My toshiba satellite pro l300 have bule screen after istalling bi
I have a new satellite pro l300 1b9
i do install / upgrade the bios driver ...then the laptop do restart and shows blue screen...
can u help me
is this problem serious or not ?
Bios password toshiba satelite l300
Method 1 (Flash BIOS)
Flash BIOS for Satellite L300-ST2501
Flash BIOS for Satellite L300-ST3502
1. Remove the battery and don't turn on the laptop (a minimum of one day or more). To remove electric current, which is still stored in the laptop. Based on experience, can turn a normal laptop, try to enter windows.
2. Download Flash BIOS slb0v150.exe then open the file, select Install, and select Install from Windows - OK.
Flash BIOS can remove the BIOS password
Method 2 (Manual)
source image : bios-repair
With solder, remove the BIOS IC, wait about 10 seconds, then plug it back. To remove the BIOS IC, you must remove the screws down and the LCD.
I hope this information helpful.
Oct 20, 2011 | Toshiba Satellite Pro L300 Notebook
Tip
Download Toshiba Satellite Pro L300 Notebook Windows XP Drivers
Download Drivers for Toshiba Satellite Pro L300 Notebook for Windows XP: Toshiba Satellite Pro L300 Notebook is shipped with Windows Vista, which is quite good but most of us dont like Windows Vista. Downgrading Toshiba Satellite Pro L300 to Windows XP requires Windows XP drivers, which you can find on this page. Download all Windows XP drivers for Toshiba Satellite Pro L300.
Download Instructions
When you click on a download link and a new page opens that is of uploading.com,
click on "download free" on that page.
After that wait for the timer to finish and than click on "download"!
Click Link Given Below to get Drivers
http://www.getpcmemory.com/drivers/download-toshiba-satellite-pro-l300-notebook-windows-xp-drivers/
Peace Be Upon you !
on Dec 29, 2010 | Computers & Internet
I am using toshiba satellite L 300 laptop istalled with windows vista for some reasond i had to reinstall the windows and when i was done with reinstallation the windows i saw that the toshiba dvd player...
try this step
right click on my computer icon
click manage
you should see a dvd drive
right click on dvd drive and click locate
you can choose the path such as E for your dvd drive click ok
if you can find your dvd o computer management try to check your dvd on your bios
restart your lapto
press f2 or delete to enter set up
see if there is any dvd install or not
if you need a driver just go to http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2175704&rpn=PSLB0U&modelFilter=L300-ST2501&selCategory=2756709&selFamily=1073768663
Jun 05, 2011 | Toshiba Satellite Pro L300 Notebook
Tried to install xp instead of vista, now bootmgr is missing.
First you will need the SATA driver already saved on a memory stick. Now go into the BIOS and change the boot order: put the cd first then the hard disk second, save the new setting and reboot. Put the XP install and reboot again, the install will start. When instructed to input extra drivers plug in the memory stick and point to it. After that don't forget to install all the other drivers from here.
http://toshibatips.blogspot.com/2009/01/satellite-pro-l300-notebook-windows-xp.html
Jun 28, 2010 | Toshiba Satellite Pro L300 Notebook
I have installed windows XP on my toshiba L300 and now webcom shows error every time i start.
I have found driver for the S300, I couldn't find L300 drivers anywhere. Try the "Toshiba-Satellite-Pro-S300-Webcam-Driver-For-XP" here:
http://www.general-search.com/fileinfo/4691363
Dec 10, 2009 | Toshiba Satellite Pro L300 Notebook
I download BIOS from the net on my toshiba satellite L300
upgrading bios is dangerous.. in not complate or accedentaly restart. system will not work...
Sep 09, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite L310 problem , display cannot appears
If the screen went blank after the driver install, sometimes clicking the mouse on the screen will bring the picture back. It sounds like the monitor is having a conflict with the resolution the driver is throwing out. Reboot the laptop and when you see the Toshiba splash screen, tap F8 until you see the multiple boot menu. Scroll to Safe Mode with networking and reboot. If the screen comes up, go to the control panel > System > hardware > display adapter > click on the plus sign and double click the reported adapter.click on driver tab and select roll back driver > click yes to any prompts and click ok. Reboot normally and see if that clears the problem.
Sep 07, 2009 | Toshiba Satellite Pro L300 Notebook
Computers & Internet Logo
359 people viewed this question
David Payne
David Payne
