Write a program to calculate Magic square Number A[4][4]
  • Arman
    Arman Sep 28, 2014
    [5][5]
  • 463 Answers
From Joe-Bob's handy-dandy reference:
(wikiedia...)
Normal magic squares exist for all orders n ≥ 1 except n = 2, although the case n = 1 is trivial—it consists of a single cell containing the number 1
The constant sum in every row, column and diagonal is called the magic constant or magic sum, M. The magic constant of a normal magic square depends only on n and has the value
Write a program to calculate Magic square Number A - 13652227c2537f1018ce4d011d792db1.png For normal magic squares of order n = 3, 4, 5, …, the magic constants are:
15, 34, 65, 111, 175, 260, …
Posted on Mar 06, 2009
How do I get all the factors of a constant using my calculator?
There is a program on page 253 of the manual (http://support.casio.com/manualfile.php?rgn=5&cid=004002013) to get the prime factors of any number. You could modify the program to get all the factors.
Another way would be to do it manually. I start with the number 1 and go up to the square root of the number. The square root of 120 is 10.95, so let's go up to 11. Using 120 as an example:
120 /1 = 120 thus factor is (1, 120)
120/2 = 60 thus factor is (2, 60)
120/3 = 40 thus factor is (3, 40)
120/4 = 30 thus factor is (4, 30)
120/5 = 24 thus factor is (5, 24)
120/6 = 20 thus factor is (6, 20)
120/7 = 1.7 thus 7 not a factor
120/8 = 15 thus factor is (8,15)
120/9 = 13.3 thus 9 is not a factor
120/10 = 12 thus factor is (10,12)
120/11 = 10.9 thus 11 is not a factor.
Good luck.
Paul
Jul 05, 2015 | Casio FX-9750GII Graphing Calculator
I'm trying to figure out a 3x3 magic square where the rows equal 21 18 10 and the columns equal 15 24 13 using the numbers 1-9
I don't think you can do it! Could you check your numbers.
If we are using the numbers 1-9 once and only once in a 3x3 magic square, the sum of the rows + the sum of the columns should be 90, since 1+2+3+4+5+6+7+8+9 in the rows adds up to 45 and 1+2+3+4+5+6+7+8+9 in the columns adds up to 45.
When trying to solve, the magic number seem to be the sums 24 and 10. To get 24, the only three numbers that add to 24 are 7 + 8 +9. Similarly to get 10, the lowest numbers re 1 and 2 and the smallest big number to use is 7. I then ran out of number trying to get 21, 13 and 15 sums.
Good luck,
Paul
May 21, 2015 | Office Equipment & Supplies
How do you use the square root on the ti 30xa
Put in the number and press the square-root key (two keys up from the 9 key). For example, to calculate the square root of 4, press 4 square-root.
Feb 12, 2014 | Texas Instruments TI-30XA Calculator
When I square a negative number, my calculator gives me a negative number. i.e. -4^2=-16
No, you're not squaring a negative number, you're negating a square. When you press (-) 4 ^ 2 ENTER , the calculator is calculating -(4^2). 4^2 is 16, and the negative of that is -16. What you want to do is to calculate (-4)^2 by pressing ( (-) 4 ) ^ 2 ENTER .
Jul 11, 2011 | Texas Instruments TI-83 Plus Calculator
I cant figure out how to get the square root of a negative number
The square root of a negative number is an imaginary number, and the TI-30XA does not deal with imaginary numbers.
However, the square root of -x is equal to i times the square root of x. So, to calculate the square root of -4, for example, press 4 square_root = and read 2. Thus the square root of -4 is 2i.
Oct 07, 2010 | Texas Instruments TI-30XA Calculator
The square root of any number using the TI83+ is different by a small amount from the TI89 differentiated number. Is the a programing issue?
Not the square root of any number. Both machines give the same result for the square root of 4, for example. The differences for other numbers are due to the fact that the two calculators use different processors and carry different numbers of significant digits for internal calculations. The square root of most numbers is an irrational number, with an infinite decimal representation. It has to be cut off somewhere. If you cut it off in two different places, you're going to get two different numbers (unless there happens to be zeroes where you cut...).
Jul 04, 2010 | Texas Instruments TI-83 Plus Silver...
When I square a negative number (eg -2^2) it gives me a negative answer (-4) why isn't it giving me a positive answer?
You're not squaring a negative number, you're negating a square. What you need to do is calculate (-2)^2 instead of the -(2^2) you're now calculating.
Feb 04, 2010 | Texas Instruments TI-83 Plus Calculator
Wrong answer with squared negatives.
Your calculator will square a number before it applies the negative sign, so what you're actually doing is squaring 2, then applying the - sign to your answer. You need to put the -2 in parenthesis, so (-2)^2. That will give you 4. Hope this helps!
Nov 12, 2008 | Texas Instruments TI-83 Plus Calculator
Computers & Internet Logo
351 people viewed this question
David Payne
David Payne
