6.8.0.32. Shut down the server, add additional modules. It will work fine.
Aug 04, 2010 | HP ProLiant DL160 G6 Server - 1 x Xeon...
Dell RAID controller in HP server? Hi i have dell (Adaptec) CERC SATA1.5/6ch RAID card, now i want to use this card in HP proliant ml150 g3 server, after fixing this card server did not recognize it keeps...
This particular device will require drivers for the Operating System to use. Also the hard disk drives will have to be installed an initialized outside the Operating System first before use. This is usually during startup after the system BIOS.
The exact steps can be found on the RAID card manufacturer's web site.
Feb 18, 2010 | HP ProLiant ML150 G3 Server
I have hp proliant with raid 1+0 .I have 2 hard and usr in option
Sometimes shortened to RAID 10, RAID 1+0 is a particular combination of two different RAID levels: mirroring (RAID 1) and striping (RAID 0). The appeal of RAID 1+0 is simple: mirroring gives you the highest level of availability RAID offers, with the fastest rebuild times when a disk fails; while striping - using the proper chunk size - is the basis for high-performance I/O.
Jun 09, 2009 | HP ProLiant DL380 G4 Server
HP ProLiant DL160 G5 (445198-001) Server Logo
658 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
