Question about Homedics PA-4H Programmable Percussion Massager with Heat
Can't disassemble massager.
I need to replace a power cord on a hand held homedics massager. No screws are showing. How do i take it apart?
I don't have the Homedics programmable, but I have taken apart my Brookstone programmable (and lots of old Homedics massagers).
I'm going to guess the screws concealment method is similar. On the under side of the massager, look for small oval-shaped outlines that are the same color as the rest of the body. Mine had four. These are little plastic plugs that you can pry out with a tiny flat screwdriver or a razor blade. The screws are hidden under these plastic plugs.
I hope this helps
Posted on May 25, 2009
  • 24 Answers
HoMedics PA-4H has 5 Phillips screws on the head and 2 Phillips screws on the handle.
The handle has a rubber grip that covers one screw, you can take the rubber grip off by sliding it towards the power cord (with a little force and some patience).
Once all 7 screws are out, unscrew the two plastic vibrating "heads" then gently open the housing.
You will need a soldering iron to unsolder the power cord from the pcb.
Hope this helps. Good luck.
Posted on Oct 02, 2014
Massager service manuals
If you go to Homedics website you should be able to find downloads for the manual you require.
Nov 05, 2014 | Homedics Health & Beauty
The electric cord on my hand held percussion HoMedic Masager is loose. How can I open it and fix it?
What is the model of your HoMedic Massager?
If it has a rubber grip on the handle, you can take it off by simply sliding it towards the power cord, with effort and a little patience.
Once the rubber grips are off, you will find 1 screw hidden under the grip, 1 screw near the power cord, and 5 screws on the head, take all the screws off.
Once you've unscrewed all of the screws, unscrew the 2 vibrating heads then take the unit apart.
Good luck.
Jul 22, 2014 | Homedics Health & Beauty
Hi, I have got brand new Homedics shistsu massager cushion (MCS-360H). When I am plugging it in, I can see that power button in the remote is not getting started. Can you please assist me with this...
Hopefully you've got the right model listed here, as the MCS-360H is a Swedish Massage Cushion.
Did you remove the screw from the back of the unit before plugging it in...? The unit will not work properly until that screw is removed, and could be damaged if it is operated with the screw in place.
Here's the manual -
http://www.homedics.com//media/documents/homedics/instructionbooks/MCS-360H_IB.pdf
If removing that screw does not make the unit operate properly, contact Homedics Customer Service at 1-800-466-3342
Oct 02, 2017 | Homedics Shiatsu Massager
Can Homedics Therapist Select? Shiatsu Pillow with Heat be used under 220 V power? Thanks
If it is set up for 110 volts, you should not use it on 220. Most likely you will burn the motor out in a matter of minutes.
Jan 24, 2010 | Homedics PA-4H Programmable Percussion...
The cord on my massager is tearing. Can I get it
It kinda depends, You might be able to bring it to a store where they will repair it for a costly charge. If you are okay with working with your hands however, you can dismantle it yourself and just repair it yourself. How you would do that is, to take it apart screw by screw until you get the power supply out in the open and just wrap the wires that are torn with electrical tape and then just close it back up. MAKE SURE YOU UNPLUG THE UNIT IF WORKING ON IT
Jul 08, 2009 | Jeanie Rub Single Speed Massager
How to replace power cord om homedics massager
This is a test by FixYa Staff.
MODS - DO NOT REMOVE
Thank you!
Jun 20, 2009 | Homedics Inc Massager Neck Massager W/heat
Hand held massagers question
The unit is not a toy and should not be used by children without adult supervision. Also, it is unsafe to use this product on adults and children while they sleep. You should NEVER use the massagers while you are asleep.
Aug 27, 2008 | Homedics PA-4H Programmable Percussion...
Homedics PA-4H Programmable Percussion Massager with Heat Logo
2,791 people viewed this question
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
