Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
I have a ESp3 all in one print, it will not print true colours from my computor or the scaner, but is perfect copying on photographic paper, Why??? It worked perfectly well when I first had it from new 6months ago.!
    Sergeant:
  • 151 Answers
For that problem kindly try doing the ff:
* Re-seat the inks both color and black then try printing
* Re-seat the Printhead of the printer then print again
* if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Posted on Sep 23, 2009
Software disk will not down load can I down load the drivers etc online
Please go to the Kodak model ESP3 multi-function printer support page by clicking on the link below, or copy and paste into your browser.
Print the instructions for installationo of the software / drivers, then download and follow the prompts to install the Kodak ESP3 multi-function printer.
Make sure you select the operating system on your computer, ea XP, Vista or Windows 7.
Good Luck
http://support.en.kodak.com/app/answers/detail/a_id/36460/selected/true
Aug 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Brother MFC-6490CW not printing properly. Need a deep clean code please?
Hold down the menu key. While still holding the menu key, unplug the machine and plug it back in. Do not let go of the key until the machine reboots and the screen says "maintenence". Hit the following keys: 7, 6, 4,black start. The machine will then go into "power purge" or deep clean mode for about 5-7 minutes. When complete hit: 99 to get out of maintanence and reboot. Be sure to have extra ink cartidges on hand as it does use up a lot of ink but this process works the best every time when the printer wont print.
Jan 17, 2011 | Brother MFC 6490CW InkJet Printer
My printer will not print in black and white, as my colour cartridge is low. How can I just print in black ink? Kodak esp3 all-in-one printer.
Believe or not, a bit of color ink is require to make true black. However, from most application you can go in to the printer preferences and click the Color tab. Check the print in Grayscale and click the Black print only option. My instructs are based on an HP model printer. The preferences can be a little different between brands. But, you should have similar options. Check your printer's manual for more specifics.
Oct 03, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Esp3 printer, has new cartriges, printing very fient
Have you tried the maintenance tool - if you open the kodak printer status monitor in your taskbar (next to the clock); at the top right hand side you will see an icon showing crossed hammer and spanner, click on this and run the tools from top down (dont need to do the test page).
If that doesnt work you could try this:-
my new esp3 printer (replaced due to not printing black) came with a suppliment document for action if no black or faint print appears!!:
verify paper is loaded into paper tray then press and hold the Cancel and Copy/Resume buttons simultaneously until the On/Off light flashes -apparently this fixes the no black/faint issue.
hope this helps
Jun 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Hp F4180 No copy to Plain paper
If you just replaced the ink cartridges, make sure you've removed the plastic tabs that cover where the ink shoots out. If they are old cartridges, make sure that the nozles haven't dried up. Remove the cartridges and dab a cloth (one you don't mind staining) where the ink shoots out, if all the colours show up, it's clear. If you notice very little colour, or none at all, try dampening the cloth and wiping down the cartridges to promote inkflow through the nozles. Hope this helps.
May 30, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Color isn't true
You'll need to calibrate your screen and your printer - calibration is required for every set of paper and ink you use. It's quite a science and an art. I suggest you google "colour space" "printer calibration" "gamut" etc and read up on it. Alternatively you could spend a few hundred quid on a printer calibration tool, either the Colormunki or the Spyder print studio.
It still won't match perfectly, as the way color is created on a screen differs hugely for to how it is produced on paper.
Start with a properly calibrated screen first though (my money is on the Spyder elite screen calibrator and spyder print calibrator)
I'm a pro photographer and I print my own photos - full system calibration is the only way. www.yourhandinmine.co.uk
Steve Causon
Apr 08, 2009 | Epson Stylus 1400 InkJet Photo Printer
IP3300 Problem with greyscale photo prints
Have you tried configuring the paper options for the type of paper you are using?
Oct 08, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Samsung CLP 510 - won't print on photo paper.
Have you changeed the PAPER type to (specialty or card stock) this always work for me. Your printer will have these setting
Aug 31, 2008 | Samsung Office Equipment & Supplies
Printing Problem
You may have a problem with your magenta color cartridge ????
Mar 25, 2008 | Office Equipment & Supplies
Old Polaroid photos
Having photographic quality copy prints made will give you far longer life than the original Polaroid. Polaroid colour dyes will shift colours and eventually fade dramatically. New photographic (and some ink jet) prints will last generations without noticeable fading.
Feb 24, 2008 | Photography
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
56 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
