Unfortunately, neither Aztech nor Motorola will hand out details about their chipsets and implementations, which is making it impossible to write drivers.
Hopeless, unless the manufacturers provide either precompiled modules (as PCTel did) or details about their products - which is simply not going to happen anytime soon. Apart from that, these software modems do not work reliably enough in a multitasking, multiuser environment, anyways.
Michael -- Michael Buchenrieder * * # Lumber Cartel Unit #456 (TINLC) & Official Netscum Note: If you want me to send you email, don't munge your address.
Was this helpful?
Yes
No
Solution #2
posted on Aug 02, 2007
Bouncy - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Hey Mariusz,
I'm in a similar position myself, trying to get the Aztech MR8800 working under Linux. Problem is the SM56 chipset doesn't implement modulation/demodulation, but rather delegates it to a software driver.
You can get a generic modem driver from # which implements V21 and V23, with V34 coming "Some Time Real Soon". You'll still need a separate driver to allow the linmodem driver to communicate with the SM56.
I'm doing some research in this direction, and will let you know if I make any headway.
Regards, Ian
Was this helpful?
Yes
No
Solution #3
Hart - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
The thing that should be outlawed is hardware without interface documentation. For many years BH (before Hayes) modems had widely varying interfaces, via registers etc., much like driving a UART chip. As long as we knew what bit to flip (and which not to flip) to make them go online etc. they were perfectly usable, albeit a pain in the butt.
Winmodems are essentially a throwback to BH.
-- Chuck Falconer (cbfalco@my-deja.com) # (Remove "NOSPAM." from reply address. Above works unmodified) mailto: (for spambots to harvest)
Was this helpful?
Yes
No
Solution #4
paulrmc - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
NO
JRT
If Winmodems are outlawed, only outlaws will sell Winmodems!
motorola sm56 speakerphone modem is connect to my new pc it keeps saying no dial tone eror 680 but...
(More)
motorola sm56 speakerphone modem is connect to my new pc it keeps saying no dial tone eror 680 but when i plug the phone line back in the old pc i connect straight away .... i have an telstra prepaid home phone line which means i have to put a code in to dial out which have copied all the digets and dashes i need to dial up from my old pc modem to my new modem
I can't get a conection on a dial up modem motorola sm56 speakerphone after it dials it trys to...
(More)
I can't get a conection on a dial up modem motorola sm56 speakerphone after it dials it trys to connect after verifying the user name and password then it times out with a 692 error
After I turn on my laptop I get this: Incompatible modem codec detected, please check your modem...
(More)
After I turn on my laptop I get this: Incompatible modem codec detected, please check your modem card
im using motorola sm56 modem.when i try to adsl speedtest download portion is ok but upload portion...
(More)
im using motorola sm56 modem.when i try to adsl speedtest download portion is ok but upload portion is never be tested
