Question about Kitchen Ranges
Unable to close the bottom oven drawer (Kenmore)
There is a baking pan stuck behind the bottom oven drawer of our Kenmore Electric oven. The drawer will not close and I can't figure out how to pull the drawer out to remove the pan?
  • Anonymous Mar 14, 2014
    bottom drawer of oven came off the railing but i can take it out
    Novelist:
  • 117 Answers
Pull the unit away from the wall and in most cases you can reach in the oven pan from then rear. If not.....pull the unit away from the wall and then lift the front about 3 inches away from the floor and let if drop....thus shifting the items in the drawer....If I can help further, I am here
Eric Campion
Posted on Feb 23, 2009
Bottom oven drawer stuck partially open. Cannot close or fully open. Model #316471000
Hello Dan, thank you for your post!
I understand that the bottom drawer of your Electrolux range will not close and it partially open. It is possible that your rail or drawer may be damaged or blocked. I would recommend pulling the drawer out to inspect it. If you pull the drawer out there should be tabs on the side to unlock in order to remove the drawer fully. The model number you have provided is invalid you can locate the model number on the serial tag. The serial tag can be found on the frame of the drawer. I look forward to assisting you. -Matt
Dec 25, 2015 | Electrolux 30" Self-Cleaning Freestanding...
Tin foil stuck to bottom of oven how to remove it
See this link: http://askruth.blogspot.com/2006/07/cleaning-baked-on-foil-in-oven-help.html
"I called Sears and this is what they said to do:
BE CAREFUL, remove as much of the foil as possible Turn oven on to 200 lay an old wet bath towel on top. Use a plastic spatular to remove the foil.
They said it will take some time to remove the foil, in some cases days, and that you can still use the oven but DO NOT use the self cleaning untill all the foil is removed."
If you can remove the bottom drip tray/pan from your oven which the tinfoil is stuck to, than remove it. Ovens with "hidden element" usually have the removable bottom tray/pan. Don't scrape yet!!
Lay the tinfoil laden tray on a flat service where it wont be disturbed for a couple of days.
Now remove any tinfoil you can with a plastic scraper/spatula/pancake flipper.
Once thats done, pour bleach directly onto the drip tray/pan until it covers all the stuck tinfoil.(assuming your oven pan is like mine and has a lip all the way around and is somewhat countersunk).
Leave the bleach in for about 2 days. Now get your plastic scraper again and scrape away. The stuck tinfoil should all be dissolved by the bleach and the scraper should get rid of any residue. Then rinse!
Now this method will probably leave some darkened stains on the oven tray, but not near as ugly or noticeable as that melted tinfoil!!
Good luck!!
May 14, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Where is the model number/ serial number located on the Maytag Gemini?
Open the door and look at the very bottom, front of range. If yours have a drawer it will be located behind the drawer right under the bake door, on the oven frame.
Jan 05, 2010 | Maytag Gemini 30" Self-Cleaning...
How do i get an aluminum foil pan stuck from the
You may be able to get it opff with the oven hot. Whatever is holding it was liquid when hot before, so should at least loosen enough for you to remove it.
Nov 04, 2009 | Kenmore 47783 Electric Single Oven
When baking bread in my Kenmore electric range (9435) the loaves on the bottom rack burn on the bottom and the ones on the higher rack take almost 2X as long to cook
In an electric range, the ideal place for baking is the middle shelf. there are temperature differences within the oven cavity. On the bottom shelf the heating elements actually "broil" the bottom of the pan. In the upper part of the oven, the temperature is lower, being blocked by the lower pans. A convection style oven is more ideal for bread baking.
Aug 23, 2009 | Kitchen Ranges
I need to get the oven floor out to clean under it.
pull your bottom drawer out and lift up on the front of the drawer then remove the drawer. then remove screws to remove the floor pan
Apr 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven won't light on bake
IF THE IGNITOR GLOWS WHEN YOU TURN ON THE OVEN, BUT DON'T GET ANY FLAME, IT IS MOST LIKELY THE IGNITOR. THE COST OF IT IS AROUND 50-75 DOLLARS.
TO REPLACE ONE, YOU MUST GAIN ACCESS TO THE OVEN
BAKE BURNER BY LIFTING OUT THE BOTTOM PAN OF THE OVEN. THEN REMOVE TWO SCREWS THAT HOLD THE IGNITOR TO THE BURNER. FOLLOW THE WIRES DOWN TO THE CONNECTOR PLUG. SELF-CLEAN MODELS WILL BE BEHIND A PANEL BEHIND THE STORAGE DRAWER. NON SELF-CLEAN MODELS WILL BE BEHIND AN ACCESS PANEL DOWN IN THE BROILER AREA. DISCONNECT THE PLUG AND REPLACE THE IGNITOR IN REVERSE ORDER.
PART NUMBER 12400035 MAYTAG.
Mar 31, 2008 | Kitchen Ranges
Warming Drawer stuck
Pull the oven out and see if you can get to the pans from behind.  May have to lift up on the back of the oven to get out fallen pans.
Oct 25, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
945 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
