Question about Kenwood NV-600 CD Shelf System
RIGHT HAND SPEAKER, DISTORTION.
Hello
I have a Kenwood hifi system NV 600 which I have had for some ten years, recently the right satelite speaker has been distorting badly, I have checked the speaker connections at the speaker and at the hifi unit and they seem to be fine, can it be repaired or can I purchase a replacement speaker or do I have to buy a pair of compatible speakers to resolve this problem ?
Thank you
Keith
  • Kenwood Master
  • 5,449 Answers
First switch the speakers over to make certain it is not the amp that is the problem.
If the speaker is still playing up on the other channel, then I would look around at a new set of speakers. They can be any that you like the look of as long as they have a power ratting at 40 watts or above each. The amp says it can take 6 to 16 ohm speakers. I would go for 8 ohms as they are more common.
Posted on Jul 04, 2017
robotek
  • 1512 Answers
SOURCE: no sound from front right and left speakers
you may have a dc condition present on speaker outputs. this could be caused by dry solder joints, suggest blanket resolder of the output stages for front channels.
Posted on Dec 10, 2007
VOTIT
  • 2071 Answers
SOURCE: Cant connect my Kenwood NV-500 with my mp3 player ?
Yes it can be,always remember that the out of mp3 player is going to IN to your Kenwood NV-500...
Just click and choose whatever connection you want;
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ..
Plasma or Video Projector Wiring Guide
Blue-ray Surround Wiring
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Posted on Aug 21, 2008
  • 263 Answers
SOURCE: no connecting wires..????
They seem to have special leads to connect them together pretty expensive ....
http://cgi.ebay.co.uk/KENWOOD-B-B5-Connector-Hi-Fi-component-cables-lead_W0QQitemZ120453267078QQcmdZViewItemQQptZUK_AudioTVElectronics_HomeAudioHiFi_Tuners?hash=item1c0b92fe86&_trksid=p3286.c0.m14
Posted on Aug 03, 2009
SOURCE: Kenwood KVT-815DVD Unit only buzzes
I bought a Kenwood KVT-815dvd player and got everything hooked up to only find out that it had a security code. The problem now is that I got it from a pawn store and they did not even know that it had a security code on it. So is their a way I can bypass they password or just reset the whole unit so that it does not have one. Also, where is the memory for this unit?
Thank you
Posted on Dec 15, 2009
SOURCE: No sound....
maybe the amplifier IC are damaged
Posted on May 10, 2010
What is the wattage output of the kenwood ka 728 integrated amp?
Specifications Power output: 130 watts per channel into 8? (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.007%
Input sensitivity: 0.2mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 69dB (MC), 87dB (MM), 107dB (line)
Output: 150mV (line)
Dimensions: 340 x 109 x 369mm
Weight: 9.2kg
Year: 1984
Kenwood KA 828 Manual Stereo Integrated Amplifier HiFi Engine
Nov 15, 2016 | Kenwood Audio Players & Recorders
Kenwood KA-76 amp. Left channel distorts and unit overheats then shuts down when volume is turned up. Headphones are not affected.
what happens if you reconnect left and right speakers? Are these problems of the unit or of the speakers/wires?
May 10, 2015 | Kenwood Audio Players & Recorders
Connect tv to hifi speakers
It doesn't lokk like your TV has an analog out for your Kenwood system. It might have an optical out but unless the Kenwood has optical in then you'll need to upgrade to a Home theater system with HDMI.
Feb 03, 2015 | Samsung Televison & Video
Kenwood A722L no sound and volume led blinking
This could be due to a faulty speaker relay (if your unit uses one). Normally, the unit will "wait" a couple of seconds after you turn the unit on. Then you will hear a "click" and the sound will begin coming through the speakers. If the relay is faulty, it would cause the problem you describe.
Aug 01, 2014 | Kenwood Audio Players & Recorders
I have a Kenwood 106vr receiver. almost right after the warranty expired whenever I'd crank some power through it it would switch off with only the stand by light flashing. i put the receiver in storage...
It sounds like you blew it up. Ten years of sitting didn't heal it.
Does it come up with NO speakers attached? If not, it's cooked. Sorry.
If it does come up you need to isolate the short being presented by the speaker(s).
For the future, I'd take it easy on the volume and take a hint from its reactions. An audio device only has so many self-protecting emergency shut down cycles in it.
http://www.retrevo.com/support/Kenwood-106VR-Receivers-manual/id/478bh948/t/2/
Jan 06, 2011 | Kenwood 106VR Receiver
Does this boss chaos c550 amp match up to perform correctly with 2 12inch kenwood peak power 600 watt magnet 500g (17.6)oz impedence 4 ohm kfc-w300s speakers
It's not bad, but at 400 watts, it's a bit underpowered
It'll be plenty loud, but the amp will distort before the speakers do, particularly if your subs are wired in parallel (as dual-driver boxes are typically wired)
Listen for distortion, and turn it down a bit if the sound gets fuzzy or static-y sounding
Feb 03, 2010 | Boss C550 Car Audio Amplifier
Harman-Kardon HK695-01 Speakers Connection Quesion
According to the manual
http://tv.manualsonline.com/mdownloads/14ae515f-03bc-a2d4-8940-672bfa19f017.pdf
leave the black connector unconnected.
Hope that helps.
Oct 02, 2009 | Harman Kardon HK695 Computer Speakers
Kenwood XD V757 System Protected
check the speaker wires are not shorting out
Dec 11, 2008 | Audio Players & Recorders
Starting system cold, no sound for 2-3 minutes
Its not worth having it looked at. $100.00 for a new 400.00 unit? My unit is doing the same thing. Turn it on and 2 to 5 minutes later it may come on. Change to video 3 4 5 etc it stop again. Only works with a cold start. Something in the unit has failed and is heat related. My original Kenwood 20/20 recevier still works. Must be 40 years old. New products just last 5 to ten years max if your lucky.
Dec 17, 2006 | Kenwood VR-6070 Receiver
Kenwood NV-600 CD Shelf System Logo
79 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
