Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Dryer has no heat. Fuze is OK.
I cannot get any heat in the dryer. The fuze seems to be OK. Is there an easy check to determine the problem before I call the service technician to come to my home?
  • mark92356 Feb 26, 2009
    the dryer blows cold cair,i replaced the heating element and thermostat and have the same problem
  • 3 Answers
Its possible that it might be the ignition box.
Posted on Mar 01, 2009
Heat stays on while blower is off and burning fuze
If you mean that the dryer timer is at "OFF' and the heater coil continues to heat, then the timer contacts are "welded" together. Check/replace the timer.
If you mean the blower is not running during a drying cycle, the the various heat-sensors, including the thermal-fuse are doing their jobs. Find out why the blower is not working: Bad motor, blocked 4" duct, etc.
Oct 24, 2013 | Amana NED4600YQ Electric Dryer
Hi, I'm having a problem with my new dryer. We got this dryer about a year ago and for some reason in the last couple months, almost every 2 weeks the fuze blows. The dryer turns on but it doesn't...
Makecertain that your wiring is not exposed to anything. Be sure to turn the power off to the dryerand check the outlet. Also check to seeif your dryer cord is connected to the dryer right. Usually the outer prongs on the dryer are thehot and in the inner one is the ground.
May 11, 2011 | Dryers
I replaced the thermal fuze in my kenmore gas dryer. Now not only does the dryer not FIRE up, but when I push the button to start the dryer, it will not fire and will shut off shortly after. When I let go...
when you start the dryer does the igniter glow red hot? they crack very easy.If you are sure you put the wires on the fuse the right way,and the igniter is glowing, and you remembered to turn the gas back on,( I've done that ), no kinks in the gas line.The next thing I would look at is the gas vavle, or coils. good luck.
Jan 19, 2011 | Kenmore 400 6942 Dryer
My HTC fuze started to heat up on its own! This is resulting in the battery discharging at a much faster rate. Any ideas?
i know this sounds crazy but u can get a blow dryer and put it on cool and dry your phone thats what i did to my htc fuze and it works so good luck!!!!
Apr 02, 2010 | HTC FUZE Smartphone
Dryer turns on and spins, but no heat.
Take the back off the dryer. Will will see a metal tube running from the bottom of the dryer to the top. This will have a fuze at the top and a thermostat at the bottom, and the heating element is inside the tube. Check the ohms on the fuze and the heating element. Replace the one that has no continuity.
Jun 29, 2009 | Kenmore Dryers
Dryer wont turn back on.
Hi!! Relax your thermal fuze has shorted out..replace your thermal fuze and all is fine..Good luck..the fuze is located by the motor blower inside the machine its white oval around 2 inches and has 2 wire leads to it good luckk.
Jan 04, 2009 | Kenmore 64992 Electric Dryer
Whirlpool Dryer GEQ9800LW0 won't turn on
Hi!!! it seems that you have a bad thermal fuze located near the blower..change the thermal fuze and you should be okay..Good luck..
Jan 04, 2009 | Whirlpool GEW9200L Electric Dryer
Maytag electric dryer won't start
Hi!!! You have a bad thermal fuse.easy to replace just lift up open the top cover of the dryer and the thermal fuze is in the back next to the heating element.Its round and black with 2 wire going into it its around half and inch thick next to the heating element ..Good luck..
Jan 03, 2009 | Maytag PYE2300AY Electric Dryer
Kenmore gas dryer won't start.
Hi!!1 You have a shorted thermal fuze on the dryer..The thermal fuze is located in the back of the dryer its white and oval with 2 wire leads..replace it and you should be fine..good luck..
Dec 26, 2008 | Kenmore 73952 Gas Dryer
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
70 people viewed this question
Dan Webster
Dan Webster
Sal De
