Question about Brother HL-2040 Laser Printer
Paper jam on Brother HL-1270N
Paper has jammed in the roller(s) at thr rear of the printer (HL-1270 Brother).
From the rear of the printer, I can see the paper that is causing the jam - but how do I get at it?
Have tried removing top of printer - no access.
Have removed metal base - no access.
Any more ideas.
Paper jammed in printer
Posted on Feb 08, 2011
  • 133 Answers
How do I clear paper jams?
If a paper jam occurs, the Paper LED will flash as shown below.
paper jam on Brother HL-1270N - c_panel_cover_open.gif Caution
    After you have used the printer, some parts inside the printer are extremely hot. When you open the front cover or face-up output tray of the printer, never touch the shaded parts shown below.
  1. Remove the paper tray from the printer.
  1. Pull the jammed paper up and out of tpaper jam on Brother HL-1270N - c_hl20_0304.gif>
  1. Pull out the drum unit and toner cartridge assembly slowly. The jammedpaper jam on Brother HL-1270N - c_hl20_03221.gifulled out with the drum unit and toner cartridge assembly.
c_hl20_03221.gif Caution To prevent damage to the printer caused by static electricity, do not touch the electrodes shown below. c_hl20_019.gif
  1. Open the back cover.
  1. Pull the tab toward you to open the rear chute cover.
c_hl20_0429.gifpaper jam on Brother HL-1270N - chapter0616.gifli class="h_mi"> Pull the jammed paper out of the fuser unit. If the jammed paper cannot be pulled out easily, push down the tab with one hand as you gently pull the paper out with other.
chapter0616.gif Close the back cover.
  1. Push the lock lever down and take the toner cartridge out of the drum unit. Take out the jammed paper if there is any inside the drum unit.
  1. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
c_hl20_025121.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part showpaper jam on Brother HL-1270N - c_hl20_02711.gifation.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Put the drum unit and toner cartridge assembly back in the printer.
  1. Put the paper tray firmly back in the printer.
  1. Close the front cover.
    Make sure that the Paper LED is now off and the printer is ready.
Posted on May 23, 2009
Paper got jammed. Removed. Still says paper jam, but I can't see any. What should I do next?
Error says paper jam, but there is not. What could cause this ...,+but+there+is+not...
iFixitThere is no paper jammed anywhere! each time I would finish with the steps and ... I have to turn off and turn on the printer to get it going again. ... and the grinding sound and the paper jam message still comes up. i am going to try .... well no luck Iremoved ink and they are not dry - new- and now it says paper jam and not so ...
Fixing Brother Printer "Paper Jam" Error with No ... - YouTube
? 1:54
May 30, 2014 - Uploaded by Refresh Cartridges
Fixing Brother Printer "Paper Jam" Error with No Paper Jammed.... problem occurred again. i try this many times but the problem is still in there. ... There was paper jam front rear on my brother j450dw that wasn't going away, that was ... How to remove jammed paper HP LaserJet Professional P1102 Printer ...
How to fix a printer paper jam. - Computer Hope
Dec 03, 2015 | Office Equipment & Supplies
After working fine for 2 years, my Brother HL-5370 started frequently jamming and wrinkling paper.
You need to make sure your paper roller is proper working if it creating any problem then you need to check there settings then it will start working fine . Renew your printer pickup roller No more paper jams Don replace rejuvenate... Frequently Asked Questions
Feb 21, 2015 | Brother Office Equipment & Supplies
Our Brother printer HL-2142 has a paper jam and we cannot locate our manual. Can you help?
hi there!
for paper jam, dont simply pull the paper out of the printer, this will damage the feed mechanism of the printer. but if already did, just open up the cartridge door of the printer (also check on the duplexer at back if it has), check for paper tear, clean rollers if you can too. this is the manual for your printer aswell since you lost your copy:
Apr 07, 2011 | Brother Office Equipment & Supplies
How could i fix paper jam on Brother HL-2140 Laser Printer?
One of the main causes for paper jams is the presence of dirt, dust, or debris in your toner cartridge. The paper coming into the cartridge would get stuck. So clean your printer regularly. Remove the dust from the printer. Also find out whether any jams occurred in the sensor hole in the upper part of the rotating drum. Do not touch the roller while cleaning. If the oil in your body gets into the roller, the printing media cannot roll over it properly and you can't get rid of the printer problem.
Jan 12, 2011 | Brother HL 2140 Laser Printer
Paper red light is blinking and it won't print but there's paper in the printer. I had to pull out 2 pieces of stuck paper earlier.
You may encounter a paper jam while working with your Brother printer. You need to be cautious while feeding the paper to your printer. Paper jams are often obvious, but you might come across a situation when you do not get any indication that the paper has jammed up the printer. In such cases, you need to open your printer and visually inspect it to search for the jammed paper. If the rollers of your printer are leaving marks on the printouts, then there is a need to clean them. Using chemical cleaners such as benzine, thinner, or alcohol to clean the rollers might prove hazardous to your printer.
Nov 29, 2010 | Brother HL-2040 Laser Printer
Paper has jammed rinter
paper jam is of two types.1.while spolling half paper will come out tom tray.remain jammed in rollers.This can solve by switching the printer power off and remove toner catridge from printer.Then power on the printer.lift the top rollers cover and reset as it is.The paper will come out without any difficult.2.Paper jam inside the toner catridge by rolling itself to drum.Switch off the printer power.Remove toner catridge from priter.Unscrew the toner catridge cover screws.remove drum from toner catridge .Utmost care should be taken while removing jammed paper from drum.Reassemble as it is and set.
Nov 07, 2010 | Brother HL 5170DN Laser Printer
Have you tried cleaning the paper pickup and registration rollers? See page 128 in the HL-2700CN User Guide available from the Brother Solutions Center
Jun 02, 2010 | Brother HL 2700CN Laser Printer
Brother HL-2040 laser printer
Make sure to clean all the rollers you can see and make sure to check the paper sensor, and clean all rollers and paper paths with some Isopropyl Alcohol (AKA rubbing alcohol)
Sep 04, 2008 | Brother HL-2040 Laser Printer
Brother hl 1440 paper jam
clean the paper feed tires with some alcahol. they are located in the upper part of the machine when you pull out the paper tray. they are gray in color. if that does not work the feed tires may need replaced.
Oct 12, 2007 | Brother HL 1440 Laser Printer
Brother HL-2040 Laser Printer Logo
733 people viewed this question
James Cagle
James Cagle
Jim Keysor
