Question about iRobot Roomba 530 Robotic Vacuum
IRobot not picking up dirt
The cleaner is moving around the room in the usual manner but not picking up much. The dirt compartment is empty and only dirt i see is on the lower side of the filter. It ran for a hour but did nothing. I cleaned the brushes changed the filter, still same result I am having the same problem -I completely dismantled and cleaned everything - it runs great except for the fact it isn't picking up dirt :-
  • carolkey80 Apr 22, 2009
    I have the same problem with mine. THe dirt collects just underneath the dirt compartment but not inside the dirt compartment.
  • Tim Nelson
    Tim Nelson May 11, 2010
    do you have a new filter on it?
  • 3 Answers
I had the exact same problem.
In my cases, cleaning the little yellow things on the end is what fixed it.
This is what I got from irobot:
We apologize for the inconvenience. Here are a few things that you can try to resolve this issue:
1. Remove and empty the Roomba's dust bin.
2. Turn the Roomba on its back, remove the brush guard, and remove the main brush.
3. Reinstall the brush guard and run the Roomba without the main brush or dust bin. Is the flexible brush turning? If yes, go to step 4. If not, please skip to step 9.
4. Inspect the main brush to ensure it is clean and not bent. Verify that the main bristle brush has a larger end cap on each end. When you perform maintenance, you will need to remove the end cap from the brush. When the brush is clean, please return the end cap to its location.
5. Verify that the main brush and flexible brush each have a yellow bearing on one end. If either yellow bearing is missing, your brushes will not turn properly. This can potentially damage the Roomba. Please respond with this information so that we can send you new brush bearings.
6. Inspect the yellow bearings on the two brushes and ensure they turn easily with your fingers. Remove the yellow bearings and clean any dirt accumulated in the bearing cups.
7. Ensure that the brush sockets (on the opposite side of where the bearings fit) are square, and not stripped or worn out in any way.
8. Reinstall the main brush and brush guard on the Roomba. Run the robot without the dust bin. Is the main brush turning? If not, please skip to the bottom to provide the requested information.
9. Remove the flexible brush and reinstall the brush guard.
10. Run the Roomba without the dust bin and listen for the Cleaning Head gearbox running. Do you hear the gears turning? If not, do you hear any noise at all? If the noise from the Cleaning Head sounds abnormal or you cannot hear it, please skip to the bottom to provide us with the requested information.
If you do hear the noise, reassemble your robot and run it again. The issue should be corrected.
** NOTE: Excessive build up of hair in Roomba's brushes and bearings can permanently damage Roomba. Inspect brush bearings regularly.
Title: Cleaning the Main Brushes
URL: http://homesupport.irobot.com/cgi-bin/irobot_homesupport.cfg/php/enduser/std_adp.php?p_faqid=624
If the issue persists, please tell us which brush is not operating properly and also respond with the following information for our verification process:
• Your complete name and shipping address
• Your Roomba's product code. The product code is located under the dust bin near the brush assembly.
• The original date and location that the Roomba was purchased
Title: Where can I find the serial number/product code for my robot?
URL: http://homesupport.irobot.com/cgi-bin/irobot_homesupport.cfg/php/enduser/std_adp.php?p_faqid=274
Posted on May 30, 2009
  • 83 Answers
Try to replace the filter, that should work.
Posted on Mar 12, 2009
2 Suggested Answers
SOURCE: IRobot not picking up dirt
this link fixed my prob :
http://www.robotreviews.com/chat/viewtopic.php?t=10628
and just in case the link doesn't work, basically, you have to take out the whole red brush-head assembly unit by unscrewing the 4 screw screws that hold in down in either corner; then find the side of the unit that has the gearing inputs, and unscrew all the screws until you get inside and clean out all the hair...
That should do it :)
Posted on Nov 29, 2009
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
www.quickanddirtytips.com/.../how-to-fix-a-vacuum-that-lost-suction
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. ....it off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
blog.mchardyvac.com/.../common-vacuum-complaints-what-you-can-do...
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
https://www.mrright.in/.../is-your-vacuum-cleaner-not-picking-up-dirt-a...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 | Vacuums
My Rooma 500 series, when I press the start button to go....it sounds like it wants to move forward and the sings a song and doesn't move
I agree with the previous poster, every time you run Romba, you have to empty out the dirt compartment, take the beater brushes off and pull the hair, lint and thread off the brushes (if you use a cat or dog brush this works fantastically) and remove the lint that's wrapped around the ends of the beater brushes. Every other time, you need to remove the thread and hair wrapped around the rotating brush (sometimes you need to remove the Phillips head screw holding this on and really clean it out). Finally the rolling ball wheel needs to be popped out using a narrow, small screwdriver and all the stuff trapped in there removed.
Feb 23, 2015 | iRobot Roomba 560 Robotic Vacuum
Why My Rroomba 560 collects the dirt and after 2 or 3 circles gives it back on the floor. What is wrong?
Sounds like it's picking up the dirt, running it around the brushes and dumping it back out after one full circuit. I would check to see if anything big is caught in the brushes and preventing dirt from going into the filter compartment. Do you need to empty out the filter compartment and shake out or change the dust filter? If the filter is too clogged, dust won't get pulled into this compartment because there's no air passing through the filter to draw air.
Jun 16, 2014 | iRobot Roomba 560 Robotic Vacuum
I starts and tehn stops and beeps three times. I can start it aain and it will run but then it does the same thing'
TYhe iRobot Roomba has different model designations. Here is a webpage with a list of what the beeps mean in the 400 series. I am thinking that is what you have. 3 beeps means the dirt cup is dirty, filters are dirty, or debris in collecting and it needs to be cleaned.
Here is the webpage: http://uksupport.irobot.com/app/answers/detail/a_id/1047/kw/iRobot%20Roomba%20Discovery%20SE%20Bagless%20Robotic%204200%20series%20Vacuum%20beeps%203%20times/related/1
Hope this helps. If it does, I would appreciate a vote. Thanks,
Handie Andie
Apr 01, 2011 | iRobot Roomba Discovery SE Bagless Robotic...
This vacuum cleaner is BRAND NEW!!! I am vacuuming a tile floor. It seems to pick up the dust, etc., and when you turn around it all back. under the vacuum! The canister is usually empty, but is clicked...
It can be due to several things. from dirty filters to clog/s in the hose or tubings to incorrectly placed dirt cup.
You didn't mention the model you have, but you can find the manual on the following site, and it will tell you how to take care of the filters.
http://www.bissell.com/searchresults_userguides.aspx?searchtext=Bissell%2520PowerForce%2520Model%25203522-1&searchType=search&mode=228
Mar 12, 2011 | Bissell Vacuums
It starts and for a few seconds and then stops The battery is fine
Is the charging ase turned on and is the dust container emptied? Any obstructions?
Apr 11, 2010 | Roomba Robotic Floor Bagless Vacuum
Too much solution being dispensed--carpets very wet--running out of solution before even 1/3 of room cleaned
The cleaning solution tank is only sufficient for part of a room, unless the room is very small.
Are you following the instructions for using the cleaner carefully? The machine has to be pulled backwards (towards you) at a steady pace in order for the vacuum to pick up the water that is dispensed. Do not use it like a normal vacuum cleaner - that will not work.
You need to start facing a wall, and pull the cleaner towards you, moving at about one foot every two or three seconds. The vacuum will then pick up the water that has been dispensed and the carpet will be damp but not sodden.
Apr 06, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
The hand cleaner picks up dirt but the floor cleaner does not.
A couple ideas.
1. Have you emptied your dirt?
2. Are your filters clean?
3. Is your roller brush working and if not, is your belt broken?
Hope this helps and good luck!
Mar 17, 2010 | Dirt Devil Featherlite Bagless Vacuum...
iRobot Roomba 530 Robotic Vacuum Logo
1,941 people viewed this question
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
