Question about Rinnai RHFE-556WTA Direct Vent Heater NG Air Conditioner
Rinnai 556 WT Energy Saver Heater - Error Code 11
I have a Rinnai 556 WT Energy Saver Heater and it is giving me an Error Code 11.
Can you advise how to fix it?
  • Perry Putnam
    Perry Putnam May 11, 2010
    Ok I found that code 11 is an ignition failure. Turn the power to the system off for a few seconds then on and watch closely to see what it does.
  • Perry Putnam
    generally there is a code list either on the inside cover or in you manual. What does it say a code 11 is?
ginko
  • 19396 Answers
SOURCE: rinnai enerysaver 556 FTR no manual
Here is the user manual Energysaver RHFE-556FTR
Here is also the repair manual RHFE-556 FTR RHFE-556 FM RHFE-431 FT
Posted on Oct 14, 2008
early1234
  • 871 Answers
SOURCE: Heater and Air Conditioner
yes it does
check here... here
Posted on Apr 01, 2008
  • 417 Answers
SOURCE: how many kw has my
Hi
The answer is 2269 kilowatt hours.
1 kilwatt hour = 3.6 mj
Don't forget to give this solution a rating.
Posted on Oct 22, 2008
  • 66 Answers
SOURCE: Rinnai energysaver 556 wt. propane heater stopped
Check your filter ,and clean it. A system must be able to breath.
Posted on Feb 16, 2010
  • 4736 Answers
SOURCE: Code 11 come out from the led. The heater rinnai
A couple of things can cause a Code 11(Ignition Failure): The gas line at the heater is not turned On or not turned on all the way. Also an obstruction in the Direct Vent Termination.
According to the Owner's Manual:
If the appliance fails to ignite, the appliance will attempt ignition after 1 hour. The "Ignition Failure" fault code, 11, will appear during that hour and disappears after a successful ignition. If ignition fails again, then the fault code will remain and another attempt to ignite will occur in 1 hour. The fault code is not stored in the fault code history.
If the flame is extinguished during forced combustion then the appliance will attempt ignition after 1 hour. The "Ignition Failure" fault code, 11, will appear during that hour and disappears after a successful ignition. Forced combustion takes place for about 15 seconds after ignition. After this time, the temperature control logic controls the combustion.
If the flame is extinguished (burner combustion failure) while the temperature control logic is operating the appliance, then the appliance will immediately attempt ignition. No fault code will appear.
If the problem was not either of the 2 listed above, the electronics may need to be reset. You can do this by turning the Master ON/OFF Switch to OFF and unplug the cord from the wall outlet. Leave the unit unplugged for 15 minutes, then plug it back in and turn the Master ON/OFF Switch to ON. The electronics should revert back to the original factory settings. From there you can set them as you like. If the reset attempt fails, a service call by an authorized service technician is the next step.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Posted on May 31, 2011
My rinnai 556 will not start, the only light is with the child lock pressed, on/off does not light? any ideas?
HI, Dear your rinnai 556 is not starting thats why it can not genrate the error code ,i advice you in this case you can not identifiy the exact problem. but i m trying to help you with my best tring:-
What you need to do -
Check the model number and serial number which are found on the data label located on the bottom of the right hand panel of the unit. Any Rinnai Energysaver Models RHFE-556T and RHFE-556FTRG Gas Air Warmers with a serial number contain the the year (YY) digits "00" to "07" may be affected. If you cannot read the data label or think you may have an affected model do not use the Air Warmer and inform anyone who may use the Air Warmer that they should not do so. Contact the Rinnai freephone helpline for further instructions, even if you have not experienced any problems
HELPLINE 0800 0304 556 or you can visit http://www.rinnaiuk.com or email project@rinnaiuk.com if you have any further questions.
The helpline staff will validate whether you have an affected product and will arrange for a Gas Safe Registered Engineer to visit and replace the gasket in the air Warmer.
i hope this will be helpfull to you. PLEASE DON'T FORGET TO VOTE ME. GOODLUCK..............
Jan 21, 2011 | Rinnai RHFE-556FAIII 21,500 BTU Ductless...
What does it mean when the power light (the small round light on the front of the heater that indicates the heater is on) is red instead of green?
was reading a rinnai pdf today about this, green means that the unit has power the red means the burner is operating so it just tells you when the gas is going basically, may not be the same for this rinnai model but is on the energy saver 556 so hopefully that explains your heater for you it should be in the owners manual if you have one as pdf i was reading was manual for another rinnai if you don't have a manual you can try downloading just type heater name and model into your google search with manual mentioned there too should bring up a pdf or a link to manual
Nov 16, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a rinnai energy saver 556f our power blew out and it knocked out all our appliances.i am trying to get my rinnai to stay lite but the pilot wont stay on.it goes on for about 3 seconds and then cuts...
Patrick,
Your 556 does not have a pilot light. When you try to start look into the window, you should see an arcing, this is the igniter. With a power outage there is no telling what may have happened. With only limited knowledge of a gas heater you should call a Rinnai service guy.
Good luck,
Tom
Oct 12, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 1004 F Error Code 11
Code 11 is that the unit is trying to light but does not sense a flame after 5 seconds. Usually means you have run out of gas if you are bottled gas. Check your bottles are turned on if you are on LPG, you might need to change over manually. Have you anything else on gas?
Jul 01, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Looking for Manuals
Google rinnai 1004 and 556 manuals. I just did and found them
Nov 26, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 403 FT
who did you talk to at rennnai?
let me know i deal with them on a buisness leval.
Mar 27, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Error code 11 on my rinnai
A code 11 also means that it might not be getting any gas. On thr right side of the unit you will find a small door. open it up and make sure the valve is in the open position. If it is, you should contact your gas company to come and diagnose what is going on. The Rinnai is not a do it yourself fix it type of heater.
Nov 06, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE-556WTA Direct Vent Heater NG Air Conditioner Logo
925 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
