Question about Braun Flex Integral 5314 Electric Shaver
Replacement shavinghead for braun 5341 electric shaver
SOURCE: Braun battery replacement
Unfortunately this is almost impossible. The batteries are part of the circuit board, and Braun only authorize their service agents to replace the whole unit, and my local agent found that it had been discontinued. If you still want to have a go, two screws are hidden beneath the two grey plastic caps either side of the charging socket on the underside of the shaver which can be prized off quite easily. Once you have removed the screws, the small plastic section comes off. Now you can slide the outer casing off. A thin black cover at the back can then be unclipped, revealing the circuit board and batteries. The whole unit simply lifts out and would be easy to replace if you could find one! Rplacing the batteries would be far more difficult and risky. Good luck.
Posted on Sep 02, 2008
  • 5 Answers
SOURCE: how to replace battery on braun 7526 electric shaver
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 scews
4) Open shaver
5) Remove circuit board with batteries
6) Install new circuit board and reassemble
Posted on Jan 07, 2009
Cytherian
  • 124 Answers
SOURCE: Battery replacement for Braun 8585
If the "reset" described didn't work all that well, as a last resort you can replace the batteries. You have two choices: put in a battery/circuit-board part replacement (drop in), or solder in new batteries. If you've got some soldering experience, I recommend replacing just the batteries. You can buy new NiMH AA 1.2v flat top batteries rather cheaply (less than $4 per cell) and using a soldering iron, take out the old ones and secure the new ones. Look for batteries with at least a 1650mAh rating. Good luck!
Posted on Oct 22, 2009
Testimonial: "I believe this is a more viable solution. I will try your advice this weekend. Thanks,."
brector3
  • 1621 Answers
SOURCE: The braun 5510 shaver.. rechargeable or not
If working properly, model 5510 will work either from the internal rechargeable batteries or directly from the cord. If your shaver no longer recharges, it needs to have the rechargeable batteries replaced.
Posted on Feb 04, 2010
brector3
  • 1621 Answers
SOURCE: My Braun shaver 8585 has died. Foil, cable, box,
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See shaveroutlet.com link below
http://shaveroutlet.com/braun-8585-activator-lower-unit-p-364.html
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
Posted on Aug 23, 2010
Braun activator 8585 change the foil
braun series 5 combi 51S outer foil and cutter replacement pack (Formerly 8000 360 Complete Or Activator) for men electric shaver braun 8585 replacement parts.
Jul 30, 2013 | Braun 8585 Electric Shaver
The screen on my braun shaver has holes and needs replacement can i get new ones for it? its the one that says caution for use only with braun series 549 class 2 power unit www.braun.com it has a trimmer...
Braun 8985 replacement foil and blades is braun series 5 combi 51S foil and cutter replacement pack.
But costomer reviews in amazon.com who take braun series 3 combi 30B foil and cutter replacement pack is fits to Braun 8985 perfectly, very smooth and close shave. Shaves much better than the Braun 51S screens foil.
You consideration
http://www.amazon.com/gp/community-content-search/results/?ie=UTF8&search-alias=community-reviews&tag=best-electric-razors-20&Go.x=0&linkCode=ur2&query=braun%208985&camp=1789&Go.y=0&creative=9325&idx.asin=B001VH6F9G
Sep 16, 2011 | Braun 360° Complete 8985 Electric Shaver
Blades need sharpening or replaced. Where do I go in JHB area
Braun syncro 7526 foil and cutter blades is Braun Series 3 combi 30B foil and cutter replacement pack.
Apr 18, 2011 | Braun Syncro 7526 Electric Shaver
My Braun shaver 8585 has died. Foil, cable, box, Clean and charge unit as new. Which Braun shaver replaces Braun 8585 and can utilise good pieces?
Aug 23, 2010 | Braun 360° Complete 8985 Electric Shaver
Looking for new blades for a Braun Electric shaver model 7630. Where can we get them and cost. Live in Gauteng, South Africa
$21-$70 from 3 pack to 12 pack
http://shavers-and-replacement-parts.stores.yahoo.net/braunshavrep.html
$28 + http://www.nelsonappliance.com/braun+shaver+parts.asp
$28+
http://www.newcomerscns.com/index_braunfoilncutter.htm
$19.99
http://www.thepartsbiz.com/Braun-7000-Series-Syncro-Pro-Shaver-Blade-And-Foil-Genuine_p_4827.html
$10
http://www.thepartsbiz.com/Braun-7000-Series-Syncro-Shaver-Blade-And-Foil-Aftermarket_p_791.html
Jun 23, 2010 | Braun 4501 Electric Shaver
I have lost my instruction and cleaning manual for Braun electric shaver #7680 and need to find replacement.
Here are the instructions for a #7680 Shaver. http://www.service.braun.com/line/SH/S5491/S5491_9_NA.pdf
Apr 26, 2009 | Braun Syncro 7680 Electric Shaver
Braun 4775 Electric Shaver Power cord
I would visit this website: http://www.braun.com/na.html
They have a link for replacement parts and a Contact Us link. By contacting Braun, you may get the name/address of the nearest parts dealer. I would think Los Angeles has a bunch
of repair shops and parts dealers.
Mar 22, 2008 | Braun 4775 Electric Shaver
Braun Flex Integral 5314 Electric Shaver Logo
168 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
