Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
The fridge section is getting too cold at the bottom
LG side by side fridge freezer
Goods placed in the bottom part of the fridge will freeze the food that is placed in it?
    Sergeant:
  • 359 Answers
THE CONTROL THAT DIVERTS MORE AIR TO FREEZER AND LESS TO RE-FRIG SIDE COULD NEED TO BE ADJUSTED TO KEEP MORE AIR IN THE FREEZER SIDE , MAKE SURE ALSO THAT THE SMALL FAN IN THE FREEZER IS RUNNING , ALSO TURN THE THERMOSTAT CONTROL TO LESS COLD , IF YOU HAVE A THERMOMETER TO PLACE IN FRIG SIDE TRY TO KEEP @ APP 40 DEGREES IN FRIDGE SIDE SEE IF ANY OF THESE HELP
Posted on Feb 24, 2009
I have a 23' free standimg dispensing side by side ref. my ref is not cooling but the freeze part is working
when you open the freezer door do you hear the fan blowing?all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer and into the fridge side,there are ducts on the bottom left side where the air return sto the freezer,if that's blocked the fridge will get warm,also if the fan is blowing depending on your model you could have a damper,it's in the fridge section up top where the cold air blows into,all it is is a door that opens and closes to let the air in when the fridge section gets warm and then it closes when it's cold enough,if the damper is bad it won't open and let the air in,sometimes it gets stuck in the open position and things start to freeze in the fridge section.if you can't figure it out send the model number and i can see what model you have,open the fridge door,look up on the right side near the ceiling and you should see a tag with the model number.good luck and have a great weekend.also from the bottom up in the freezer,remove the second bin of food and touch the back inside wall of the freezer,if there's frost or like snow on the back inside wall of the freezer you have a defrost problem,let me know what you find.
Aug 07, 2012 | Kenmore Refrigerators
Refrigerator food freezing even when on lowest setting
There is one of three reasons why your fridge section is freezing food. You didnt mention whether you had a side by side or freezer on top or bottom model, so the following checks may not apply to your unit.
One reason food might be freezing is your cold control has failed, and will not turn the unit off when the physical temps are correct. When this occurrs food normally freezes throughout fridge section, top, bottom, middle, front and back.
BOTH controls, though you may only have one, should be at the middle setting. Adjust your controls, place a plastic cup of water at the top, the middle, and bottom shelf of your fridge. Check all three AFTER 24 hours. if all three are ice, you COULD have a bad cold control.
It is possible you might also have a door damper that is stuck open. A door damper is a swinging or sliding door that opens / closes either when temp control settings are adjusted, or on some fridges, when either door is opened, the damper closes. Please note, door dampers are USUALLY only present on side by side refrigerators. They can have a motor, or thermostat open the door automatically,which can break, and others will simply have a lever of some sort, which usually wont.
If after 24 hours, only the middle and bottom cups are ice, your evaporator fan motor, in the freezer, is likely not operating. Not knowing the BRAND you own, it could be the motor itself, a thermostat located on the evaporator, your defrost heater, or a main computer control board that controls the fan motor.
Sorry I cant be as specific as id like, but i had to cover all possible bases
Oct 16, 2011 | GE HSM25GFTSA Side by Side Refrigerator
Fridge is set at 44 ,freezer is -4 and the food is frozen in the fridge. can't get fridge to stop freezing all the food,what temps do I need to set?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Feb 01, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
LG GR431SCA fridge will not cool properly and top half of freezer and ice maker section will not freeze. The bottom half of the freezer (below the shelf) freezes well, but above the shelf and the ice...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 04, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
Lg fridge freezing food in freezer section
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for
the cold control and the air deflector, As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control
Hope this helping solving the problem.....
Aug 15, 2010 | LG LRSC26922S Side by Side Refrigerator
My fridge is freezing food in the fridge section. The eggs closest to the freezer are all frozen, vegetables are frozen.
the cold control and air deflector, As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this help in solving the problem....................
Fridge is freezing food
Make sure nothing fell below your crisper, deli drawer section. There are some air return vents below them and if they get partially obstructed would allow cold air to pool in the bottom of the fridge.
Make sure your freezer control did not get turned up too high.
Also you may want to check with the manufacturer as they did have some issues with some of the bottom mount models exhibiting this problem and they developed a repair kit for them.
Jun 11, 2010 | Amana ABB1927DE Bottom Freezer...
Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer will not keep foods frozen fridge will not keeep temp.
Sounds like a main control board problem keeping the freezer fan from working . If no air flow to the top of the freezer , the icemaker will stop working and the ice will begin to melt ( leaking from freezer ) . The coils will start to freeze up due to no air flow across them . If continued for a period of time , the cold air could return thru the return vent located in the bottom of the ref/freezer section and freeze the water tank in the refrig section , causing the no water thru dispensor .
Jul 11, 2009 | Hotpoint HSS25GFP Side by Side...
Side-by-side fridge is freezing food on bottom shelf
Look to the freezer section for a possible frosting on the back wall. If you have a defrost problem in the freezer and air circulation stops cold air from the freezer may settle through the return area of the duct between the refrigerator and freezer section because cold air is heavier the warm air. Normal circulation follows a clockwise pattern.
Also your setting of the refrigerator temperature may be set to cold. Once again cold air settles to the bottom.
Jun 02, 2008 | Whirlpool Refrigerators
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
252 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
