Question about Samsung RS2534 Side by Side Refrigerator
Samsung fridge freezer fridge is registering 13 and not cold
Water dispencer has also stopped working
  • 700 Answers
YOU WILL HAVE TO THAW OUT THE FRIG SO THAT THE WATER WILL FLOW THROIUGH THE TUBING TO THE DISPENSER.
Posted on Mar 07, 2009
I have a samsung fridge freezer model no RSH1DTMH and the fridge will not go lower than 13degrees and the freezer and water dispenser seem ok. The fridge freezer is only 3 years old. Any ideas/
We had the same fault on our Samsung American style RSH1DBRS fridge freezer as lots of other people seem to be having. After doing lots of research, we found the best solution seemed to be to buy a repair kit from Appliance DIY Repairs. The instructions were fantastic and the installation was a doddle. Excellent service & well priced.
Jan 19, 2011 | Samsung RS2630SH Side by Side Refrigerator
WATER DISPENSER DOES NOT WORK ON MY SAMSUNG SIDE
a friend of mine had a similar problem with his and it wound up being a solenoid valve on the back of the refrig
Nov 13, 2009 | Samsung Refrigerators
Water dispencer and ice dispencer stopped working
Make sure the water supply line is turned on (the valve probably is behind the fridge or under the sink ) also check if is kinked or damaged.
Aug 25, 2009 | Kenmore Freezers
Ice maker not working
Cause could be the solenoid valve which controls water flow into the ice maker.
Could be bad solenoid, bad relay for solenoid, clogged solenoid valve, corroded electrical connections, etc.
More info? Let me know...
Charlie
Aug 14, 2009 | Refrigerators
Icemaker and water dispenser not working GE GSS25JFPA stopped working and i thought it was water filters (have not changed in 4 years changed the internal filter and a aux one in basement in line no...
generic troubleshooting video: http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
as the video shows a kinked line may be the culprit. or
if your ice maker is making ice and it is your ice dispencer that is not working along with your water dispencer and when you press the dispencer button the light dims on the door. I would replace the main board. I experienced the same problem and the board fixed it This board is shared by many models and brands of fridges and the transformer goes bad from power surges this board powers the solenoid valves that open for your water
Apr 03, 2008 | Refrigerators
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Maytag mfd2561 water dispencer and ice maker issues
Most likely it is the High Voltage Control board located in the unit compartment (take off the back cover where the water lines are) i have had lots of them failing and doing all kinds of odd things, so far it has been that computer. Part number 12002608
RS21 DCNS FRIDGE COOLING FAULT
There is a fan behind the plastic. This distributes the cold air throughout the fridge. What happens is this fan stops turning due to freezing up. A temp solution is to unplug the samsung for 6-12 hours to allow the ice to melt from around the fan. This is a known design fault. It is easy to dismantle the plastic cover and defrost the frozen fan with a hair dryer, this way the fridge will only be off for about an hour
Aug 14, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2534 Side by Side Refrigerator Logo
433 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
