Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Get a Professional
Find a Solution
Most Common Problems for:
Wireless broadband connection
By Duke - usenet poster
Home built PCAMD Duron 1.4 Mhz, 1 gid Ram, 15 gig HD, onboard sound and
video on ECS MB. Two similar PC's sharing wireless broadband connection,
not networked. 2nd PC with USB NIC loses connection when portable phone is
in use. 1st PC stays connected. Phone support from RoadRunner say I need
to open ICS, but error box states to contact system administrator when
attempted to open. I am the sys admin and am logged on as such. Using
w2kPro. Is there any way to open ICS?
Thank you,
James
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (#).
Version: 6.0.681 / Virus Database: 443 - Release Date: 5/10/2004
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Dec 23, 2007
Very Helpful)
2bob_watch
Rank: Wiz
Rating: 81%, 52 votes
It could possibly be that you haven't fitted your filter on the phone connection. If you're using ADSL as your broadband, each phone connection sharing that paticular phone number each requires one of those filters. I hope the solution is a simple one for you
Was this helpful?
Yes
No
Solution #2
posted on Aug 02, 2007
Very Helpful)
herself
Rank: Apprentice
Rating: 0%, 0 votes
is
Hello James,
If they are sharing a common wireless broadband connection then they are
networked
I don't understand what Internet Connection Sharing has got to do with a
portable phone, cell or otherwise, ICS is the system windows uses to share
an internet connection with other machines on your network, one computer has
direct access to the net, the others access the net through it.
When you say 'wireless broadband connection' is this a commercial thing you
pay a subscription for, or are you referring to a wireless access point or
router in your home, that is then connected to adsl or cable, etc?
Cell phones, and some 'dect' portables can disrupt wireless networks,
because of the similar frequencies they use, is this your problem?
To enable ICS, yes, you do have to be a member of the administrators group,
have you or anyone else, accidently or otherwise changed your membership.
You also need more than one 'network' connection to enable ICS, you then
share the internet connection.
What computers have you got connected to what, and how, because, unless I'm
just in stupid mode today (very possible), then I think the group needs some
more info from you.
TTFN, Ken Phillips
is
Hello James,
networked
more info from you.
TTFN, Ken Phillips
Was this helpful?
Yes
No
Solution #3
Not Rated)
Rachel007
Rank: Apprentice
Rating: 0%, 0 votes
I need the wireless since I'm in a condo
and don't want to run RJ45. It'll be handy if I ever get a laptop. I just
went and exchanged the 2.4 ghz phone for a 900mhz. Hopefully that will cure
the problem.
Thanks to all of you for your time and expertise.
James
| | wired
| connection,
| You might try a different cordless phone, possibly one that uses a
| different frequency.
| Also, consider if you really need wireless here. You have more trouble
| with it, and really have no need for it unless this is a computer you
| move around.
| Surfboard
| I hope you have software firewally on each computer, you need them
| too. The hardware will do a very good job of blocking incoming
| connections, but not much with outgoing connections (where most of the
| problems seem to be).
| It won't hurt anything, just be careful to block those ports (135-139)
| from the internet. I need it, since I just have 1 printer (and don't
| want to waste all that money and space).
| Also, there's an internet security test at
| # this tests your system's response to
| incoming connection attempts. You should get a good result with a
| router, but check anyway.
| Systems without routers are often poor in this area, even worse if
| without a software firewall too (best to use both).
| | | | sound
| | | | phone
| | | | are
| | | | | | a
| share
| computer
| | | | | or
| | | | | when
| Using
| | | | | membership.
| then
| | | | | | | | | | | | | | | sound
| | | | phone
| | | | are
| | | | | | a
| share
| computer
| | | | | or
| | | | | when
| Using
| | | | | membership.
| then
Was this helpful?
Yes
No
Solution #4
Not Rated)
Luisa_K
Rank: Apprentice
Rating: 0%, 0 votes
move around.
Was this helpful?
Yes
No
Solution #5
Not Rated)
Rogers
Rank: Apprentice
Rating: 0%, 0 votes
Get a 900mhz phone (g). Give the 2.4 to someone else.
Was this helpful?
Yes
No
Solution #6
Not Rated)
paulrmc
Rank: Apprentice
Rating: 0%, 0 votes
I'll try to be more specific.
I've subscribed to RoadRunner Cable Broadband. Computer one is hard wired
to the wireless modem/router. Computer two has the wireless usb connection,
and is the one losing the connection when our cordless phone is in use,
which is a 2.4 ghz.
We are using a Motorola wireless cable modem gateway, 5 function: Surfboard
modem, wireless access point, router, print server with firewall, SBG1000.
A Motorola wireless usb adapter on computer 2. The computers are not
networked for file or print sharing.
| | and
| connection,
| | is
| Hello James,
| networked
| need
has
you
group,
I'm
some
| more info from you.
| TTFN, Ken Phillips
| | and
| connection,
| | is
| Hello James,
| networked
| need
has
you
group,
I'm
some
| more info from you.
| TTFN, Ken Phillips
Was this helpful?
Yes
No
Solution #7
Not Rated)
Riddle
Rank: Apprentice
Rating: 0%, 0 votes
Sounds like you have a 2.4ghz phone. If so that is the problem. The
phone signal is interreferring with the wifi.
Do you have the 2nd computer plugged into the first before you connect
to the cable box? If the answer is yes then you are standing in the
barnyard looking at the barndoor but going thru the neighbors field to
go thru it. Put a router in if you do not already have one, then
connect both computers either wired or wireless to the router and
connect the router to the cable box. This last connection MUST be
wired. ICS means that the 1st computer must be on for the 2nd computer
to access the net. With a router this is no longer true AND your 1st
computer will be faster since it does not have to transfer the data
thru it to get to the 2nd computer.
Was this helpful?
Yes
No
Related Problems
I cannot access to router IP after i enebled security, and...
Home built PCAMD Duron 1.4 Mhz, 1 gid Ram, 15 gig HD,...
I have just installed a modem in my gateway computer. The...
Can you Help with these Modem problems?
can i use my adsl modem as a regular...
Solve
can i use my adsl modem as a regular modem to send faxes from the comp. i also have a voip box does... (More)
Broadband light goes on and off
Solve
Ok so since yesterday my broadband light has been going off and on. It may last for 10 minutes to a... (More)
Our speedstream 6520 modem won't...
Solve
Hi we have a speedstream 6520 and the older computers connect fine to it with our WEP code - however... (More)
The modem on/off switch is...
Solve
The modem on/off switch is intermittent. It is a Siemens Speed Stream Ethernet ADSL Modem
i dont have a software for EDGE...
Solve
i dont have a software for EDGE modem E67II
Sponsored Links
Describe your Computer problem:
Top Modem Experts
Rank: Guru Guru
Solutions: 273
Experience: 35+ years as a computer technician, motorcycle racer, photographer, imaging consultant, tinkerer.
Ask Me
Find more Modem Experts
Top Computers & Laptop Repair
(330) 502-6853
Instead of lugging your computer into a shop and...
(601) 918-0222
I will connect to your Computer and repair the...
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
