Question about Porter Cable 3,000 Watt Electric Generator CTE300
My porter cable generator 3000 wt will not stay running once star
My porter cable generator will start but it will not stay running.
  • Jim London
    Jim London May 11, 2010
    Hi, There are a couple of things that will allow it to start then shut it down, like low oil or overtemp, or not moving the choke into run position. Can you give more details?
  • 169 Answers
If this generator has been stored for any length of time with fuel in the carb you probably have a plugged main jet in the carb. As joboo1 says there are a few other things that could cause this behavior, but most often I see dirty carbs, water in the fuel, and plugged/dirty air filters. Get a flashlight and look into the fuel tank thru the filler hole, if you see anything floating in there you've got water in the fuel. Look at the ari cleaner, oil and fuel on the element indicate a dirty carb. Of course check the oil level. Lastly, take the bowl off the bottom of the carb (shut off the fuel valve first), if you see debris in there the carb needs a good cleaning.
Regards,
Carl
Posted on Mar 01, 2009
I need a capacitor for a porter cable DBS1325 alternator but it is rusty and I cant read the labeling
Porter-Cable Portable Generator - Lawn and Garden Manuals
lawnandgarden.manualsonline.com > ... > Lawn and Garden Porter-Cable
Products 1 - 35 of 35 - Porter-Cable Portable Generator A02871-043-0. Porter-CableGenerator Instruction Manual. Pages: 0 Saves: 0. See Prices Buy or Upgrade ...Missing: dbs1325alternatorcapacitor
Sep 12, 2015 | Porter Cable Electrical Supplies
When I spray starting fluid in carb it starts but won't stay running
It is not getting gas. Check there is gas in the tank, the fuel tap is working and the float in the carburettor isn't stuck.
Aug 16, 2015 | Porter Cable PorterCable BSI525W 5250 Watt...
Why porter cable h450is generator won't start
If it starts initially, then it has spark. most likely the jets on the carbureator are clogged. You should remove the carb and clean/rebuild it.
Sep 07, 2014 | Porter Cable 4,500 Watt 9 Hp Portable...
Throttle on generator question
The idle control switch allows the generator to go into idle when there is no demand form the appliances connected. This saves gas and increases the life of the generator. Damage can occur for some appliances like a refrigerator/freezer because the voltage and frequency are not prepared for the load resulting in a low voltage bad startup that will damage the appliance. Suggest that you leave the idle control switch off while any motor/electronic devices are connected.
The throttle control is likely a choke function for starting. These generators are designed for only one running speed to produce the necessary 60 cycles per second and voltage.
The following link is to a Canadian web site that later in the detail report describes the concern of idle control. In addition it provides good insight to the operation and use of portable generators
Hope this helps?
Understanding Portable Generators
The user manual see pages:
http://www.mikestools.com/download/Porter-Cable-Manuals/Porter-Cable-CTE300.pdf
May 06, 2017 | Porter Cable Portable Generator BSV750
What type of oil do i take for a porter cable 5250 watt electric generator?
Your generators take ordinary 10W30 motor oil.
We use these things on the job.
Don't turn engine upside down or on its side to drain oil, or oil will run into carburetor
Oct 24, 2010 | Porter Cable PorterCable BSI525W 5250 Watt...
My porter cabe 5500 only runs on choke
Because it running lean, too much air in the air/fuel mixture. I can only give a suggestion and it's a rule of thumb I follow regarding basic internal combustion tuning. With this condition I locate the fuel adjustment screw, usually located after the throttle plate (butterfly) which controls the amount of fuel into the mixture.
I would set it up to run richer then open the choke until it idles effortlessly, without any assistance. When it's too rich, the engine's revolution would be to high and probably cause it to smoke a little and I back off the adjuster. The best level is that it shouldn't stumble and cut off. Once this is optimal, hard starting and unassisted idling should be eliminated.
Jun 27, 2010 | Porter Cable 5,500 Watt Portable Generator...
Porter/Cable BS1525-w generator, starts always on the first pull, runs fine for an hour or more and then it dies out. Starts right away and it runs again for a while before it dies out again. No matter if...
Hello. I'm sure that you've checked your air filter, so check the pinhole vent on the fuel filler cap. Next time it dies, immediately crack the cap and listen for the sucking sound of air rushing into the tank. If you hear this, clean the cap!
Regards, --W/D--
Jul 23, 2009 | Porter Cable 3,500 Watt 6.5 Hp Portable...
Porter Cable 3,000 Watt Electric Generator CTE300 Logo
559 people viewed this question
Top Porter Cable Electrical Supplies Experts
John Trevino
Spud Howell
Are you a Porter Cable Electrical Supply Expert? Answer questions, earn points and help others
