Question about Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius WMA40S Drum wont turn at all
My Washing machine drum wont turn.Machine fills withwater and drains but drum just wont turn and of course not spin either
  • 3,741 Answers
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Oct 01, 2009
  • charlymonty Oct 01, 2009
    It doesn't spin
    If your washer won't spin, check these:
    It doesn't pump or spin
    It pumps, but doesn't spin
    It spins only with the lid closed
    If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
    • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
    • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
    If your washer pumps out the water but doesn't spin, check these:
    • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
    • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
    • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
    • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
    • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
    • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
    • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
  • 36 Answers
The drive belt needs to be replaced. if you take it to a home depot or a lowes they will replace it at a cheap price. thank you for using fixya
Posted on May 01, 2009
zeusfaber
  • 247 Answers
SOURCE: Hotpoint Aquarius 1000 WM62, fills then trips the house electrics
This sounds very like you've got an insulation breakdown in the heating element, or in the wiring that leads to it. When the water level gets high enough, the machine switches the heater on to start warming things up - at which point the fault gets taken into circuit and blows everything. You already know all the stuff about switching off and unplugging before you start. If you hadn't just been working on the machine, I'd have said just to lash out £23 on spec. and fit a new element. Under the circumstances, it might be worth doing a few checks first: 1. Although you're sure you've replaced all the wires correctly, just triple-check you haven't swapped live and earth at the element. 2. Inspect the wires that run to the element to make sure none of them are chafed or trapped, and that none of the connectors are fouling anything they shouldn't be. 3a. If you can get hold of an insulation tester, use it to check the element earth-live resistance (with all wires disconnected). This should be of the order of a Megohm or more - but will be much less if the element casing has leaked. 3b. On the assumption you haven't got an insulation tester in your back pocket, try this instead: Carefully disconnect the live wire from the element, make it safe with tape if you need to, then try to run the machine. If the machine now fills properly without taking the trip out, then this is a pretty good pointer towards needing a new element. A.
Posted on Feb 18, 2007
jsrock516
  • 5911 Answers
SOURCE: hotpoint aquarius extra wma46
The first question you need to ask yourself is, "is the drain pump running?" If you can hear the drain pump running when it tries to drain, then more than likely you have a clogged drain pump, or drain line. Here's how you can determine which one: You can check the drain line by seeing if it collapses when the pump starts to run. If it does, then you know you have a clogged line somewhere BEFORE the pump. This usually means an article of clothing has gotten between the wash basket and outer tub and is stuck in the line. If the line is full of water and doesn't seem to be going anywhere, hook up a wet/dry shop vac to the drain hose in the rear of the machine to see if you can pull water from the tub, through lines, and through the pump. If you can't, you know you probably have a clogged pump, or drain line AFTER the pump. If the drain pump does not come on, you may have a pump failure. In either case, you need to drain the water from the tub. A wet/dry shop vac does a great job at pulling water from the tub, so you don't have to bail. Let me know if this helps.
Posted on Jul 22, 2007
  • 155 Answers
SOURCE: Drum Paddle broken Hotpoint Aquarius
The paddles in the drum are there to agitate the clothes being washed. Without them, it is possible that the drum would just spin while the clothes sat still at the bottom.
For optimum performance, it is best to have all the paddles present, but if one is broken/missing then it shouldn't have too much effect.
Hope this helps,
Matt
Posted on Mar 08, 2008
  • 47 Answers
SOURCE: drum not going around
Bad belt or transmission.
Posted on Jun 25, 2009
barkencoa
  • 3463 Answers
SOURCE: Hotpoint Aquarius 1100 WM63 Not Spinning Clicking Programmer
I would suggest you check the brushes in the motor, as it sounds like they are worn out.
Replace them if they are less than 3 or 4 mm long
This would give you the symptoms you are describing.
Please rate my solution.
Thankyou.
Posted on Feb 09, 2010
Hotpoint Wt540 1400 wont spin
check the machine washes ok if it does not turn the drum on wash check the motor brushes if drum action is ok on wash check the drain pump for blockages
Mar 06, 2014 | Hotpoint Aquarius WD63 Front Load...
Machine will not final spin
I was given wrong info. the machine did go through the cycle and drain. However, the drum DID NOT revolve at all. Main motor Brushes replaced. Now OK. Thanks.
Feb 15, 2010 | Hotpoint Washing Machines
Hello i have a hotpoint wma40 the machine will go
Hi, i have a wma40s had it for 7 ears now same thing happended would start a cycle but then stop halfway through make the noise but the drum would not spin etc. i bought some carbon brushes of ebay for 7 quid and it works better than its worked in years bit nosiey for first few washes but after it settles it is as good as new.
Jul 06, 2009 | Hotpoint WMA40 Front Load Washer
Aquarius washer drum stuck
sounds as if the drum bearings have gave way was it noisey b4 this
Jun 06, 2009 | Hotpoint Aquarius WF220 Front Load Washer
WF340 hotpoint aquarius WASHINING MACHINE
Hi, Remove the drive belt from the drum & motor then turn the drum be hand, Is it noisy? if it is then the drum bearings need replacing i have used this website before and they are very good.
http://www.candmdomesticappliances.co.uk/section.php/88/1/hotpoint-washing-machine-spare-parts
Apr 22, 2009 | Hotpoint Aquarius WF000 Front Load Washer
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details you need to observe if machine is draining and pumping water inside during cycle, see: It doesn't spin
Jan 06, 2009 | Hotpoint WMA54 Front Load Washer
Drum wont turn
I WOULD CHECK THE FLYWHEEL THAN LISTEN FOR SOUND OF THE MOTOR IF YOU HEAR IT SPINING THAN IT IS POSSIBLE THE SHAFT IS BROKEN OR SEIZE
Jun 16, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
hold the start button for 5 seconds this should clear previous program. then select drain on your dial. press start as normal and machine will drain. if this does not work the only other remedy is with help, making sure the end of the drain hose is higher than drum at all times take machine outside, lean it back at 45 degrees agaist a wall with a towel or similar covering lid to stop scratching . working from underneath loosen the large jubillee clip that connects the drum to pump drain hose to the drum. As the drum is overfull there is no recepticle large enough to fit under so just let water just flow away. Dry every thing off. make sure you don't loose ping pong ball in filter and make sure filter is clear. refitting is reverse of removal
Mar 28, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WMA42 Front Load Washer Logo
208 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
