Question about Dell Dimension 2400 PC Desktop
How to remove the hard drive from my dell dimension 2400 pc
  • Dell Master
  • 4,806 Answers
Hi there.
Firstly remove the power cord from the back of the desktop, then turn the unit round so the back of it is facing you, on the right hand side there may be a couple of screws and plastic catches, remove the screws and lift the plastic clips so the side panel opens up, once that is done you will be able to see the motherboard, the hard drive looks like this >>>>>How to remove the hard drive from my dell - e340c2b.jpegnow depending on the type of dell you have there maybe screws or green plastic strips that holds the HDD in place, if you cannot get it that way then the front panel has to be removed.
If this is the case post back and I'll tell you how remove it.
Good luck and thanks for using Fixya!!!
Posted on Feb 23, 2009
  • Dell Master
  • 1,183 Answers
Take the print out of the removal intructions from the link below
http://tinyurl.com/9x92t
Thanks
Proton
  • 3 Answers
Unplug your Computer, Remove the sides of the computer. Fined the HD. You can follow the IDE cable from the motherboard to the HD. Pull this cable and the power supply plug straight out. now just remove the four screws and it will slide out. The IDE Cable looks like thick duct tape. :)
3 Suggested Answers
SOURCE: Dell Dimension 2400 PC Desktop CPU Fan Suppose To Blow?
Blows air into the case away from the cpu.RICHARDM69...This is a solution please vote as such.
Posted on Dec 20, 2008
  • 18 Answers
SOURCE: Dell dimension 2400 does not recognize cd/dvd drive
Dear Minita,
please follow these steps.
1. Click on START button, the click on RUN
2. Enter REGEDIT and press enter
3. When REGEDIT starts, open up the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325 -11CE-BFC1-08002BE10318}
4. After clicking on {4D36E965-E325 -11CE-BFC1-08002BE10318} you should see two settings on the right-hand side:
"Upperfilters"
"Lowerfilters"
Click on each of them, press DELETE and click YES.
Then close REGEDIT, shutdown & restart your PC
if you still having problem or any other questions, please do not hesitate to contact me.
Many Thanks.
Regards,
AJoshi
Posted on Mar 18, 2009
Is wd1200jb-00gvc0 hard drive compatible with dell dimension 2400
That is a western Digital Hard drive compatible with most computers even Dell Computers
May 15, 2014 | Dell Dimension 2400 PC Desktop
I'm trying to increase hard disk space on a Dell
Hi.
The Dell Inspiron 1100 is a laptop whereas the Dell Dimension 2400 is a desktop pc.
The hard drives are incompatible because they are a different size, plus the Inspiron only supports one hard drive so you can't install a slave device. The only way to increase hard disk space is to buy a large capacity internal IDE laptop drive or an external hard drive.
Regards.
Jan 01, 2013 | Computers & Internet
Dell Dimension 2400 won't boot says press F1 continuosly and hard drive makes constant ticking noise
there could be a problem with your hard drive. I would try another one if possible.
Nov 07, 2012 | Dell Dimension 2400 PC Desktop
Hard drive boot failure
what is the error message? If operating system could not find, try you original windows installation CD, during you boot from the CD there is a repair option, follow the wizard to complete.
Sep 03, 2012 | Dell Dimension 2400 PC Desktop
No boot device available stike f1 to retry boot and f2 for setup utility diskette drive 0 seek failure a dell dimension 2400 series
Your computer cannot find a boot-able storage device, i.e. hard disk drive, to boot from. Either your hard disk drive is defective or the OS (operating system software) is corrupted and needs to be re-installed.
Jul 27, 2011 | Dell Dimension 2400 PC Desktop
What to do after installing a new hard drive?
Download and install the drivers from support.dell.com
Install them in this order
http://www.fixya.com/support/r4432358-proper_order_install_drivers_dell
Apr 04, 2010 | Dell Dimension 2400 PC Desktop
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
I have a PC Dell Dimension 2400 with a hard 40 GB
Basically when you install a new boot drive you need to install Windows operating system on the new hard drive, also the device drivers (eg video, audio, modem, LAN etc), your programs and data. The reason programs has to be installed is because the installation process copied DLL files to the System folders and makes changes to the registry.
You can only copy your data onto the new hard disk.
To avoid copying your data to the new hard drive, you can set up the old hard drive as second hard drive (ie. slave drive), if you delete the redundant folders and leave only the data folders then you have an adddition 40Gb of disk space.
Aug 27, 2009 | Dell Dimension 2400 PC Desktop
HOW DO I REMOVE COVER OF 2400 TOWER,INSTALLING 80G HARD DRIVE
Here’s a link to the service manual for 2400: http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/rmvcvr.htm
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
847 people viewed this question
Alun Cox
