Question about Dell XPS M1530 laptop. TUXEDO BLACK. 15.4" Widescreen Thin, slim & light notebook computer, Intel Co...
My XPS 1530 will not shutdown, it only restarts
When I go to the start menu, and click shutdown or sleep, the computer will not shut down. It just restarts. The only way for me to shut it down is to hold the power button on the keyboard.My XPS Dell computer - My problem is when the powder is on, the computer keeps coming on for a second or so and then goes off and then comes on again. It just does this over and over again. The computer was on sleep mood and than when I came up to use it, it froze and then shut off, and now it keeps coming on and off for a second or so. Please HELP!
  • Gay Beaston Feb 23, 2009
    It is not a laptop it is a XPS Desktop on in one monitor - TV etc. Computer keeps acting like it is coming on but shuts off - repeats this over and over again. the computer is not even a year old yet.
  • 544 Answers
Thank you for choosing Fixya.com.
Let's make all things easy and faster.
make a back up fille to all your important documents.
after that reformat your computer.
im sure the problem will be fix if you have the driver of your computer or laptop and have idea how to reformat you can do it by yourself.
if not let me know.
Posted on Feb 23, 2009
  • Mark Milan silaran
    Mark Milan silaran Feb 23, 2009
    Hello their again,
    sometimes we are accidentally saving some corrupted file and is is the one reason why our dsektop or computer not functioning properly.
    But even it is a desktop you can reformat.
    this is the best way of solution to your problem.
    but if the computer is still on warranty get your desktop to the shop where you buy the unit i prefer to suggest you that don't touch anything let the seller or technician specialist do this for you.
    thank you hope this will help.
  • 679 Answers
This is a case of a corrupted registry, there is no way that this can be resolved by just doing any repair since windows will not start anymore because the registry key for the logon has been either deleted or corrupted, reinstall windows.
    Guru:
  • 832 Answers
Hi there!
thanks for using fixya.com!
you better restore the system your unit or you can do a reformat.
thanks!
  • 1 more comment
  • Dennis Jambalos
    Dennis Jambalos Feb 23, 2009
    hi again!
    pls try this option:
    When you click on the Shut Down option, your computer restarts instead of shutting down.
    1. Click Start > Run and type REGEDIT
    2. Click the plus sign next to HKEY_LOCAL_MACHINE
    then System
    then CurrenControlSet
    then Control
    then click CrashControl
    3. Double-click on AutoReboot on the right side and change the value from 1 to 0.
    Close regedit and restart the computer. Now the computer should shut down normally instead of restarting.
    regards! and let me know...
  • Dennis Jambalos
    or do the following options again if still the same....
    One: Hi Win XP has an mechanism to restart itself in case some internal or hardware problems occur.You can disable it by first opening the control panel ->System->Advanced->Startup and recovery settings->Disable all the three options in system failure section . This will do.
    Second: Check Device Manager and let me know if Computer is registered as ACPI or STANDARD.
    If it is ACPI, a few setting changes and you will fixed up in a jiffy.
    IF it's STANDARD, you need to perform a REPAIR on your system and explicitly state it is an ACPI installation before proceeding with the repair.
    Of course, all of this applies if you have an ATX power supply which you probably do.
    or visit this: http://support.microsoft.com/default.asp...
  • Dennis Jambalos
    i am here again...
    try this as well...
    1. Right-click My Computer, and then click Properties.
    2. Click the Advanced tab.
    3. Under Startup and Recovery, click Settings to open the Startup and Recovery dialog box.
    4. Clear the Automatically restart check box, and click OK the necessary number of times.
    5. Restart your computer for the settings to take effect.
    Thanks!!!
    Novelist:
  • 148 Answers
just take the out the power cable after shutting the system down, press hold the power button on the system tower for 15 seconds and then put in the power cable and start the system if the issue doesn't resolve
please call dell technical support, if you are under limited hardware warranty, as this might require multiple troubleshooting steps.
Further Queries are welcome
if my solution was helpfull please do rate me
if you find my solution helpfull please do rate me
    President:
  • 2,110 Answers
1. Right-click My Computer and go to Properties > Advanced
2. Under Startup and Recovery, click Settings to open the Startup and Recovery settings menu
3. Under System Failure, uncheck the Automatically restart check box, then click OK as needed to exit out
4. Restart the computer and see what happens
    Genius:
  • 1,913 Answers
Wheny power up the computer press "del "or F2 or any key to enter in bios settigns .then load otimal bios defaults settings.then save all settignsogfbios.then check .
may be your computer virud infected .scan your computer with avast antivirus with latest update.download it form here
http://www.avast.com/eng/download-avast-home.html
  • 744 Answers
Hi check out the following steps...
Try running chkdsk /r and then restart the computer. to do that, click on START--->RUN, in the open field, type 'cmd' and press <enter>.... A DOS window will open... At the blinking cursor, type 'chkdsk /r' and press <enter>. You will get a message that the drive can't be locked and do you want to run it the next time Windows starts. Type 'y' and press <enter>. Now shutdown the computer and restart it... Chkdsk will run and it may take some time... Depending on your installation, you will see a blue screen that will show the progress. Sometimes the screen will stay black and the hard drive light will flash. That's ok. Let it run until Windows loads. Wait until it is completely loaded and then try shutting it down normally....
it works out for u..
thank u!!
  • Prakash Ram
    Prakash Ram Feb 24, 2009
    jus follow the steps i mentioned ur problem will get solved...
    thank u!!!
    Brigadier General:
  • 3,614 Answers
better you try to DO a system restore on the unit.
  • micromaster
    micromaster Feb 23, 2009
    if there was no files to be recover on the unit. you must do a clean install of Xp on the unit. reformat the drive and re install a fresh copy of win xp.
    keep us updated more again here.
    micro
Reiniciar el equipo
Normal restart: select restart from the apple menu, or press the power key (the sleep/restart/shutdown dialog appears), then click the restart button or press the "r" key.
Forced restart (use only if the computer crashes or freezes): Press simultaneously the Apple, Control and power keys.
Forced shutdown (use only if the computer won't respond to anything, not even a forced restart): Press and hold the power button on the computer until the computer shuts off.
Jul 02, 2013 | Apple iMac Computers & Internet
How to put my computer to sleep mode
I do not recommend sleep mode for windows because it eventually causes windows files to corrupt because of in proper shutdown, forcing you to do a full install of the operational system.
Mar 17, 2012 | Dell Latitude D830 Laptop Computer PC...
How can i reboot my acer laptop
Press Start(ORB at bottom left for vista/w7) and if you're on windows 7/vista, there should be a list button on the bottom right side of the start menu saying "Shutdown"(windows 7) and "Sleep"(Vista), click the list and click Reboot.
On XP you need to click the Shutdown button and before you click shutdown instead click Reboot(Green button If i recall correctly).
Jul 15, 2011 | Computers & Internet
How to shut down dell inspiron 530 computer - the button only takes computer to sleep mode
I assume you use Windows Vista.....
In vista the default action of the power button is configured to sleep mode..
So to shutdown the PC you can press "Start - right arrow - right arrow - right arrow - Enter", or you can navigate to the same using the mouse & selecting shutdown from the list besides the lock icon.
You can also change the power button configuration this way goto " Start-Control Panel-System and Maintenance-Power options-change plan settings (under the current plan you are using) - change advanced power settings - Power buttons and lid - Start menu power button" click on settings and select shutdown, apply & save the settings and close this window.
Now you can just click the power button to shutdown your computer.
Jul 05, 2009 | Dell Inspiron 530 Desktop Computer
Problem with startup of XPS 1530
if ur unable enter the save mode...then vista has to b corrupted....install new vista and goto to repair option....
May 26, 2009 | Dell XPS M1530 Notebook
Xps shut down
Follow This!!!
>Start Menu
>control panel
>power options
>Change plan settings (currently selected Plan)
>Change advanced power settings
NOW, Scroll Through this LONG list of options until you see "Sleep" .
Select/Expand The Sleep item.
Expand "Allow hybrid sleep".
Set Both "On battery" and "Plugged in" to "Off".
Now Your computer will sleep as normal...
See this link to clarify if my walkthrough doesn't wor for you:
http://www.howtogeek.com/howto/windows-vista/disable-hybrid-sleep-mode/
Mar 22, 2009 | Dell XPS M1530 Notebook
Try running chkdsk /r and then restart the computer. to do that, click on START, RUN, in the open field, type 'cmd' and press <enter>. A dos window will open. At the blinking cursor, type 'chkdsk /r' and press <enter>. You will get a message that the drive can't be locked and do you want to run it the next time Windows starts. Type 'y' and press <enter>. Now shutdown the computerand restart it. Chkdsk will run and it may take some time. Depending on your installation, you will see a blue screen that will show the progress. Sometimes the screen will stay black and the hard drive light will flash. That's ok. Let it run until Windows loads. Wait until it is completely loaded and then try shutting it down normally.
Good luck and let me know how it works out.
Feb 07, 2009 | Dell XPS M1530 laptop. TUXEDO BLACK. 15.4"...
Dell XPS M1530 trouble shutting down
Try this, just to see if the shutdown actually works.
Open a command prompt and enter the following:
shutdown -s -t 05
-s is to shutdown, -t 05 is a 5 second countdown.  Let me know if it actually shuts down.
Feb 02, 2009 | Dell XPS M1530 Notebook
My computer does not shut down
Ok
Gonna try and teach you some basic programming :-).
What the following will do, is create you a Desktop Shutdown Icon, which when you double click on it, will hopefully shut down your PC rather then restart it.
So here's how to do it :-).
1. Right click on your desktop and select new > shortcut.
2. In dialog box type “shutdown –s”
3. Click next to continue and then type a name for shortcut (IE Shut Down PC) and click finish.
Now you should see the shortcut on your desktop and will hopefully solve your problem.
Dec 08, 2008 | Computers & Internet
Dell XPS M1530 laptop. TUXEDO BLACK. 15.4" Widescreen Thin, slim & light notebook computer, Intel Co...  Logo
320 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
Computer Links
