Display just started displaying message ''Cavity Size 30'' then it says to increase press 3 and to decrease press 6, then press start.
If you press 3,6, Start or any other button you just get the quick 3-beep sound which means it's an incorrect button choice.
We threw the breaker at the electric panel and re-energized the unit but it still displays the message.
Had the same message on my display after spilling water on the cooktop. Obviously, the seal (rubber gasket) that prevents liquids getting inside the control area is not very good.
I replaced the Control (p/n: 10181439 / 9761799, 2 numbers, same part) and the flat cable between the touch keypad and the Control (9762781).
After turning the breaker back on, only had the message to set the clock.
SOURCE: My control panel display reads
Check this site.
http://www.repairclinic.com/Fault-Codes
Anymore questions please comment me back.
SOURCE: Clock problem
try holding hte clock/set start button in for 3-5 secs, it sounds as if youve accidently turned of the clock display. .. a common issue especially after turning clocks back.. its a built in feature for people with too many clocks in kitchen, they allow you to turn off the display.
Capacity
Oven Capacity (cu. ft.): 1.6
Features
Wattage (IEC-705 Test Procedure): 1000
Cooking System: CircuWaveâ„¢
Plus
Power Levels: 10
Style: Over-The-Range
Clock: Plus AM/PM
pad
Electronic Scrolling Digital Display: Yes
Electronic Touch Controls: Yes
Kitchen Timer/Timer (On/Off): No/Yes
Variable Scroll Speed: 5
speeds (sub-pad w/ AM/PM)
SmartControl System - Concurrent Programming: Yes
SmartControl System - Help Pad: Yes
Beverage (Convenience): Yes
Cook (Convenience): 9
Codes
Popcorn (Convenience): Yes
Reheat (Convenience): 6
codes
Add 30 Seconds: Instant-On
Child Lock: Yes
Cooking Complete Reminder: Yes
Defrost Type: Auto
& Time
Delay Start: Yes
Display On/Off: sub-pad
w/ zero
Express Cook: Instant-on
1-6
Reminder (24 hr): Yes
Time Cook: I
& II
Time Preference: Control
Enhancement (1/9)
Turntable: Glass
Turntable On/Off: Yes
Turntable Size (in.): 13-1/2
Cooktop Lighting: Bright/Night/Off
Night Light: Auto
Rack Type: Wire
Oven Rack
Sound Volume Control: 4
levels
Easy Mount Installation: Yes
Exhaust Fan: 2-Speed
Appearance
Case Color: Black
Color Appearance: Stainless
Steel
Door Color: Black/Stainless
Steel
Handle: Designer-Style
Weight And Dimensions
Approximate Shipping Weight: 63
lb
Overall Depth: 15
5/8"
Overall Height: 16
3/16"
Overall Width: 29
7/8"
Cavity (W x H x D): 20
31/32" x 9 3/8" x 14 3/16"
Power/Ratings
Electrical Input - 120V Amperage: 15
Electrical Input - 120V Watts: 1480
Frequency (MHz): 2450
Have exact same problem. Cavity size 30 can't clear.
Cavity size 30 press start to set doesn't work
