Question about Microsoft Windows XP Home Edition
Black screen on monitor
I turn it on and I get a color display that says no signal ;then screen goes black ;the tower and the monitor are on but the screen is black
  • Microsoft Master
  • 4,806 Answers
Hi there
Remove the side panel from the desktop and clear the cmos >>> black screen on monitor - cce5f1a.jpgmove the plastic jumper to the other position, and turn the machine on, if nothing happens, you have cleared the cmos, put the jumper back in its original position and see it the PC boots. If there is no Jumper, take the battery out for an hour.
Remember to remove the power cord before you take the side panel off.
Post back with the results please
Good luck and thanks for using Fixya!!
Posted on Feb 23, 2009
I have a acer.x223w when,it powers up the.screem stays black, n i get a blue blinking light on.the bottom
I disagree with ikkenom only due to the symptom of the flashing blue light. This would indicate to me that the monitor is not getting any display signal and is in sleep mode at least the is what happens on my Samsung monitor. Used to be that they use a two color led in the monitor, green when ON and getting display signal and amber or orange when in sleep mode. I would check the computer by trying a different monitor. If you have a second monitor, great, if not, maybe a friend will let you bring your computer over and try the computer with their monitor. Could also be a display adapter setting. Do you get any change when you first turn on your computer? i.e. Do you get the BIOS or manufacturer screen when first turned on? Also if you disconnect the monitor cable from the computer and power cycle the monitor, do you get a No Signal display for a few seconds before the monitor goes black and the blue light starts flashing?
Let me know what happens with the testing above or if you need further instructions to carry out testing.
Thanks, Jim
Feb 21, 2013 | Computers & Internet
One of the two monitors will cease displaying screen image and begin rotating between a BLACK/WHITE/GRAY/Primary Color Bars every other second following a few minutes after start up. Have tried Restar
It might be the input from the graphics card. Try swapping the two monitors' feeds to see if the problem is with the monitor or the card. The monitor seems to be going into a screensaver mode since there's no signal. The flashing light could mean there's a power supply problem, or no signal.
Oct 15, 2017 | DoubleSight Displays Computers & Internet
Describe your dell dimension E521 wont boot and Problem my computer turns on but doesn't open it goes to a black screen with little flashing bar in top left corner nothing new was installed but there...
The 123 lights on tower translates as:
Routine system activity subsequent to video initialization.
Watch your monitor for on-screen messages.
Disconnect the video cable from the computer and see if you get floating color bars on display. If not, your monitor is defective.
Jan 10, 2011 | Dell Dimension E521 PC Desktop
Dell E171FP Monitor goes black after 2 secs
Hi, I don't think the problem is with your monitor. Your monitor sounds like it's doing exactly what it's supposed to do. The monitor is supposed to turn off if there's no cable attached, which means there's no signal input. When the screen goes black, does the power light stay on and turn orange? or does it go off as well? I would recommend that you lower your screen resolution to 1280x1024 or lower in the Display Properties window, then remove your primary monitor, and connect the monitor to your desktop computer. You should see it light up when connected. The monitor auto-senses when there's a computer attached to the cable and when there's a signal. If it doesn't see a signal, it goes black to save power.
Jun 17, 2009 | Dell E171FP 17" Flat Panel LCD Monitor
Monitor wont display a picture
plz try by resitting the ram if it doesn't work then *********** board require servicing
Mar 16, 2009 | Microsoft Windows 98 for PC
chack your ram
your display cord may be damaged or loose chack it
Feb 23, 2009 | Computers & Internet
Black Screen
No, this is typical problem for defective inverter. Mostly screen appears for some seconds and then turn to black. If you are technician, you can use this link :-).
http://www.lcdrepair.us/1702inverter1900x.html
Oct 01, 2007 | Dell 1703FPs 17" TFT LCD Flat Panel...
Monitor Acer Problem
I agree it isn?t the monitor but I would suspect the video card you are connecting it to or the PC itself. Generally if a monitor doesn?t detect a video signal it will go into hibernation mode, typically displaying a no signal warning and changing the LED color from green to amber. When you start the computer is anything displaying at all? Are you sure the PC is powering up and booting?
Jul 22, 2007 | Acer AL1916W 19" LCD Monitor
Microsoft Windows XP Home Edition Logo
63 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
