Question about RCA M4208 MP3 Player
Only playing music on the right speaker
RCA M4208 - This used to play music on both speakers and now it only plays it on the right side of the head set. Can't figure out how to get it back to both sides playing music.
  • 3 Answers
Its the headphones, It happened to me a new set of headphones worked.
Posted on Feb 23, 2009
I accidently put the rca wires in the wrong audio input/output on my craig cd graphics karaoke player.Could this be why i have no sound?
The RCA outs are designed to send a signal to an external amplifier. That amplifier, in turn, sends the music signal to speakers.
The RCA inputs are designed to take audio signals from another device (like an ipod, CD Player, or computer) and play it through the Craig System speakers. If you sing into the microphone, the vocals will be mixed with the incoming music. However, in these cases, there won't be lyrics on the screen. If you play a karaoke DVD in a DVD player, connect the red, white and yellow RCA cables from the DVD out to the Craig Inputs, the lyrics should appear on the Craig screen while the music plays.
If you mistakenly plug RCA cables into the Craig Inputs and plug the other end into an amplifier's inputs, neither will produce any sound.
Using RCA outs is only necessary if you want to have louder music than the on-board Craig speakers can handle. Of course, you can run the yellow video cable to a TV RCA input to get a bigger lyrics window and the RED and White RCA to the TV RCA Red and White inputs to hear the music through the TV's speakers.
Aug 30, 2014 | Audio Players & Recorders
Hi is it possible to connect a laptop to a denon 700aedab for music playback
HI, very possible. Just follow this instruction:
All yo need to use for the connection is to get an RCA TO STEREO JACK HEAD (use the google image to see the type of cable).. Connect to denon 700aedab, make sure that the denon 700aedab is on either aux, tunner,video,etc. Those auxillary options on your denon 700aedab.
Connect the RCA into the aux of the denon 700aedab and connect the small jack head into the laptop ( where you plug in earphones),and play and enjoy your music.
If it does not play with aux try tunner, or video, one mustplay,and if it does ot play any, that means either the port of your laptop or the denon 700aedab port is faulty.
And don't forget to connect the speaker,because diffidently you will sure hear absolutely nothing with out the speaker.
Feel free to pass your comment .
Thanks for using fixya.
Jan 10, 2011 | Denon Audio Players & Recorders
Hi. Today I bought a 3 foot audio y-cable and an RCA (Phono) Female to RCA (Phoneo) Female cable so that I could hook up these two speakers that I have that belong to a predisian sound system (boom box)...
All you need to do is get a USB based sound adapter 16/32BIT MINIMUM to plug your speakers straight into your laptop with better sound. Many laptops will have limited sound OUTPUT which places large limitations on pushing sound through your nice speakers. You already know the problem is not the speakers or new cables, therefore you know that problem has been isolated to your laptop. You may also check the volume settings in the laptop to ensure your running the highest possible BIT or volume enhacement software. Let me know if this does the trick for you.
Jan 09, 2011 | HP Audio Players & Recorders
My apple iPod nano 5th gen wont play music through the headphones right. It only plays through the internal speaker even with the headphones in. I can hear it through the headphones a little but it is...
take the headphones out play the music full volume then put the headphones in and lower the music all the way down then your volume will be normal and it will only play in through the head phones unless you take headphones out then it will play through speakers
Aug 30, 2010 | Apple Logitech Inc MM50 Portable Speakers...
The speakers on the left side of my technics stereo have stopped working and are making a loud humming sound while the speakers on the right side still play music normally model number is sa-120 and the...
Check the input cables from the source you are playing at both ends. Sounds like an input problem, not a speaker problem. Twist the RCA connectors as you push them in to make sure the connection is good.
Aug 29, 2010 | Audio Players & Recorders
My new Ipod Classic won't play from both sides of
Maybe The head phone port is different in your ipod
maybe try a different sound cord
Mar 12, 2010 | Apple Logitech Inc MM50 Portable Speakers...
When I play CD only the right speaker is play but
first- is the tuner set to mono or stereo? if stereo, stop using the analog rca jacks and use an optical (toslink) cable to transfer your audio to your receiver. almost all cd players have this output and the same with the receiver. better still, if you are using a late model cd or bluray, and your receiver has hdmi inputs use those as they will transfer both audio and video with one cable.
Oct 29, 2009 | Sony STR-DE575 Receiver
Music plays through speaker when receiving messages
its tha connection from your head set to ur fone move it around till u hear it beep in ur head set then it shud play in ur head set hope dis helps
Mar 22, 2009 | Nokia N79 Cellular Phone
Back rear speaker wont play when singled out. more details inside
I would suggest you mdisconnect the rear speakers from the amp, take a 9volt battery and click te speakers on at a time. If proble duplicated, the you have the left speaker tied to the right somewhere.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 26, 2009 | Clarion EQS746 Equalizer - 7-Band In-Dash...
Mp3 player only plays on right side speakers
Have you tried a different jack? It could be faulty.
Aug 11, 2007 | Pioneer DEH-P6800MP CD Player
RCA M4208  MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
