Question about HP DesignJet 1050c plus InkJet Printer
SYSTEM ERROR 0B000D 00000001
I try unplugging, restart but nothing works. Need help urgently
  • 447 Answers
This is the HP page related to your error code.
Posted on Feb 23, 2009
System error 0B000D 00000005
Hi, I believe this error occurs when there is no 24 volt supply to the PCB. Go back and check you have plugged all the connectors back in correctly.
Thanks
Sep 29, 2014 | HP DesignJet 1050c plus InkJet Printer
What does system error 0b000d 0000001b mean on my hp 1050c
sounds like the service station siezed and the control circuit to the motor has burned out- common fault for this machine- unfortunately this means its cheaper to buy a new machine than it is to repair- sorry
Dec 14, 2013 | HP DesignJet Office Equipment & Supplies
0b000d 00000012
Hello. 0B000D error during start-up indicates a 24VDC failure. This is generally caused by a failed DC power supply. There are 2 types of power supplies - 1 for the 1050C series and 1 for the 1050C Plus series. They can both be found at: HP Designjet 1050C 1055CM repair parts
Oct 11, 2013 | HP DesignJet 1050c plus InkJet Printer
My laptop turns off when charged
Computer restart due to overheating:
Computer restarts due to over-heating when the processor fan goes faulty.Computer restart due to faulty RAM:
Computer restarts abruptly if RAM goes faulty, or if you install some in-compatible RAM or more than one RAM modules of different frequency or type.
Computer restart due to faulty Hard-disk:Faulty hard disk is one of the most common reasons for abrupt computer restart. Run a hard disk scan to fix this issue. If there are bad-sectors on your hard-disk, its the time to get it replaced. Computer restart due to overheating up of hard-disk:
Apr 05, 2012 | Computers & Internet
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced] "ServerAdminUI"=dword:00000000 "Hidden"=dword:00000001 "ShowCompColor"=dword:00000001...
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Dec 06, 2010 | Brother Office Equipment & Supplies
Hi all , My HP laptop auto shuts down when i open microsoft words , why is this so ? can somebody pls help me ? I need todo some work on it urgently!! , Thanks !!
You will need to press the F8 key before windows starts to load then disable
the auto restart on error. That will allow you to read the error message and
someone may be able to guide you.
You could also try booting from the XP CD and run the recovery console (if
that's an option) once in the recovery console type chkdsk /r to correct any
errors & try booting again.
OR
Disable automatic restart on system failure. This should help by
allowing time to write down the STOP code properly. Right click on
the My Computer icon on the Desktop and select Properties, Advanced,
Start-Up and Recovery, System Failure and uncheck box before
Automatically Restart.
Do not re-enable automatic restart on system failure until you have
resolved the problem. Check for variants of the Stop Error message.
An alternative is to keep pressing the F8 key during Start-Up and select
option - Disable automatic restart on system failure.
If you are using a wireless keyboard and the F8 key does not work
substitute a wired keyboard and mouse for this exercise only.
Please prost your feedback.
May 19, 2010 | Computers & Internet
Asus k50ij webcam image upsidedown
I have the same problem with my laptop Asus K50IJ, and apparently we're not the only ones. It seems that the only solution is manycam.com, as lifeframe utility or driver installations don't solve anything. Hope it helped!
Jan 30, 2010 | Computers & Internet
System error 010023 00000001
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
CF
Jun 27, 2009 | HP DesignJet 3500cp InkJet Printer
System Error 0B000D 0000000D on display, nothing prints
Hello.
From the service manual:
System Error: 0B000D
Problem
Description:
24 V source test failure.
Corrective Action: Replace the Electronics Module
HP Part number: C6072-60146
I just looked up the pricing and it's not cheap. Let me know if I can be of further assistance.
May 28, 2009 | HP DesignJet 1050c plus InkJet Printer
HP DesignJet 1050c plus InkJet Printer Logo
605 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
