Question about Canon PIXMA MP830 All-In-One InkJet Printer
Service error 6A00 in my canon ip 5200 printer. what should i do
My Canon MP830 shows the error code 6A00. On the computer screen it shows service error 5C10. How can I fix this?
  • Canon Master
  • 6,487 Answers
You can follow the steps in resolving the problem from this link
http://www.fixyourownprinter.com/forums/inkjet/37440
Posted on Feb 23, 2009
    Genius:
  • 1,550 Answers
The error code means AP Position Error .
Manually move the print head left and right, turn the printer on/off. If you still get the same error. Then check for a torn paper lodged inside. Removed it printer will be working .
  • 744 Answers
Hi...there's a couple things you can try:
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.
Double check that your ink tanks are seated right too
As far as the noise goes (and possibly related to the error code) be sure that your scanner is UNLOCKED...
With the machine turned OFF:
Open the document cover, look on the tray where the glass is -- and then look to the LEFT side of the glass and you will see pictures of an opened lock and a closed lock and a little switch...
Make sure the switch is next to the UNLOCKED position.
WAIT 5 seconds or so and then turn the unit back on.
If you STILL have the error code, try these two types of resets:
To clear the memory:
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
To do a stop/reset:
To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
  1. With the printer powered on, PRESS AND HOLD DOWN the <Stop/Reset> button then press the ON/OFF button.
  2. Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.
If none of the above clears it up, you may have to have the machine serviced.. check to see if you are still under warranty...
thank u rate me!!
think it will solve ur problem....
  • 544 Answers
Thank you for choosing Fixya.com
please try to shutdown your computer and printer.
try to double check the wirings and cables connection thru the computer and printer if it is in proper.
Then try to Open again your printer.
If still no change at all.
try to re install your printer.
please let me know if any changes happen after you do this suggestion.
    Brigadier General:
  • 5,158 Answers
1. Opening the cover and wait for ink carriage to center
2. Pull out power cord
3. Pushed carriage to far left (should slide easily)
4. Used paper towel and wiped purge unit a lot of times
(press down to soak paper towel with ink). Repeat until the paper towel is relatively clear.
5. Used diluted napisan (oxygen-based cleaning agent in the
ratio of 1:3 with powder:water) and soaked paper towel
6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white.
7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down
8. Slided carriage back to original position
9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
    Genius:
  • 3,422 Answers
HI,
6A00 is a problem with the sheet feed unit.
Please click on the below link and try out some of the troubleshooting steps:
http://www.fixyourownprinter.com/forums/inkjet/39177
    Brigadier General:
  • Canon Master
  • 3,614 Answers
Hi here,
do removing the ink cartridge and resit it properly. check for any paper jam inside the machine.,
let me knw.
  • micromaster
    micromaster Feb 23, 2009
    1. Do a print head cleaning
    2. Print the nozzle check pattern
    3. - repeat steps 1-2 up to two times -
    4. Do a print head Deep Cleaning (Note: the Print Head Deep Cleaning Procedure uses a lot of ink)
    5. Print the nozzle check pattern (This will print a test page using all nozzles in the print head)
    6. - repeat steps 3-4 up to two times -
    The
    printhead can also become clogged or blocked with paper debris or
    solidified ink. If your print quality is poor or your printer will not
    print at all, it may be time to change your printhead.
Canon mp830 has a 6A00 error code
Do a random internet search type in canon mp830 error code 6A00
to see whatt that code means
Jan 21, 2013 | Canon MP830 All-In-One Printer
My screen on my printer says error 6A00 error code. I have turned printer on and off...not sure what is going on
See website above for all details to do with this error.
Unfortunately 6A00 is a problem with the sheet feed unit.
Follow Canon's suggestion, take it or send the unit UPS to the Authorized Repair Facility.
You most likely will NOT be able to resolve the problem yourself, sorry.
Your service and repair manual is below, for you to download. All error codes and fixes are in there.
www.pdfoo.com/result-pixma-mp830-service-manual-.html
Sep 30, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I have a error code 6A00 and alarm light flashing on my canon pixma mp 830
Canon lists the solutions for the error 6A00 as...
1.
Press ON/OFF switch to reset the multifunction device
2.
Press Stop/Reset and ON/OFF to reset the printer
3.
Removing paper jams
4.
The MP830 may require repair
5.
Unlock the scanner lock switch (MP830)
Oct 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
On printer screen it is showing Error 6A00 and error code. Whats does this mean and how can I fix it
In my IP 3000 during a print suddenly on the 3rd page, a big "crunch" sound. Paper was jammed - error 5100 or smthg, and managed to remove the paper... but then error 6A00 came up. I found this post and was saved. Manually moved the print head left and right, turned the printer on/off. Still the same error. Then I noticed a piece of torn paper lodged inside. Removed that, got inky fingers, and finally got printer in working condition.
Try to clean any foreign object inside.May be it can help you.
Sep 10, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 23, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error Code 6A00 for MP830
try simply moving the cartridge back and forth a few times first
Because: 6A00 is a problem with the sheet feed unit. Follow Canon's suggestion, take it or send the unit UPS to the Authorized Repair Facility. You will NOT be able to resolve the problem yourself.
Dec 09, 2008 | Canon PIXMA MP830 All-In-One InkJet...
My canon mp830
Error code 5200 means the print head temperature is too high. The only was to resolve this error is either replace the print head or replace the logic board. The print head is available, part number QY6-0061 but you will struggle to find a logic board. The only other thing you can try is resetting the EEPROM on the logic board, this sometimes clears the error. A service manual will show you how to do this: http://www.tradebit.com/filedetail.php/4546483-canon-pixma-mp830-printer-service-manual
Jun 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830 Service Error 6000
Canon PIXMA MP830 all-in-one Inkjet Printer
Error code 5C10 on computor screen and on the printer it says 6A00
Jan 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
old marine
old marine
