Question about ECS C51GM-M Motherboard
Frame that hold cpu on to circut board,,mother board , broke and cpu fell to bottom of case..need the fram that fastens to mother board /with 4 screws . thanks , tat
  • 24 Answers
Http://www.frozencpu.com/products/6553/bra-18/CPU_Fan_Retainer_Bracket_w_Backplate_-_AMD_AM2.html
This site sells what you are looking for.
Posted on Mar 05, 2009
Front seat can't move forward
The problem is that the wire that's spring loaded under your seat has broken or failed same thing here's is how you can fix it now unbolt 4 bolts that hold the seat in place then unplug the wires from the harness connected to the seat find a chain smaller of course than a dog chain from the bottom u will see where the wire broke it will b a dead giveaway now take the chain reconnect it to the two sides left and right move the lever but b careful because the two won't move in tandem they will move away from each other watch out for your fingers and hands fas it happens quite fast so word if u are not technical take it to somewhere that is thanx Chris
Feb 23, 2014 | 2007 07 Chevrolet Cobalt Cabin Air...
Best supported processor for gaming?
For CPU upgrade it is hard to say without more information. These machines can have several different mother boards. Take a look at the mother board and find a Model number. With what you gave it looks like it runs a Pentium 4 641.
However, when systems get slow they may need a clean out. I use CCleaner to clean excess files and the registry out. But make sure to have a backup.
Other then this speed for gaming depends on what type of CPU, memory (RAM), motherboard, etc. that you have. There are so many products on the market, so exact details are needed to see what is slowing you down. Also, if frame rate, FPS, is an issue then, Do you have a video card that is not integrated on the motherboard?
Dec 29, 2013 | eMachines T5088 Motherboard Replacement...
I have a hunter air purifier model number 36316 and need to know how to change the filter
Hello, this is Ava with Think Crucial.
To change the wick filters of your humidifier:
1. Turn off the unit and unplug it from the wall outlet
2. Remove the tank for the housing.
3. Locate the 3 lock tabs in the base of the unit. Turn them clockwise until the base of the tab lines up with the indentions in the base and lift off the housing.
4. Locate and turn the lock tab clockwise on the base holding the wick fram. Remove the wick frame and set it aside.
5. Remove the old wick by pulling the bottom of the wick out of the frame first and discard.
6. Insert the new wick top first. Ensure wick is in between the tabs at the top of the wick frame then slide the bottom part of the wick into the fram, making sure not to crush the bottom corners of the wick.
7. Reassemble the unit and refill the water tank if necessary.
8. Turn the unit back on and resume operation.
You can purchase a wide variety of high quality Hunter replacement parts for your Hunter Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?page=1&q=hunter&type=product
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Dec 16, 2013 | Holmes Products HAP422-UC Air Purifier
Left earbud has no sound
I had this problem with 2 of my HBS 700s. The speaker in the earbud goes bad and needs to be replaced. If it is still under waranty you can send it in to be replaced (trying a home repair will probably void your waranty so try this at your own risk). If it is out of waranty and you have experience with a soldering iron, the earbuds can be replaced with a plain set that look similar to the originals from your local store (Wallgreens has a good selection for like $10). I am a novice at these things but the solution was pretty easy and has worked for both of my earbuds. I actually improved the quality of sound by installing better earbuds.
3d9a9467-2679-44c4-ba93-679ba93f6b9d.jpgYou will need:
- 1 small soldering iron
- one set of new wired earbuds (no volume control or mic... just plain earbuds)
- jewlers phillips head screwdriver
- one small flat screwdriver or thin flat edge to pry the cover off.
- one needle or thumbtack
Directions are the same for both sides. I suggest doing one side at a time and repeating the steps for the other side.
Directions:
- TURN OFF HBS 700
- locate the rubber plug on the bottom of the case (one on each side above the L and R symbols) and remove the plug with a needle.
- remove the screw located under the plug
- use a jewelers flathead screwdriver or thin flat edge to pry the case appart. The best method is to gently pry the bottom of the case outward then push in and up on the top part of the case starting at the back of the plastic case (where the earbud wire comes out) and working your way forward.
- remove the earbud cup and set aside. (if working on left side, also remove the charger door.)
- the circut board is held in place by plastic arms on the sides. Gently pry the circut board away from the case and lift up where the arms are holding it in place.
- once case is removed from circut board, you will see where the earbud soldered to the board.
NOW FOR THE FUN STUFF...
-cut your replacement earbuds to length and expose about 1/4" of the two wires inside (usually one gold and one colored or one solid color and one multi colored).
-The two wires are coated to prevent them from shorting out while touching. Add solder to your soldering iron so there is a good drop hanging from the tip. Insert one wire at a time into the drop of solder (about 1/32" will do) and hold it there for a few seconds. This will melt the coating and allow the solder to stick to the wire.
BE CAREFUL NOT TO SOLDER TOO MUCH OF THE WIRE OR IT WILL TOUCH THE OTHER AND SHORT OUT! ONLY A LITTLE ON THE TIP OF THE WIRE WILL DO.
-carefully use the soldering iron to remove the old earbuds from the circut board. A small soldering iron with a sharp tip works much better than the standard size at this. The soldering points for +/- are VERY close together so becareful not to melt them together.
-solder the new earbuds in place of the old ones. + to + and - to -.
-tie a knot in the earbud wire close to the circut board so it does not pull free from the case when closed.
-at this point in my repair, I turned the HBS 700 on to listen for the startup tone to make sure the earbud was connected properly. I DO NOT RECOMMEND TURNING IT ON OR TOUCHING COMPONENTS WHILE IT IS ON. IF YOU WISH TO CHECK IT AT THIS POINT LIKE I DID, DO SO AT YOUR OWN RISK. ALSO, MAKE SURE NOT TO HOLD THE CIRCUT BOARD OR TOUCH IT WHILE IT IS ON AND TURN IT OFF BEFORE CONTINUING.
NOW IT'S TIME TO PUT IT ALL BACK TOGETHER.
-reinsert the circut board to the top cover in reverse of how you took it out. Do not force it and make sure all the plastic arms clip over the circut board securely. Make sure to press the buttons to see if the are seated right.
-replace the earbud cup, battery door and power switch if it fell off.
-attach the bottom cover making sure to leave the knot on the inside of the cover. The cover should snap on easily.
-Re-insert the screw and plug.
DONE!
If you wish your new earbuds to attach magnettically to the cup, you will need to break open the old earbuds and remove the magnets from inside. Then glue them to the outside of the new earbuds or drill a hole for them to sit in and glue them in. Be careful tho because drilling holes too deep in the new earbuds could damage the wires inside (I found that out the hard way)
I hope this solution was helpful
Oct 17, 2013 | LG HBS-700 Bluetooth Headset
My phone sony erissson c902 can't sent msg
Instructions
things you'll need:
* Phillips-head screwdriver
* Torx T6 screwdriver
* Credit card
Hold down the phone's power button until it shuts off. Place the phone so the back side is facing upward. Remove the back cover and remove battery pack from its compartment inside the phone. Slide the SIM card out of its slot inside the battery compartment. Set it aside.2
Loosen all screws from the phone's back casing. Depending on your exact phone this will include either Phillips or Torx T6 screws. Remove the back casing to reveal the internal circuit board.
* 3
Remove all screws fastening the circuit board to the phone's casing. Unplug all ribbon cables from the visible side of the circuit board. Lift the circuit board out of the phone's front housing and unplug the the ribbon cables from the opposite side of the circuit board. This disconnects the keypad and LCD screen from the circuit board. Remove the board from the phone's casing completely.
* 4
Flip the phone over, and insert a guitar pick or credit card into the gap along the outside edge of the phone's front housing. Use the pick to pry the front housing from the phone to reveal the keypad and LCD screen. Remove the two to four screws fastening the keypad to the phone's frame. Lift the keypad out of the phone and set it aside.
* 5Use the guitar pick to gently pry the LCD screen out of the phone's frame. Set it aside.
Apr 23, 2011 | Sony Ericsson Cell Phones
When I power up, it starts @ the "safe mode" screen then when I make a choice after a few seconds, it shuts down. My wife noticed last night it was hot to touch. I thought nothing of it until this...
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
As the fan is not moving,computer is running hot so it is shutting down.Need to check the fan cable, reset the cable,if it works it is fine,other wise need to replace the fan.
Disassembling the Lower Case Assembly
  • Disconnect the Bluetooth cable from the main board.
Sep 26, 2010 | Acer Aspire 5050-3242 Notebook
MOTHER BOARD FOR CPU RUNNING WINDOWS XP
1.0 verify first your processor first so we can work what mother board will fit to your processor,
2.0 if your processor is bigger than pentium 4,
3.0 windows xp will definetly run smoothly..
4.0 Thanks!
Jul 15, 2010 | Intel Motherboard
Model: TFX27PFSM BB Ice/water dispenser mother
The board will remove by prying at the bottom of the board . Sometimes I can use my hand only , pulling out from the bottom , to remove . Other times , I have to pry from the bottom to remove . Do not try to remove the dispensor frame , only the board .
Oct 10, 2009 | GE Profile CustomStyle PSI23NGR Side by...
Comp does not turn on. green light off but goes on when mobo disconnected
Test the power supply in another computer.
If that works, the next thing is to check the mother board. Remove all daughter boards from the slots. Remove all memory, disconnect all hard drives, cdroms, etc.
Make sure there is nothing plugged into the mother board except the video cable (if it is on-board video), if not, then make sure you have a good video card plugged in.
Again with no memory, no boards except a video card, if needed, and the power plugged into the board.
Turn on the power, and watch the screen. If it works, then you should get a notice that there is no memory, no hard drive, and so on.
If that is the case, then proceed to install one item at a time to isolate the problem. If it is not the case, the the mother board is probably bad. One other thing to check would be the CPU.
If you get no notice with the above, then the cpu could be bad. Check it in another computer, if possible. This should tell you what the problems are or is.
In the above cases, either the cpu or the mother board can be isolated to see what is bad, if any.
Oct 07, 2009 | HP Computers & Internet
Heat Sink Fan fell off
Any Pentium 4 fan will do. The pc will not boot without a CPU fan plugged in.
Jun 17, 2008 | EliteGroup P4VMM2 Motherboard
ECS C51GM-M Motherboard Logo
62 people viewed this question
Top ECS Computers & Internet Experts
David
David
WTF Chuck.....
WTF Chuck.....
Coss
Are you an ECS Computer and Internet Expert? Answer questions, earn points and help others
