Question about Amana ALE643RB Electric Dryer
Amana electric dryer will not heat/ LEA60AW Everything works fine but no heat...have cleaned all lint from inside the dryer by taking front panel off. What else should I check.... I noticed it wouild come on for a load or two and then quit. Now I cannot get it to heat up at all.
  • Anonymous Mar 13, 2009
    Heats up for 5 to 10 minutes, then gets cool. Cleaned lint, striker element and thermostat
  • 462 Answers
Check for 220 Volt at the heater entrance to the heater box (accessible from picking up the top on most models). If you have 220v there the heater element is out. If you don't have 220v on the terminals of the heater the problem is in the controls. The fuse link, the timer contacts, the centrifugal switch on the motor, and the heater safety thermostat and operating (s), are all suspect and have to be eliminated 1 by 1. Hope this helps. With any luck all you need is a new element. Clean the duct out while replacing the heater if so because the main thing that causes heater element burn out is low air flow a kinked Dryer vent hose, lint, and plugged up fan on the motor are the 3 main causes of low air flow. If yours has little holes in the inside cabinet these can get clogged with lint also and cause a problem. Hope this helps and please rate me accordingly Thank you and good luck.
Posted on Mar 13, 2009
    Problem Solver:
  • 5 Answers
I have an Amana dryer and it did the same thing. The heating element went out. I don't have my model number but on mine you take off the lower access panel and the heating element is located way in the back on the right side. Just follow the wires. Make sure the dryer is unplugged and then you can remove the heating element. If I remember correctly the new element was about $40.00 at the local applianance parts store. Pretty easy to change at least on my model. Good luck.
Posted on Sep 10, 2009
Amana dryer lea60aw.when dryer is plugged in and door open, timer is ticking and recently replaced heating element is giving off heat-does the timer need to be replaced? or is it a thermoststat/ etc.?
It should not be on sounds to me like the cent switch inthe motor needs replacement. Common on amana dryer motors, not too hard to fix. See if it slides easy by hand and oil it cleaning out any lint that may have accumulated in the swtich. The job of the switch is to power on the heating element ONLY when the motor gets up to speed and centrifugal force slides out wrights on the switch allowing for power to go to the heater element . Switch stuck most likely, let me know.
Jan 11, 2017 | Amana Dryers
How do I remove the front panel?
AMANA Dryer Control panel Parts Model LEA60AW PLEA60AW
take two side pieces (screws) and the knobs off front and it unclips
Jul 30, 2014 | Amana Dryers
Amana ndg7200tw dryer belt replacement
Unplug it from power,Take the top off the dryer. They "pop" on and pull off. Take the front panel off from the inside, Clean all the lint out, remove the old belt by sliding it off the front if it is not broken, put the new belt on, Stretch it to motor pulley, put the belt tensioner pulley on it, reassemble.
Feb 17, 2014 | Asko T761 Electric Dryer
LED20AW Heating element
No Jim, that amount of lint is normal in all of those dryers. You should clean it out annually to prevent fires. The front panel under the door is all that you should have to take off to get to the heater coil and to clean it out.
Jan 20, 2014 | Amana Dryers
Dryer runs for a while then stops. is this the motor overload protector?
Dryers can get finicky when they get older. I would open the back panel and any other port or access you can find and blow or vaccuum it out. Sometimes a ton of lint and dust will accumulate over a overload heat switch and cause it to stay hotter than its supposed to. This of course shuts the unit off. Pay attention to where the lint screen and trap is. If you can partially disassemble the housing the filter lives in, do it and clean it out. You may also want to completely remove the vent hose and be sure it isn't restricted by a ball of lint. THat will cause and overheat too. Good luck and let me know.
May 02, 2012 | Amana Dryers
How to take it apart to clean out the ling area? Hose won't go down that far.
So I just bought one of these and had to clean the lint out to get the dryer heating again. Open the cabinet doors and there are 4 screws
pointing toward you" that will get the console off. Take those off and remove the console, taking care to properly disconnect the electrical connections. Then there are some screws at the top off the front panel that you need to take out. Remove those and the front panel and, again, watch the electrical connections. On the inside of the front panel is where all the lint collects. I got near a wastebasket full and once I cleaned it out the heat was working just fine again. Good luck to you.
Mar 07, 2010 | Maytag Neptune MCE8000AY Electric Dryer
Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
Jul 10, 2009 | Amana ALE643RB Electric Dryer
Your heating element is dying. A new element runs 'bout $40. It'san easy fix. Couple screws .
Mar 05, 2009 | Amana ALE643RB Electric Dryer
Amana electric dryer will not heat....LEA60AW
check your wall vent to make sure it's not clogged,also check the fuse on the heater box it may have blown,without the fuse the heater will not work,you can check it with an omns meter-mike
Feb 23, 2009 | Dryers
Fisher and Paykel DGGX1 Gas Dryer Not Heating
On gas models of the F&P top load dryer, there is a reset button for the gas igniter. Take the front panel off as described above and you will see some orange wires leading to the front of the burner. Remove those (one side has two orange wires, the other one - note which is which; generally the two wire connection is on the left) and the reset button is between them. Press it, replace the wires and start the dryer. The gas should light in about 15 seconds. If it does let it run for 10 minutes or so to insure it is fixed. Then shut down and replace the front panel.
Check the lint trap as described above and also check the lint vent outside the house. My vent goes up through the roof and the lint builds up about every two years. You can by a vent cleaning brush off eBay for less than $20.
Mar 17, 2008 | Dryers
Amana ALE643RB Electric Dryer Logo
1,550 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
